| Re: Smaller sail for Hobie 16
[Re: mako]
#127175 12/31/07 09:53 AM 12/31/07 09:53 AM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | I believe the mast is a different height, however I am not sure as to all the differences.
I think the different height mast would cause the most problems as it would not have the "catch" for the shorter sail.
I know that my comp tip mast does not have the bottom "halyard catch" (probably the wrong term) for when the sail is reefed. Apparently the older non-comp tip masts have a second catch.
From what I understand, reefing the sail should depower it quite a bit? Have you tried it with a reef, yet?
Cheers, Ryan
[Re: mako]
#127178 12/31/07 04:17 PM 12/31/07 04:17 PM |
Posts: 1,187 38.912, -95.37 | Anyone have any comments on sailing a 16 with reefed sail? Yup, raced once with a reefed main in 35mph and gusting stuff. Boat was very controlable, able to drive upwind with only me (175#) single trapped. Crew was on tramp with both hands holding the un-cleated jib, and there's the problem in too much wind...a cleated jib and a strong gust will knock over a 16 <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
[Re: _flatlander_]
#127179 01/01/08 03:09 PM 01/01/08 03:09 PM |
Posts: 493 Minnesota | I've always been reluctant to reef. I would like to try it, but then I get concerned about the sail. Looking at the reef grommets in the sail, I'm concerned the stress at those limited points could be damaging to the sail, if done frequently. -So why get into a habit that may damage the sails ? Am I being a scaredy cat ?
[Re: CMerrell]
#127182 01/02/08 08:53 AM 01/02/08 08:53 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | When you reef a Hobie 16 sail, you also have a shorter foot length and, basically, a loose foot. It's just a matter of tying down the clew to the boom and pulling it tight with a line to the end of the boom. Wouldn't matter that it is shorter than the boom, would it? The fact that the Hobie 16 HAS a boom is what would make it possible to use a smaller sail. No? | | | Re: Smaller sail for Hobie 16
[Re: Mary]
#127184 01/03/08 08:46 AM 01/03/08 08:46 AM |
Posts: 206 Virginia USA | When you reef a Hobie 16 sail, you also have a shorter foot length and, basically, a loose foot. It's just a matter of tying down the clew to the boom and pulling it tight with a line to the end of the boom. Wouldn't matter that it is shorter than the boom, would it? The fact that the Hobie 16 HAS a boom is what would make it possible to use a smaller sail. No? We may be talking two different scenarios. I assumed the H16 boom would not be used with a Wave sail. In that case, the main sheet would attach to the clew and, given that the foot of the Wave sail is shorter than a H16 sail, the sheets would angle forward and tend to tension the leech more than the foot. I think you are suggesting using the Wave sail and attaching it to the boom in some fashion. I agree that would function similar to a reefed down H16 sail. However, since the H14 and H16 mains are so similar (e.g. have a foot rope, use the same boom extrusion), I think a H14 sail would make the "neatest" set up. I have not used a H16 sail with reef points in many years and my experience with the Wave is limited so my discussion is all theoretical. Some real world results would be interesting. | | | Re: Smaller sail for Hobie 16
[Re: mako]
#127185 01/06/08 08:24 PM 01/06/08 08:24 PM |
Posts: 471 NC | Pamlico sound if full of sailboards and kites when the wind is 20mph. I would like to be out there but a full sail 16 would not be my first choice. Keep using the full size sail, find a heavier crew and don't be scared to push the boat. Make those sailboarders and kiters realize what they're missing. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> | | | Re: Smaller sail for Hobie 16
[Re: mako]
#127189 03/01/08 06:36 AM 03/01/08 06:36 AM |
Posts: 61 | I have a hobie 16 main easy junior. It is like the hobie easy sail but only goes to the reefing point and doesnt use the boom. I am never use it. It has only been used 3 times. I would sell it if you want. I am in UK but could ship it. Also have a small soft jib (no battens.)
Stealth F16 The Black Pig
[Re: mako]
#127190 03/14/08 05:14 PM 03/14/08 05:14 PM |
Posts: 251 beaufort, sc | i have an older, reefable main and i use it when i'm sailing solo. i weigh about 160. if its blowing 20 or over, i leave the jib on the beach and sail 'uno style'. i started with a h 14 so tacking without the jib is not a problem, actually easier than a 14 'classic' because the 16's extra weight helps shoot through the tack. theres plenty of performance available for me with the reduced rig, hull flying is easy and predictable. if you reef properly i dont think theres any extra strain on the sail, the reef points are tied just tight enough to keep the foot from flapping around. the loads are on the halyard, tack, and outhaul.
marsh hawk
[Re: CMerrell]
#127192 05/05/08 08:39 AM 05/05/08 08:39 AM |
Posts: 40 Florida | IMHO the ideal solution would be a H14 sail on a H16 boom. That solves downhaul/outhaul/sheeting angle problems. The stock halyard could be extended with a wire rope pigtail. You are exactly correct. I used to do this years ago when I sailed both a 16 and a 14. Now I sail a Hobie 17 and the 17 sail is a perfect fit on the Hobie 20 with a halyard pigtail.
Kathryn Garlick
Evolution, 28R, #185
[Re: mako]
#127193 05/05/08 08:56 AM 05/05/08 08:56 AM |
Posts: 40 Florida | I am going to look for a 14 sail and give it a try. I would buy the sail and boom for a dedicated setup if I can find one. All you need is the 14 sail and a pigtail on your halyard. I don't know that a 14 boom would work well because of sheeting angles. A 16 boom works well with a 14 sail.
Kathryn Garlick
2,582
guests, and 492
