| used A's #127428 01/01/08 03:08 AM 01/01/08 03:08 AM |
Joined: Feb 2005 Posts: 4,119 Northfield Mn Karl_Brogger OP
Posts: 4,119 Northfield Mn | Ok I know this is a really loaded/vague question.
What would one expect for an older A cat in decent condition? Something in good shape but maybe not technoligically "competitive" anymore?
| | | Re: used A's
[Re: Karl_Brogger]
#127429 01/01/08 09:31 AM 01/01/08 09:31 AM |
Posts: 1,226 Atlanta | I'm assuming you mean a older style Acat that is minimum weight and has a carbon mast? You can find these from between $3 and $12k, depending on age, and how they've been used. All glass older boats are less, as they can get soft over time, kevlar and carbon boats hold up better over time, so expect to pay more. Older Catnip style Acats with aluminum masts can be found for $2-$5k. I saw a boat that Steve Clark built and sailed in the worlds (not the recent worlds) with a carbon hall mast for $3k in RI, nice boat, carbon daggers, rudders. It was about 5k over weight, but the daggers were solid and you could easily get the weight out of the daggers. This boat was at Sail Newport, dont know what happened to it. Also, the Lake Hopatcong guys have a bunch of older catnips, some are projects, but you might get them to part with one of those boats. They use these to introduce people into the class. The other option is to build your own, I spend $11k on my boat, and its a current design. Check here, lots of newer onew for sale now that the worlds is over. http://www.usaca.info/ Bill | | | Re: used A's
[Re: davefarmer]
#127432 01/01/08 12:22 PM 01/01/08 12:22 PM |
Posts: 902 Norman,OK | I am really interested in buying an older A-cat also. I went as far to post an add on the A-cat website. Something around 2-3K.
If anyone has a line on one tell me!
| | | Re: used A's
[Re: davefarmer]
#127434 01/01/08 01:15 PM 01/01/08 01:15 PM |
Posts: 6,049 Sebring, Florida. | I think the A's need to start a new division, something like "Vintage A's" or some such. The boat must be 15 years old or older, And something affordable would be nice. By affordable I mean less than $5,000, which is all I can justify paying for two glass (or wood) hulls, an aluminum mast and one sail. The new all carbon boats out there now, at $30,000, are way beyond my reach.
One of the more popular motor sports car racing classes is the "Vintage Class", apply the same concept to A cats.
Blade F16 #777
| | | Wrong on Price Timbo
[Re: Timbo]
#127436 01/01/08 04:53 PM 01/01/08 04:53 PM |
Posts: 395 LA | The new all carbon boats out there now, at $30,000, are way beyond my reach. A new Vectorworks XJ or Alien sailaway is around $21K. Same for the A3 which is back in production completely under Melvin and Morelli (no more Performance Catamaran involvement). Any boat imported into the US is high right now because of the weak dollar but new Gel Tek's were selling at the Worlds for $25K to $26K, not $30K. The boat is still expensive but keep in mind most are all carbon construction (beams, foils, mast, hulls) or have kevlar hulls. Glass boats are just not being built, too wiggly. Apparently the price is not killing the class because it is still growing in the US. Bob Hodges USACA | | | Re: Wrong on Price Timbo
[Re: Acat230]
#127437 01/01/08 04:58 PM 01/01/08 04:58 PM |
Posts: 6,049 Sebring, Florida. | Thanks for the correction Bob, but $21K, plus trailer, plus box, plus wheels, plus... is still way out of my range for a singlehander. If there were a Vintage A class, for a lot less money, well...maybe.
Blade F16 #777
| | | Re: used A's
[Re: Karl_Brogger]
#127439 01/01/08 07:59 PM 01/01/08 07:59 PM |
Posts: 1,383 Kingston SE South Australia | My guess is you will probably get a MK3 for not much more than the older types with the probable advantages of modern mast Decks are clear ( this is a big thing ) modern centreboards modern rudders with kickup modern curve and design of traveller looks relatively modern Rockers on some older models are forward more so have to have extra long tillerbar and hike way forward. ( this may suit you more if you are going out through surf ) Rounded hull making tacks easier and faster. Should be around weight I purchased my older A as a second boat and wouldn't hesitate to do it again regards
[Re: Karl_Brogger]
#127440 01/02/08 09:40 AM 01/02/08 09:40 AM |
Posts: 3,116 Annapolis, MD | This just may be my perception but it seems that the A Class is probably the second strongest class in the US despite the large price tag. What is the basis for your opinion?
crac.sailregattas.com
| | | used A's
[Re: Mark Schneider]
#127441 01/02/08 10:01 AM 01/02/08 10:01 AM |
Posts: 4,119 Northfield Mn | What is the basis for your opinion? Just looking at national and worlds attendance. Didn't the worlds in Florida limited to 200 boats? Nationals seems to have really good turnouts as well. Only the H16 has a similar turn out. Oops. 98 boats competing. Just found the thread Still a ton of boats in one place.
[Re: Karl_Brogger]
#127442 01/02/08 10:38 PM 01/02/08 10:38 PM |
Posts: 395 LA | This just may be my perception but it seems that the A Class is probably the second strongest class in the US despite the large price tag.
Do these boats typically come with sails new? Just curious. I have been in the class since 2001 and from my perspective, we've seen steady growth. Different areas seem to have growth spurts at different times and some areas the boats just don't seem to catch on for whatever reason (Florida panhandle a good example). In terms of positive growth, the Pacific northwest, a resurgence on the west coast, the Annapolis area, and most recently the Tampa Bay area have been shining stars. In terms of regatta attendance, the NAC gets good attendance when it is more centrally located even though the strong growth of attendance for the midwinters and the recent WC seems to blow that theory (the venue in Islamorada is a strong pull). This year we had 110 paid up members in the US class association. Over 100 sailors took part in the US district qualifying series that was used to start seeding out the allocations for the WC. Times are good, I hope we can keep the momentum going and keep sales up for our excellent builders and suppliers (Hall Spars, Morelli and Melvin, Vectorworks, Guck, Inc)in this country. Bob Hodges USACA | | | Re: Wrong on Price Timbo
[Re: Acat230]
#127443 01/03/08 10:39 AM 01/03/08 10:39 AM |
Joined: Jun 2001 Posts: 75 Ljubljana, Slovenia mayhem
Posts: 75 Ljubljana, Slovenia | A-class is for sure a great boat-- expensive, but so are the 2 handed heavyweights. I just turned 40. I see all my friends who had Nacra6.0s in their late 20s and 30s, have jumped to A-cats: - They have better jobs and can afford A-cats (even as the price escalates) - They have less time and want boats that need less setup and not not need more people as crew. - They love the idea that crew weight and general fitness are no longer key differentiators.
Our fleet is nearly 100% Bim2000s (fiberglass, minimum weight, carbon rig). For my money, carbon mast is a "must have" and unfortunately one of the most expensive and delicate parts of the boat. Other parts such as sails are often cheaper than class (Hobie, Nacra) boats because of their lighter weight and strong competition in the market. Fiberglass hulls are still made by Bimmarree (but not Vectorworks-- the USA producer of the same boats). Even though they have the same shape and weight, few buy them-- carbon boats stay stiffer longer and how can you spend so much money and not get the "cool material" all around (it is like ordering a BMW M5 without the alloy rims)
Bottom line: 1999-2002 Bimm/Vectorworks or Boyer/Flyer with Carbon mast is regularly sailed condition is a great entry level boat. For $1500 more, you could probably get a 2001-2004 similar boat with carbon hulls and still have an affordable entry level boat. Older, wooden or very cheap A-cats may not be such a good deal because their ultra lightweight constructions means they do not hold up well to long term abuse-- high risk you spend too much time and money keeping it on the water. (it is not like rescuing an old Hobie 16)
Finally, despite a wildly fantastic A-class world championship, few people attending/watching were buying boats after/during like previous years so I heard. I suspect the lack of a new dominant design/technology combined with the fact that most A-class boats in the USA are already carbon/carbon and holding up well combined with Euro/$USD sticker shock.... IMHO With continued, increasing class interest, this could start making entry boats expensive as new supply of used boats slow down. I would not wait for better deals if I found a good entry level boat at a fair price. | | | Re: Wrong on Price Timbo
[Re: mayhem]
#127444 01/03/08 11:11 AM 01/03/08 11:11 AM |
Posts: 3,348 | - They love the idea that crew weight and general fitness are no longer key differentiators.
You are in for a pleasant surprise (I hope!) While I don't own an 'A' yet, I think fitness will be as necessary as it is on the F16. And that's a good thing. | | | A-cat fitness levels
[Re: fin.]
#127445 01/03/08 02:17 PM 01/03/08 02:17 PM |
Posts: 75 Ljubljana, Slovenia | The old Nacra 6.0NA in Worrell-1000 configuration required a heavy hot stick to fight the rudders, 2:1 systems for massive spinnakers, and a mainsheet that regularly required so much tension that exploding bolts on the high end haarken slides push many of us to switch to titanium bolts when sailing in the strong stuff.
On the other hand, my mother could steer and A-class (if I could strap her into the boat without the police arresting me as she screamed). It is lightweight, nimble, and sensive to the lightest pressure. Downwind, when I overheat, my Bim2000 punches into waves and usually slows down-- the Nacra would carry so much momentum that it would dive like scenes in the movie Das Boot. The A-class still likes tension on the mainsheet, but the carbon mast is more responsive so you don't need to be so cruel to the boat.
Don't get me wrong. The A-class is not for the Benetau 42 crowd. You need enough fitness to get on and off the wire quickly (very quickly-- it is simply un-sailable without using a trapese9. And you need even more flexibility since the boat is smaller. You move more like a dancer and less like a rugby player. When I entered regattas out of practice or in bad physical shape on a Nacra 6.0, I would get injured. On an A-class, I usually injure the boat first.
buy and A-cat, you'll will love it.
| | | Re: A-cat fitness levels
[Re: mayhem]
#127446 01/03/08 04:26 PM 01/03/08 04:26 PM |
Posts: 1,383 Kingston SE South Australia | My Stingray has the same height mast as my A, with heaps more sail area and a lot more feeling of power. What amazes me with the A is I am looking at quad blocks to handle that last couple of inches of sheet tension wheras I don't have that problem with the Stingray. In a bit of a blow with waves on the A, I'm constantly playing the last bit of main sheet and finish the day much more tired. regards
[Re: JeffS]
#127447 01/03/08 05:56 PM 01/03/08 05:56 PM |
Posts: 271 Atlanta, Ga | I would rather move like a rugby player than a dancer any day | | |
2,593
guests, and 166
