| Re: Kids Cats - Parents input requested.
[Re: alutz]
#125429 12/04/07 04:34 AM 12/04/07 04:34 AM |
Posts: 461 Victoria, Oztralia | Same here, No3. It is so simple to arrange the boards to have a single line pull up system for both boards.
I think its reasonable to assume that the kids won't be shown the boat on the beach and then saying all the best, this all comes down to probably the most important aspect of all of this, our help (adults/parents) I would dare say that the kids would be launched with us up to our...guts and the same when they come back in, initially anyway.
Since having kids, I never under-estimate what they're capable of....
Regards
Matt
Matt Harper
Homebuilt Taipan 4.9
[Re: Rolf_Nilsen]
#125431 12/04/07 05:36 AM 12/04/07 05:36 AM |
Posts: 1,449 | The question I have is - Are C/Bs worth, to the parents, an extra $1000 at least for their kids to have C/Bs over skegs. This could increase the cost of the boat by nearly %20. Is it worth this much? If I were sailing the boat I'd want option 3 but the boat is not designed for my use so that is not relavent.How would the parents see this given they either find the extra time in building the craft or the extra money to buy such a craft. That is the real question. How does it balance out when the cost is taken into account? I appreciate all input and look forward to gaining a better understanding of how people see things.
Thanks, Phill
[Re: phill]
#125434 12/04/07 09:02 AM 12/04/07 09:02 AM |
Posts: 1,187 38.912, -95.37 | The question I have is - Are C/Bs worth, to the parents, an extra $1000 at least for their kids to have C/Bs over skegs. This could increase the cost of the boat by nearly %20. Is it worth this much? If I were sailing the boat I'd want option 3 but the boat is not designed for my use so that is not relavent.How would the parents see this given they either find the extra time in building the craft or the extra money to buy such a craft. That is the real question. How does it balance out when the cost is taken into account? I appreciate all input and look forward to gaining a better understanding of how people see things.
Thanks, Phill Phill, No! The potential of c/b case leakage, especially if the boat may be "accidentally" grounded a few times, is not worth the risk. Potential maintenance issues are bad "Dad...when are you going to fair MY boards?" "Yes, we like the boat except it leaks" To a new sailing family (and I believe this boat can attract total newbies) one (well...two) less item/s makes it that much more marketable. Keep it simple. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: phill]
#125435 12/04/07 09:28 AM 12/04/07 09:28 AM |
Posts: 9,582 North-West Europe | I found it pretty entlightning when I sailed and raced my F16 against a club member both when he had a Prindle 16 and a Blade F16. On the F16's we are now pretty evenly matched (him having had a season on the boat). When he was sailing his Prindle 16 he was always very close behind. If you made one or two mistakes then he would be along side you.
Yes a boardless cat will point a little lower then a boarded cat (except in very light winds where board don't do much at all, Andreas) but the difference in performance was surprisingly small. And we have to factor in that the Prindle 16 (deep V-ed hull) was both heavier and undercanvassed relative to the F16.
I now have some additional information about the sideways slip angle of both setup and the difference is only 2-3 degrees when going upwind and no difference on all other courses.
So my point here is why have daggerboards over skegs or deep V hull when the difference in performance is too small to really matter to the target group of kids/youths and their parents (who are not hardcore racing freaks). I mean what is 2min difference after a full hour of racing anyway ? A huge difference for Olympic sailors but all but negligliable for youths and their parents.
That leaves us the ease of tacking, but really seriously consider this a mute point as well for the following reasons. When you make a boat shorter it becomes dispropotionally easier to tack. This is easily proven by what many will call "useless mathematics". But if that doesn't interest you then do this experiment yourself. Get a long timber planck, hold it in water as a hull and try to turn it. Now cut the planck in halve and do it again. Notice how large the difference in resistance to turning is ! The difference is a factor of 4. And there are other reinforcing principles at work that make this ratio larger still.
Without going deeper into (mathematical and modelling) details I give you the final conclusion. By going to a 12 foot hull length and 65 kg platform weight with a kid as crew the resistance to turning the boat with respect to say an F18 is only 1/7th of the force related to the BOARDED F18's.
Of course the rudder area on the 12 foot will be smaller as well as will be the leverage it has, but even if we scale those as well then the difference factor is still at least a 1/2th.
How much more difficult will a deep V hull or hulls with skegs turn with respect to a round bottomed hull with daggerboards, a factor of 2 or maybe a factor of 3 (these are huge factors by the way). So if we simply entlarge the rudder of the 12 foot a little bit then we are garanteed to achieve parity in easy of tacking and turning with respect to the boarded F18 even when using skegs or deep V-ed hulls !
Now I can also make energetic comparisons showing that the Deep V or Skegged 12 foot hulls will not decellerated more then the F18 during a tack because of the above principles.
So ny final point is, how much more easily do we want the 12 foot to tack and turn, If a F18 feel is good enough then why justify the daggerboards ?
So my vote would go to the skegs or deep V-ed hull and normal kick-up rudders. And loose the large taper at the end of the rudder board. Just a small taper there will be enough.
[Re: _flatlander_]
#125440 12/04/07 10:17 AM 12/04/07 10:17 AM |
Posts: 1,307 Asuncion, Paraguay | The question I have is - Are C/Bs worth, to the parents, an extra $1000 at least for their kids to have C/Bs over skegs. This could increase the cost of the boat by nearly %20. Is it worth this much? If I were sailing the boat I'd want option 3 but the boat is not designed for my use so that is not relavent.How would the parents see this given they either find the extra time in building the craft or the extra money to buy such a craft. That is the real question. How does it balance out when the cost is taken into account? I appreciate all input and look forward to gaining a better understanding of how people see things.
No! The potential of c/b case leakage, especially if the boat may be "accidentally" grounded a few times, is not worth the risk. Potential maintenance issues are bad "Dad...when are you going to fair MY boards?" "Yes, we like the boat except it leaks" To a new sailing family (and I believe this boat can attract total newbies) one (well...two) less item/s makes it that much more marketable. Keep it simple. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> All agreed. But some things that sound complicated may actually be simpler and better choices than expected. Before dismissing the idea, I would like to list the features of a single centreboard pivoting from the central truss: - It needs no case, only lateral support (easy to build, access and maintain) - It is external to the hulls and independent from them (no leaks, safer, cheaper) - It helps right the boat (safe, fast and efficient righting pole style recovery) - It doesn't interfere with the boom or take deck space (easy to gybe, difficult to bruise inexperienced legs). - It is invisible both down and up (therefore not ugly). - It is cheaper and easier to build than a board in each hull (but Phill is the one who can confirm this). Another possible configuration change would be to replace the twin rudders with a single, deeper, daggerboard style rudder, also placed in the central frame. Depending on project specifications, this could further reduce the price and complexity, while still yielding a fast boat compared to #2. The central structure would concentrate about everything needed to sail the boat: rudder, centreboard and mast. It would look a lot like an Optimist or Laser with two hulls. I guess this could help parents feel comfortable with the idea of a cat trainer. What do you think?
Luiz
[Re: Stewart]
#125442 12/04/07 10:53 AM 12/04/07 10:53 AM | Anonymous
| Anonymous
Unregistered | LuiZ:
How would a single rudder work on a cat? It would have to be 6 feet long to stay in when you fly a hull! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Doug | | | Re: Kids Cats - Parents input requested.
[Re: ]
#125443 12/04/07 11:41 AM 12/04/07 11:41 AM |
Posts: 545 Brighton, UK | LuiZ:
Doug Not necessarily, with a central rudder when you fly a hull going upwind as the rudder comes out of the water the boat would luff up and so it could be a "safety feature" preventing you flying a hull too high. Gareth | | | Re: Kids Cats - Parents input requested.
[Re: grob]
#125445 12/04/07 12:01 PM 12/04/07 12:01 PM |
Posts: 548 MERRITTISLAND, FL | I like the single rudder and maybe single board idea, It may not be the right solution but it is something I would like to try.
It is much simpler, is familiar to a mono sailor and is cheaper.
Gareth Simple to use yes as there is only 1 Cheaper from a foil aspect also because there is only 1 of each as well. Cheaper as a whole -No - as you have to create mounting and deployment fixtures on the cross bars which before were simply a plain round tube. This complicates the platform considerably both for use and the build. | | | Re: Kids Cats - Parents input requested.
[Re: Stewart]
#125446 12/04/07 12:12 PM 12/04/07 12:12 PM |
Posts: 9,582 North-West Europe | no privately owned Waves or any M4.3s in Europe either.
I'm was told by a Hobie employee that they sell the wave here, but we haven't seen any boats on the water yet. I think the lionshare of the wave sales are to resorts.
The Wave had been around since when 1998 ? Up till now it hasn't caught on overhere as far as I can tell.
[Re: Luiz]
#125447 12/04/07 12:31 PM 12/04/07 12:31 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | But some things that sound complicated may actually be simpler and better choices than expected.
What do you think?
How 'bout barge boards...
2,694
guests, and 623
