| Cats and weight #12095 10/27/02 11:35 AM 10/27/02 11:35 AM |
Joined: Aug 2002 Posts: 215 Durham, North Carolina jwrobie OP
Posts: 215 Durham, North Carolina | Between the two of us, my wife and I weigh 360 pounds. We're keeping our eyes out for boats designed for somewhat heavier crews than our Prindle 16, which Wouter says tops out at 325 pounds - it sails fine for us, but we are sailing rather deep into the water. Our combined weight does seem to be dropping slowly, but it won't hit 325 any time soon ;->
What boats should we be looking at? We sail mainly on inland lakes, but would like to be able to sail on the Pamlico sound or possibly on the ocean. I assume most 16 foot boats will not have any more buoyancy than our P16. So far, people have suggested we look at the Hobie 18, Prindle 19, Prindle 19MX, and Prindle 18-2. Are these all good choices? Are there other good choices not on this list?
How hard is it to get a Hobie 18 without comp tips?
Jonathan | | | Re: Cats and weight
[Re: jwrobie]
#12097 10/27/02 02:18 PM 10/27/02 02:18 PM |
Joined: Aug 2002 Posts: 164 The Netherlands (North West Eu... RobLammerts
Posts: 164 The Netherlands (North West Eu... | A perfect cat in my opinion would be a nacra 6.0.
Me and my crew together weight a 175 Kilo’s.
And we can handle is perfectly, the boat can also be very good handled by one person.
It listens very good and is easy to handle.
I used to sail a 18ft Dart, but we were to heavy crossing the waves (slowing down caused by water under the tramp).
Another advantage is that the spare parts for the 6.0 are easy to get both used and new.
I am sure that you can find a 6.0 owner who will take you on board for a tryout.
Success.
Rob
Nacra 6.0 European version
Nr 090 + Spi
| | | Simple
[Re: jwrobie]
#12101 10/27/02 07:31 PM 10/27/02 07:31 PM |
If you like the P16 than maybe going for a P18 is just the right step to take. That boat will take 360 well. I had both the 16 and 18 and the 18 with to guys on it (also 360) went well.
| | | Re: Cats and weight
[Re: jwrobie]
#12103 10/27/02 08:11 PM 10/27/02 08:11 PM |
Posts: 80 Vero Beach Fl | My crew and I weigh in at over 400 lbs and have been racing a NACRA 6.0NA for the last year. I am very pleased with the boat, it is very well built and durable. Performance wise, it is a big step up from the P-16 and with that comes some trade offs. On the plus side you have speed, pointing ability, lots of hull volume, resistance to pitch poling, and reasonable pricing. On the downside, it is a powerfull but well behaved boat. Adding a furling jib could be a solution-it will sail well on the main alone. Another point is it a very busy boat with lots of control lines, but this could be cleaned up by replacing the jib lead system with a cleaner set up if you are not racing. Having dagger boards is another task, but they are well worth it unless you sail on very shallow water. I have had 3 200lb guys on the boat and it still moves! Even though a used 6.0 will cost twice that of a H-18, it is worth it(I owned an 18 for years) P-19s are also nice and can be picked up very inexpensive ($2000) but are much more fragile. You may also find some very good deals on a NACRA 5.8 (19ft) as they have been around quite a while. Good luck with your search-boat shopping is one of the best pleasures in life. | | | Re: Simple
[Re: jwrobie]
#12112 10/28/02 01:11 AM 10/28/02 01:11 AM |
Posts: 3,116 Annapolis, MD | Wow
Lots of recomondations of really high performance boats!! No questions to Johnathon about what kind of sailing he really wants to do. How likely is he to go sailing in 15 knotts... or is he really sailing in 10 knots and fair weather. How shallow is the Pamlico sound??? In many of the tidal bays, sandbars are constantly shiffing. A boardless boat or a boat with kick up centerboards and rudders is much more user friendly. How much weight can you and your wife move around on the beach...Will you be trailering the boat often and stepping the mast... Dead boat weight on and off the trailer will get old quick and stop you from sailing your toy. Similar... the raising and lowering of the mast are really intimidating to lots of people and require a good bit of stength or rigging to deal with.
There is no harm in moving up in boat performance slowly...I would recomend a couple of moderate jumps upward... as opposed to an I20 when you have sailed P16'.!
Boardless boats that would suit are the N5.7, the Dart 20 and a G Cat 5.7.... In addition, these rigs are boomless which is another user friendly feature for family and friends. These boats are noticibly faster then your P16 and have about the same level of conrol lines.
It does not sound like you are looking for a huge performance increase... however, a step up from the boardless boats would be the P18-2 and Nacra 5.5sloop. Mystere 5.5. The first has a boom and kick up center boards... the second is boomless with dagger boards. .. I would make sure that you sailed the P19, N5.8 and Hobie 20 plus all of the 20 footers in a decent breeze before you purchsed one... the power in these boats could be a huge surpise and much more then you want to deal with.
I own a Dart 18 and a Tornado.... I sail the Dart solo, and with family and non sailing friends.... Its simple, boomless and fun and extemely versitile. The Tornado is lots of boat (Similar to Nacra 6.0's and I 20's in power) It is not as much fun unless you have another sailor with you who can sail the boat with you...
Check out Mark Michaleson's buyers guide for some good info about possible boats.
Have fun.
Mark
crac.sailregattas.com
| | | Re: Cats and weight
[Re: jwrobie]
#12113 10/28/02 05:38 AM 10/28/02 05:38 AM |
>>Would the P19 be closer to the P16 in terms of simplicity?
Not really. All of these boats were designed a race boats whiel boats like H16, P16 and P18 were more designed as fun boats. Although fun in the old days (70's) meant more performance than fun boats today (wave, getaway)
See my other post too.
| | | People say alot of things
[Re: jwrobie]
#12114 10/28/02 06:12 AM 10/28/02 06:12 AM |
I notice that people say alot of things. And I can't best rebut any statements in the following way.
If you think that P16 sails well (Pitchpoling ?) than you'll be happy with the P18 (similar or less pitchpoling than the P16)
About bouyancy in the hull, there are far more factors that determine picthpole characteristics. One of those factors is length : width ratio. Ofcourse the P16 and P18 are of equal width with the P18 being longer. Another factor is mastheight and sailarea and so on.
Simple looking at bow volume and saying "That'll Pitchpole like a Dolphin" is indicative of reduced understanding of catamaran design.
A little more info on the Prindles :
The Prindle family can be devided in two branches.
Branch 1 : P15 : P16; P18 : Escape
Branch 2 : P18-2 and P19
Both branches were designed in different periods (exception is Escape) Branch 1 is of 1974 to late 70's and branch 2 is from 1984 to late 80's
Branch 2 is noticable more race oriented and can be compared to Nacras and Hobie's of the same time frame (N5.5; N5,8 TheMightyHobie18, H20)
Branch 1 had as main competition the H16, Dart 18 and G-cats.
Branch 1 : is noticably simpler in design. but also far more robust and will resist abuse far better.
It is my personal opinion that Branch two is better suited to affordable recreational sailing. As many know I'm current upgrade to a High Performance race boat, but I have decided to keep my P16 (Just sold my P18) Why, because in 20 knots and more I just love sailing that craft solo or with a crew and I don't have to fear sandbars or landing back onto the beach with 15 knots of boat speed.
I also love it's simplicity, especially under heavy conditions. And it is a boat that I won't hesitate lending out to someone else.
So when you say :"I do like the P-16 a lot, so a P 18-2 or P 19 sounds pretty inviting.... "
My reaction would be :" If you like the P-16 alot than the P18 should be on top of the pretty inviting list"
I fact it is just a bigger P16 with some extra performance and extra weight carrying capacity.
With respect to being of equal performance upwind as a P16; That is not my experience although I can see that a P16 sailed at its optimal weight 135 kg's (300 lbs) and a P18 sailed at it's optimal weight of 160 Kg's (just over 350 lbs) would be more similar in speed. But ofcourse for crew of the same weight the P18 would be faster.
I've talked about the Prindles in specific by this does not mean that other boats suggested are attractive.
11,410
guests, and 342
