| Re: Beach Wheels..PSI?
[Re: mbounds]
#127608 01/03/08 12:52 PM 01/03/08 12:52 PM |
Posts: 12,310 South Carolina | Mine have a PSI rating on the sidewall and they say 10psi max. They are hard as a rock at that point, you can certainly do with less.
Jake Kohl | | | Re: Beach Wheels..PSI?
[Re: RickWhite]
#127611 01/04/08 12:55 PM 01/04/08 12:55 PM |
Posts: 145 Cheshire, UK | I've also found that the glue holding the valve in its rubber sleeve can rot after a year or so - so there'll come a time when you try to remove the dust caps and end up pulling out the valves. A solution is to grease the dust cap threads before ftting, and to keep the pressure low to avoid a "blowout" (5 psi works for me). I found that rubber solution glue does not set, but it offers enough resistance to stop the valve popping out at a low pressure.
Of course, you can replace the valves (or tubes) periodically, but this solution will work when disaster strikes at the start of a sailing day.
Simon Shadow 067 | | | Re: Beach Wheels..PSI?
[Re: RickWhite]
#127614 03/05/08 09:10 PM 03/05/08 09:10 PM |
Posts: 471 NC | Both Euro Trax and Cat Trax have always lost air. Finally I discovered a solution. Tubes! I had the local garage at Put-in-Bay install the tubes and they are always ready to go.., with no hand pump work required. Works great. We now sell them on our store at www.OnLineMarineStore.comRick What section of the OnlineMarineStore are the tubes sold under? I'm trying to get my trax ready for the season and a tube is looking like the best way to go. | | | Re: Beach Wheels..PSI?
[Re: drbinkle]
#127615 03/05/08 09:21 PM 03/05/08 09:21 PM |
Posts: 3,224 Roanoke Island ,N.C. | I looked all through the on-line store and couldn't find them either. Where dey at? Todd
| | | Now: repair
[Re: David Parker]
#127617 03/06/08 02:33 PM 03/06/08 02:33 PM |
Posts: 35 | I put tire repair goop in my tires. The first time I did it was maybe 10-12 years ago. Last year they started leaking again, and I put in some more. I think I've added air once since then. I used Slime brand this time. It claims to seal holes 1/4" in diameter. We put some in one of our club's trailer tires that I thought it would never seal. One large ball of green slime flew out of the tire, then it was sealed. http://www.slime.com/John | | | Re: Now: repair
[Re: John_C]
#127618 03/06/08 05:20 PM 03/06/08 05:20 PM | Anonymous
| Anonymous
Unregistered | I just filled my tires with concrete. Now they never go flat. Of course it takes 4 of us to push them up the beach... but they aren't flat! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | | Re: Now: repair
[Re: ]
#127619 03/06/08 06:18 PM 03/06/08 06:18 PM |
Posts: 35 | I just filled my tires with concrete. Now they never go flat. Of course it takes 4 of us to push them up the beach... but they aren't flat! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> I put about 8 ozs of repair goo in each tire, so about 1 pound total. Since a bicycle tube can weigh close to 0.5 lb, I would guess installing the inner tubes would add at least 1 lb and probably closer to 2 lbs. John | | |
1 registered members (Talus1),
680
guests, and 163
