| Re: Nacra 5.0 hull and sail numbering
[Re: Toni_50]
#124681 11/25/07 04:25 AM 11/25/07 04:25 AM |
Posts: 757 japan | as far as i know it should be a 1986 model....
that's about the time nacra changed from solid frp to the foam sandwich, which do you have?
as for sail numbers my 1982 nacra 5.2 doesn't have the inverted U symbol either but i have a pic of a 5.2 3089 which does, so i guess it came into use sometime after 1982....
my sail number is J65, which has nothing to do with the hull number as can be seen below but more to do with the fact that it was the 65th 5.2 to be registered? in japan
[Re: arbo06]
#124683 11/27/07 10:57 PM 11/27/07 10:57 PM |
Joined: Nov 2007 Posts: 50 Severna Park, MD David_Nolte
Posts: 50 Severna Park, MD | I concur, the 86 identifies it as a 1986 boat. I've just come into a 1983 boat.
Many manufacturers numbered sails in production order, but there is no reason you can't put any number that has significance for you on it.
David H16, H14, N5.0
David Nolte H16, H14, Nacra 5.0
3,195
guests, and 376
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
