| Drill and Fill #117589 09/18/07 10:38 PM 09/18/07 10:38 PM |
Posts: 902 Norman,OK | I am in the process of rigging my 5.2 with a spin and am wanting to drill holes in the bows to attach bridles for the spin pole to.
I can handle the drilling but what should I fill the hole with. I can work fiberglass well but it always is so ugly, I saw some paste stuff that might work, would that be easier?
Anyone have advice?
| | | Re: Drill and Fill
[Re: gree2056]
#117590 09/18/07 11:25 PM 09/18/07 11:25 PM |
Posts: 4,119 Northfield Mn | The bridles for the spin pole on my FX attach to where the bridles for the mast attach to the hull.
| | | Re: Drill and Fill
[Re: gree2056]
#117591 09/18/07 11:30 PM 09/18/07 11:30 PM |
Posts: 2,921 Michigan | west system with structural filler would be my suggestion. You could use some chopped glass as well but I think the structural filler would be fine. But then again, there are smarter than me engineering types around that could give you a little more info. here is what I would do- drill the hole- not a very big one though. Put a piece of tape over one side. Inject west sytem with maybe a little structural filler into the hole to make sure it is all in contact with the surrounding glass/etc. You could then add more structural filler to the epoxy making it almost a paste and put it in there.
| | | Re: Drill and Fill
[Re: Karl_Brogger]
#117592 09/18/07 11:31 PM 09/18/07 11:31 PM |
Posts: 902 Norman,OK | I know on alot of boats that bridles attach near the bows plus ones at the same point the bridles for the forestay attach.
| | | Re: Drill and Fill
[Re: bsquared]
#117594 09/19/07 09:00 AM 09/19/07 09:00 AM |
Posts: 902 Norman,OK | So you used West System. I have never worked with it, I assume that West Marine would carry it?
869
guests, and 648
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 Sep 13th, 2025 | | | |
