prindle 15 , adding a jib? #123711
11/14/07 04:51 PM
11/14/07 04:51 PM
jonathan Offline OP
jonathan  Offline OP
i have a prindle 15, and want to fit a jib to make it a little faster, and more fun to sail. Has anyone done this?, i want to do it cheaply, are there any recommendations as to what is the biggest jib from a different class of dinghy/cat, that would be best to use
Re: prindle 15 , adding a jib? [Re: jonathan] #123712
11/14/07 05:48 PM
11/14/07 05:48 PM
japan
erice Offline
erice  Offline
japan
i've no experience with adding jibs to uni cats but on your question of oversized jibs i seem to remember reading that some people have added nacra 5.8 jibs to the nacra 5.5
from that i'd guess that a jib from a prindle 16 or hobie 16 would be around the right size and pretty easy to find 2nd hand
have you seached for pics of both and compared their rigging to your prindle 15
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: prindle 15 , adding a jib? [Re: erice] #123713
11/14/07 05:51 PM
11/14/07 05:51 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Where are you located?
Trey
Re: prindle 15 , adding a jib? [Re: jonathan] #123714
11/14/07 09:42 PM
11/14/07 09:42 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
fully battoned Hobie 16 will give you great flat sail down wind without barberhaulers but you will need to be onto it up wind in heavy.
Short prod and WAY cheaper than a spinny for more fun that uni.
Re: prindle 15 , adding a jib? [Re: warbird] #123715
11/14/07 10:15 PM
11/14/07 10:15 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
You should be able to find some hobie 16 jib pretty cheap, I see them on ebay all the time.
Re: prindle 15 , adding a jib? [Re: gree2056] #123716
11/14/07 10:35 PM
11/14/07 10:35 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Check your pm's.
Trey
Re: prindle 15 , adding a jib? [Re: NCSUtrey] #123717
11/15/07 07:44 AM
11/15/07 07:44 AM
jonathan Offline OP
jonathan  Offline OP
Thanks, for the respones, i am in the UK. I had thought about, a hobie or prindle 16 jib, but thought they might be too long in the luff, hence my question. I think i`ve sorted out the cleat arrangement, probably on a wire across the tramp, rather than cleats on the front bar, as this would enable a jib with a larger foot to be employed. I think some nacras have this arrangment.?
Re: prindle 15 , adding a jib? [Re: jonathan] #123718
11/15/07 08:58 AM
11/15/07 08:58 AM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
I asked the same question about a jib and received the following reply from a fellow in the Netherlands.
Hi Howard, I bougt a stock P15 jib, which is 3,78 m2 according to the texel rating. Using a HC 14 jib would be fine, thats 3.54 m2. The blocks of the jib are attached to a line between the two stays.
greetz,
Arend
Trey, this Prindle is in Raleigh but my daughter has never had the chance to use it.
Howard
0 registered members (), 454 guests, and 38 spiders.
