Beach Wheels..PSI? #127605
01/03/08 12:20 PM
01/03/08 12:20 PM
TurboCat Offline OP
TurboCat  Offline OP
I bought a set of used beach wheels for my Nacra 500 and was wondering what kind of PSI you guys put in them. I dont want to pop one due to too much air pressure(kind of expensive). I bought the smooth tire, red wheels, adjustable cradles.
Not a big deal...Just wondering what the normal PSI was.
Re: Beach Wheels..PSI? [Re: TurboCat] #127606
01/03/08 12:36 PM
01/03/08 12:36 PM
8-10 psi
Re: Beach Wheels..PSI? [Re: TurboCat] #127607
01/03/08 12:40 PM
01/03/08 12:40 PM
There should be a "Max Circumference" listed on the sidewall of the tire.
I vaguely recall my CatTrax having a max circumference of 64 inches.
It doesn't take much pressure to get there. I think 8 - 10 psi might be high.
Re: Beach Wheels..PSI? [Re: mbounds] #127608
01/03/08 12:52 PM
01/03/08 12:52 PM
Mine have a PSI rating on the sidewall and they say 10psi max. They are hard as a rock at that point, you can certainly do with less.
Re: Beach Wheels..PSI? [Re: Jake] #127609
01/03/08 12:55 PM
01/03/08 12:55 PM
Bottom line - go with what's printed on the sidewall.
Re: Beach Wheels..PSI? [Re: Jake] #127610
01/04/08 10:01 AM
01/04/08 10:01 AM
RickWhite Offline
RickWhite  Offline
Both Euro Trax and Cat Trax have always lost air. Finally I discovered a solution. Tubes! I had the local garage at Put-in-Bay install the tubes and they are always ready to go.., with no hand pump work required. Works great.
We now sell them on our store at www.OnLineMarineStore.com
Rick
Rick White
www.onlinemarinestore.com
Re: Beach Wheels..PSI? [Re: RickWhite] #127611
01/04/08 12:55 PM
01/04/08 12:55 PM
Cheshire, UK
Simon Offline
Simon  Offline
Cheshire, UK
I've also found that the glue holding the valve in its rubber sleeve can rot after a year or so - so there'll come a time when you try to remove the dust caps and end up pulling out the valves. A solution is to grease the dust cap threads before ftting, and to keep the pressure low to avoid a "blowout" (5 psi works for me). I found that rubber solution glue does not set, but it offers enough resistance to stop the valve popping out at a low pressure.
Of course, you can replace the valves (or tubes) periodically, but this solution will work when disaster strikes at the start of a sailing day.
Simon
Shadow 067
Re: Beach Wheels..PSI? [Re: Simon] #127612
01/04/08 11:31 PM
01/04/08 11:31 PM
brucat Offline
brucat  Offline
Rick, you are SO right! Same thing happened to my lawn tractor (OK, hold the redneck jokes)...
I've often wondered why they were always promoted as "tubeless" like that is supposed to magically be better than tires with tubes? Is that just marketing trying to get us to fall for something that costs the manufacturer less to produce?
Re: Beach Wheels..PSI? [Re: brucat] #127613
01/05/08 12:46 AM
01/05/08 12:46 AM
Actually a tubed tire is more likely to fail. Virtually nothing runs tubes. But a good fix for a low stress application like this.
Re: Beach Wheels..PSI? [Re: RickWhite] #127614
03/05/08 09:10 PM
03/05/08 09:10 PM
NC
drbinkle Offline
drbinkle  Offline
NC
Rick
What section of the OnlineMarineStore are the tubes sold under? I'm trying to get my trax ready for the season and a tube is looking like the best way to go.
Re: Beach Wheels..PSI? [Re: drbinkle] #127615
03/05/08 09:21 PM
03/05/08 09:21 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
I looked all through the on-line store and couldn't find them either. Where dey at?
Todd
Isak Dinesen
E. B. White
Re: Beach Wheels..PSI? [Re: Team_Cat_Fever] #127616
03/06/08 08:15 AM
03/06/08 08:15 AM
Dunedin Causeway, FL
David Parker Offline
Go to Rick's Store.
Search for "tubes". Be sure to use "tubes" and not just "tube".
Otherwise, just go here.
Cat Trax tubes
Hey Rick, will these tubes work in EuroTrax?
Now: repair [Re: David Parker] #127617
03/06/08 02:33 PM
03/06/08 02:33 PM
John_C Offline
John_C  Offline
I put tire repair goop in my tires. The first time I did it was maybe 10-12 years ago. Last year they started leaking again, and I put in some more. I think I've added air once since then. I used Slime brand this time. It claims to seal holes 1/4" in diameter. We put some in one of our club's trailer tires that I thought it would never seal. One large ball of green slime flew out of the tire, then it was sealed.
http://www.slime.com/
John
Re: Now: repair [Re: John_C] #127618
03/06/08 05:20 PM
03/06/08 05:20 PM
I just filled my tires with concrete. Now they never go flat. Of course it takes 4 of us to push them up the beach... but they aren't flat! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Now: repair [Re: ] #127619
03/06/08 06:18 PM
03/06/08 06:18 PM
John_C Offline
John_C  Offline
I put about 8 ozs of repair goo in each tire, so about 1 pound total. Since a bicycle tube can weigh close to 0.5 lb, I would guess installing the inner tubes would add at least 1 lb and probably closer to 2 lbs.
John
