Data on Infusion mast surface #119885
10/09/07 01:32 PM
10/09/07 01:32 PM
World Citizen
JFR Offline OP
JFR  Offline OP
World Citizen
Hi,
I'm ordering new sails and wondering if anyone out there has valid data on Nacra Infusion (2006) mast surface so I'm not jeopardizing the 17 sqm-rule when up for measurement.
Also, any Infusion sailor out there who have tried a real fathead main (more than 1000 mm top) and like to tell the results?
Kind regards,
J E
JFR
Infusion Mk2
Re: Data on Infusion mast surface [Re: JFR] #119886
10/09/07 04:38 PM
10/09/07 04:38 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
What would be the point in +1000mm? It contravenes class rules!
Re: Data on Infusion mast surface [Re: JFR] #119887
10/09/07 06:42 PM
10/09/07 06:42 PM
ncik Offline
ncik  Offline
Your sailmaker should be responsible for making the sail measure correctly. Most are willing to modify, free of charge, if it fails measurement. Usually the foot gets trimmed, it's the easiest spot.
Re: Data on Infusion mast surface [Re: JFR] #119888
10/10/07 04:54 AM
10/10/07 04:54 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
just had a look at my measurement cert and the mast area is measured at 1.7m2
Re: Data on Infusion mast surface [Re: TEAMVMG] #119889
10/20/07 06:56 AM
10/20/07 06:56 AM
World Citizen
JFR Offline OP
JFR  Offline OP
World Citizen
TEAMVMG: Thanks for that. I wonder if there is a decimal more in your cert.
Tiger mast surface is measured at 1,51 sqm.
Since Infusion mast is appr. 3 cm more shouldn't it mean that the Infusion surface is more like 1,75m2?
And yes I know your sailmaker should know this but the problem occurs when you convert a Tiger main for Infusion use.
JFR
Infusion Mk2
Re: Data on Infusion mast surface [Re: JFR] #119890
10/21/07 08:54 PM
10/21/07 08:54 PM
Will_R Offline
Will_R  Offline
Tiger mast is tear drop, the Infusion mast is Wing (more surface area)
Re: Data on Infusion mast surface [Re: Will_R] #119891
10/22/07 02:04 AM
10/22/07 02:04 AM
japan
erice Offline
erice  Offline
japan
is there a formal or informal definition of a wingmast?
something like, "a wingmast is defined as a teardrop section rotating mast, controllable, that makes up at least 10% of the chord of the sail"
because there are tables around that start the calculation at 5% of chord
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Data on Infusion mast surface [Re: erice] #119892
10/22/07 02:09 AM
10/22/07 02:09 AM
japan
erice Offline
erice  Offline
japan
ie in the middle of this page
http://www.tspeer.com/Wingmasts/teardropPaper.htm
and the title is "aerodynamics of teardrop wingmasts"
confused
eric e
2009 weta tri - 294
Re: Data on Infusion mast surface [Re: erice] #119893
10/23/07 01:55 PM
10/23/07 01:55 PM
World Citizen
JFR Offline OP
JFR  Offline OP
World Citizen
Will R: Thanks for pointing that out. I did not see it needed clarification.
JFR
Infusion Mk2
