Cracked luff track on comp tip. Repair? #118685
09/28/07 09:29 AM
09/28/07 09:29 AM
M
mswanson Offline OP
mswanson  Offline OP
M
I noticed that I have a crack piece of plastic on the comp tip of my 16. When raising the main, the sail would pull out of the luff track on the comp tip, but I was able to still raise the sail by putting the boat on it's side and raising the main that way.
I would think some type of repair on this would be possible, but what type of glue should I use? Super glue? Epoxy?
The crack is about 1.5 inches long.
Thanks for any help!
Re: Cracked luff track on comp tip. Repair? [Re: mswanson] #118686
09/28/07 11:12 AM
09/28/07 11:12 AM
California
mmiller Offline
mmiller  Offline
California
The tracks are removable / replaceable. You might try reversing the track (top to bottom). The track on a 16 is a bit difficult to get off the mast, so perhaps replacement would be easier as you may damage the track further removing it.
Replacement instructions:
http://www.hobiecat.com/support/pdfs/38584001.pdf
The track for the 16 is a different profile than shown, but the process is the same. Because of the 16's different shape, it is a bit harder to remove.
Replacement track is # 20616001
0 registered members (), 2,610 guests, and 425 spiders.
