Cat trailer on ground in snow...is this OK??? #122027
11/01/07 08:55 PM
11/01/07 08:55 PM
Minneapolis, MN
duganderson Offline OP
Minneapolis, MN
I'm storing my Hobie Getaway in Minnesota on a trailer in the grass with the tramps off. Will the cold and snow damage the wheels just sitting on the ground in one place with the weight of the boat on the trailer?
thanks, Doug
Re: Cat trailer on ground in snow...is this OK??? [Re: duganderson] #122028
11/01/07 09:23 PM
11/01/07 09:23 PM
DHO Offline
DHO  Offline
If you're really worried about it, you could take the wheels off and keep them in the house, and put the trailor up on jackstands. This also makes it harder to steal.
D.Ho
TheMightyHobie18 1067
Re: Cat trailer on ground in snow...is this OK??? [Re: duganderson] #122029
11/01/07 09:38 PM
11/01/07 09:38 PM
You'll be fine. The biggest thing is snow sitting on the tramp.
Re: Cat trailer on ground in snow...is this OK??? [Re: Karl_Brogger] #122030
11/01/07 10:11 PM
11/01/07 10:11 PM
japan
erice Offline
erice  Offline
japan
machines left out in snow generally suffer less problems than those left out in rain
the biggest problem with freezing is water expansion in pipes and radiators. water just sitting in the hulls doesn't seem to cause any problems when it freezes
at least that's been our experience storing our boats over winter
i've even pulled up and restored a fiberglass dingy that spent 8 years at the bottom of a lake that froze over most winters. a few bubbles in the gelcoat that shouldn't be there but eveything else seems fine structually
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Cat trailer on ground in snow...is this OK??? [Re: duganderson] #122031
11/01/07 10:19 PM
11/01/07 10:19 PM
Darryl_Barrett Offline
SNOW? SNOW? what is this thing called snow? AHH I think I remember that we used to have that many years ago but all the sailers here got together and banned it 'cause it hindered our sailing for the full 12 months of the year.
Re: Cat trailer on ground in snow...is this OK??? [Re: duganderson] #122032
11/02/07 02:10 AM
11/02/07 02:10 AM
Issaquah, WA, USA
H17cat Offline
H17cat  Offline
Issaquah, WA, USA
Suggest you store with the trailer tilted up so water will run off, and with plugs open. Condensation will occur in the hulls, and should be allowed to drain out. This is how we store the cats at Sail Sand Point in Seattle. www.sailsandpoint.org
Re: Cat trailer on ground in snow...is this OK??? [Re: H17cat] #122033
11/02/07 04:54 AM
11/02/07 04:54 AM
M
Mappy Offline
Mappy  Offline
M
I have always stored my trailers with the trailor jacked up on blocks so the wheels are off the ground in NH. Not sure if it is required but my wheels have not have problems.
Re: Cat trailer on ground in snow...is this OK??? [Re: duganderson] #122034
11/02/07 05:38 AM
11/02/07 05:38 AM
srm Offline
srm  Offline
I usually try to put the trailer up on cinderblocks to get the wheels off the ground during long-term storage. Next year I need to replace the wheels anyway, so I didn't bother this winter.
One thing to note. If you store your boat under a tarp with the mast as an A-frame. You need to be careful about how much weight from snow/rain builds up on the tarp. One time I noticed a lot of water had pooled on a tarp, and it bent the mast quite heavily (the mast had rolled with it's side facing up rather than the stronger front facing up).
sm
Re: Cat trailer on ground in snow...is this OK??? [Re: srm] #122035
11/02/07 06:50 AM
11/02/07 06:50 AM
sm
Thats a good point about using the mast that way. I need to cover a larger boat this winter (should probably be shrink wrapped) and was going to do that but I will figure out something else.
Re: Cat trailer on ground in snow...is this OK??? [Re: PTP] #122036
11/02/07 08:04 AM
11/02/07 08:04 AM
sm
Are you seriously worried about snow in Pensacola?
Re: Cat trailer on ground in snow...is this OK??? [Re: Jake] #122037
11/02/07 08:15 AM
11/02/07 08:15 AM
sm
HA!
I wish. I moved to Michigan in August. The blade is snug in my garage in Fl. The larger boat will be up here (who knows where they will all be as the years go on).
0 registered members (), 21,605 guests, and 1,443 spiders.
Most Online23,137
1 hour ago
