Page 1 of 5 1 2 3 4 5
Blade building project.. #119618
10/08/07 08:47 AM
10/08/07 08:47 AM
Rolf_Nilsen Offline OP
Ref: http://woodastic.blogspot.com/
We are finally underways with our building. We plan to update the blog every week for those who might be interested. So far the strongback is done and we begin cutting and fairing the stations this week.
Re: Blade building project.. [Re: Rolf_Nilsen] #119619
10/08/07 09:06 AM
10/08/07 09:06 AM
By all means, keep us posted. And good luck!
Re: Blade building project.. [Re: fin.] #119620
10/08/07 09:37 AM
10/08/07 09:37 AM
Rolf:
I noticed you said you are on a budget, I am currently selling my older sails for $500.00 (jib and main) battens included. Now the only problem I can see is shipping them to your location wont be economically feasible.
Re: Blade building project.. [Re: Rolf_Nilsen] #119621
10/08/07 09:49 AM
10/08/07 09:49 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Three at once!!! Sounds like a fleet building party.
Re: Blade building project.. [Re: tshan] #119622
10/08/07 09:55 AM
10/08/07 09:55 AM
Thanks for the offer Robi. Mainsail would never fit our masts and I do think we want to do the sails ourself. Nothing like crisp new sails <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Blade building project.. [Re: Rolf_Nilsen] #119623
10/08/07 10:11 AM
10/08/07 10:11 AM
No problem Rolf, keep us updated. I am specially interested to see how that tornado rig is going to work out for you.
Re: Blade building project.. [Re: Rolf_Nilsen] #119624
10/08/07 10:59 AM
10/08/07 10:59 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
are you going to get the hulls down to weight with strip planking?
Have you done the weighing out?
<img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Re: Blade building project.. [Re: Stewart] #119625
10/08/07 12:17 PM
10/08/07 12:17 PM
We think it will work out well Stewart. We will pull off a test panel with 200gsm/4mm spruce/200gsm cloth once we have the stations set up to get some numbers. Considering that ply usually have three layers of epoxy on each side plus paint we should be good if we are careful with gaps (epoxy is heavy and expensive). I have also been talking with strip kayak and canoe designers about how to build light and got lots of tips. We have discused weight at length but only the test panel will tell. We will also do some experimental stuff inside the hulls to bring weight down as far as we dare. It will all be documented in the blog. Phill have come up with some new (to me) ideas which it will be fun to implement.
Re: Blade building project.. [Re: Rolf_Nilsen] #119626
10/08/07 04:50 PM
10/08/07 04:50 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
Good luck with the project Rolf. Keep posting the Blog address every time you update it - I can never remember these things <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Maybe you should set up a webcam, so that we can all watch and give our opinions and advice on the cold winter evenings <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Dermot
Catapult 265
Re: Blade building project.. [Re: Rolf_Nilsen] #119627
10/09/07 04:29 AM
10/09/07 04:29 AM
Finland
Gato Offline
Gato  Offline
Finland
Welcome to the club Rolf
Re: Blade building project.. [Re: Rolf_Nilsen] #119628
10/09/07 12:11 PM
10/09/07 12:11 PM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
cool.. Hope it works out!!..
200 gsm glass?.. I suspect you could drop to 100gsm if you wished. Although 200 will give greater scuff resistance...
If you wanted to be tricky you could use a combination of 100 & 200..
But dont listen to me I enjoy mucking about in a shed too much.. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Blade building project.. [Re: Stewart] #119629
10/09/07 12:27 PM
10/09/07 12:27 PM
Stewart,
I am happy with any input, especially critical, as that often bring a new angle or information to the issue.
200gsm is choosen becouse it have proven to be a good schedule on kayaks both for strength and stiffness. Some of the tests done by Gougeon bros (J.R. Watson really did them I think) indicate that this is the best weight vs panel stiffness ratio for our project as we try to match materials to make it as strong as a proven ply boat. But as mentioned earlier, only the test panels will tell.
85gsm at the bow and 200gsm further back has been suggested.. How much work should we put into this is the question. Interestingly enough, a carbon laminate dont seem to have helped to bring weight down. A light carbon cloth would probably have needed more epoxy so it would have come out stiffer and stronger, but heavier. Pretty interesting I tought.
By golly, I also hope this works out <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Blade building project.. [Re: Rolf_Nilsen] #119630
10/10/07 12:36 AM
10/10/07 12:36 AM
Finland
Gato Offline
Gato  Offline
Finland
I agree with Stewart that 100g is enough. It is in one way only surface strength you will gain. You will need to put the glass fibres at 45 degrees to the woodfibres to gain anything in strength.
Re: Blade building project.. [Re: Gato] #119631
10/10/07 02:20 AM
10/10/07 02:20 AM
Thanks Åke (and Stewart). I understand that your opinion is that except for scuff resistance a catamaran strip hull will not gain much in the way of strength by using 200gsm instead of 100gsm. Correct?
I was worried that panel stiffness and strength would not be good enough for loads working 90degs on the wood fibers, making the glass strands break with catastrophic hull failure as a result. We dont plan to put much inside the hulls. Just partial bulkheads/ring-frames under the beams and at the bridle, going for a monocoque structure. This means that the panels between the bridle and the mainbeam will have to take care of themselves.
BTW, Åke. Just had a look at the pixie building photos you have on your site. I must say that your workshop is really nice and inspirational with its position just by the water. Looks like an old boathouse? If you work with epoxy during winter, how do you heat it?
Re: Blade building project.. [Re: Rolf_Nilsen] #119632
10/10/07 04:08 AM
10/10/07 04:08 AM
Finland
Gato Offline
Gato  Offline
Finland
If you put the glas mat so the fibers lay 45 deg to the wood fibers you will have them all working to prevent the hull cracking.
The best would be to use a Biaxial 45 deg mat.
I am also scared that you will have to glass both sides, at least on bigger boats it is the rule
Re: Blade building project.. [Re: Gato] #119633
10/10/07 04:34 AM
10/10/07 04:34 AM
Hoookay.. Why is that? Glass fibres better aligned to the shearing loads between planks?
Do you even get biaxial +-45 200gsm glass? (or 100gsm)
The plan is definately to glass both inside and outside!
Re: Blade building project.. [Re: Rolf_Nilsen] #119634
10/10/07 04:57 AM
10/10/07 04:57 AM
Finland
valtteri Offline
valtteri  Offline
Finland
At least few strip planked kayak plans that I have seen contained 160 g/m² glass on both sides. Why not strip plank with foam? With some heating the foam strips could be bigger than wood ones thus saving lot of time. Of course foam is not as "cool" material than wood <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />.
Valtteri Blade F16
Re: Blade building project.. [Re: Rolf_Nilsen] #119635
10/10/07 05:53 AM
10/10/07 05:53 AM
Finland
Gato Offline
Gato  Offline
Finland
The wood in itself has very low resistance to shearing loads <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Don't think you can find BX+-45 of less than 400g
Re: Blade building project.. [Re: Gato] #119636
10/10/07 06:11 AM
10/10/07 06:11 AM
Hmm, I can always cut plain weave and use that as a 90-90 substitute put on skewed but there might be rather a lot of waste and work in applying it. Overlaps and stuff is not much fun..
Re: Blade building project.. [Re: Rolf_Nilsen] #119637
10/10/07 07:10 AM
10/10/07 07:10 AM
Rolf,
From my own experience your comment about using light carbon and using more resin is not right. The type of weave, without a vacuum, has a greater bearing on weight. If you comparing plain weave to double bias then double bias will consume more resin although it would be stronger. Now double bias and a vacuum would be a good combination. I plan on trying this on the outer laminate of another project.
Now if you were talking about light kevlar and carbon or glass you may have a point but only because kevlar is such a bitch to work with.
If the outside was plain weave glass at +-45 would be very easy with very little waste and provide a hull that would most likely have better tortional stiffness and equal in all other respects. The issue is making the overlaps fair. This is easy if painting the hulls but requires more skill if a clear finish. You can work on an approx 0.1mm of thickness of the laminate for 100gm of cloth weight. So if using 200gm you would need a rebate on each overlap (1/5 of a mm) it could be achieved with a thin sanding block and course sand paper.
Just lay the cloth in place on the hull and mark the overlaps and then sand a rebate. If you go a little deeper this can be solved while filling the weave of the glass with clear resin. If painting it is even easier because you can use filler.
BTW:+-45 would work out easier to apply because it can be done in sections and the weave will take the complex shape much better rather than one whole side on the hull in one hit that will not take the complex shape as well.
Most Online22,490
Yesterday at 08:14 AM
