| Data on Infusion mast surface #119885 10/09/07 01:32 PM 10/09/07 01:32 PM |
Posts: 36 World Citizen | Hi, I'm ordering new sails and wondering if anyone out there has valid data on Nacra Infusion (2006) mast surface so I'm not jeopardizing the 17 sqm-rule when up for measurement.
Also, any Infusion sailor out there who have tried a real fathead main (more than 1000 mm top) and like to tell the results?
Kind regards, J E
JFR Infusion Mk2
| | | Re: Data on Infusion mast surface
[Re: JFR]
#119886 10/09/07 04:38 PM 10/09/07 04:38 PM |
Posts: 1,203 uk | What would be the point in +1000mm? It contravenes class rules!
[Re: JFR]
#119888 10/10/07 04:54 AM 10/10/07 04:54 AM |
Posts: 1,203 uk | just had a look at my measurement cert and the mast area is measured at 1.7m2
[Re: TEAMVMG]
#119889 10/20/07 06:56 AM 10/20/07 06:56 AM |
Posts: 36 World Citizen | TEAMVMG: Thanks for that. I wonder if there is a decimal more in your cert.
Tiger mast surface is measured at 1,51 sqm. Since Infusion mast is appr. 3 cm more shouldn't it mean that the Infusion surface is more like 1,75m2?
And yes I know your sailmaker should know this but the problem occurs when you convert a Tiger main for Infusion use.
JFR Infusion Mk2
[Re: Will_R]
#119891 10/22/07 02:04 AM 10/22/07 02:04 AM |
Posts: 757 japan | is there a formal or informal definition of a wingmast?
something like, "a wingmast is defined as a teardrop section rotating mast, controllable, that makes up at least 10% of the chord of the sail"
because there are tables around that start the calculation at 5% of chord
[Re: erice]
#119893 10/23/07 01:55 PM 10/23/07 01:55 PM |
Posts: 36 World Citizen | Will R: Thanks for pointing that out. I did not see it needed clarification.
JFR Infusion Mk2
591
guests, and 41
