| Re: Spin pole setup.
[Re: dacarls]
#13112 03/08/05 03:56 PM 03/08/05 03:56 PM |
Dave,
There is no advantage to the M20/M18 setup. The double bridle setup when flying a spi is not very nice. It tends to foil up manouvres with the spi. Best for spi sailing is the single forestay with a bridle setup. When you do this then the traditional spi pole setup with lines is easiest, cheapest and best.
| | | Re: Invention ideas??
[Re: thetudor]
#13114 09/30/05 01:47 PM 09/30/05 01:47 PM |
Joined: Jun 2004 Posts: 141 Panama City Beach, FL steveh
Posts: 141 Panama City Beach, FL | 1. I built a box that we put on the rear crossbar of our Nacra 6.0 to help us raise the mast. It is approximately 28" high, and when the mast is connected to the ball at the base, it gives a much better angle to start lifting the mast from.
2. I installed a temporary gin pole on the trailer between the front crossbar and the mast support. This allows for a better angle for raising the mast using the trailer winch.
3. I also built a light bar which hangs from the 6.0 rudder castings so the trailer lights can be easily removed for either trailer launching or just to prevent mechanical damage.
That's all I can think of right now. I know this is a revival of a revival, but I'd love to see pics of 1 and 2. A gin-pole/A-frame/ angle-improver setup is relatively easy to work out. My problem is how to slide a 31ft mast out past the rear crossbeam and support it with it turned 90 degrees to get it onto the ball and then limit the mast turning back straight until the downhaul is clear as it's lifted with a winch/gin-pole arrangement. Working on the non-"chicken float" chicken float. Some time in a wind tunnel sure would help. | | | Re: Invention ideas??
[Re: steveh]
#13115 09/30/05 02:58 PM 09/30/05 02:58 PM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | Here is an idea that was suggested to me by an "old Salt" but I haven't tried it .....yet. It makes some sense since I too, have the type of mast that requires a 90 degree turn. He thought I should rivet another tang on the side of the mast (so that the pull would naturally turn the mast 90 degrees) and abandon the forestay as what I attach to the winch. I haven't done it yet because I don't want to drill more holes in the mast # 1 and # 2 I haven't figured out how I would attach a line to the tang that didn't have to be left in place while I was sailing. For holding the mast in place at 90 degrees I just fabricated a PVC pole with a "V" on top and bottom that rests on the ground but holds the mast on its side 6 feet off the ground behind the rear beam. I use the pole to help lift the mast while my helper cranks the winch. With the 6 foot pole I can lift it high enough without having to climb onto the tramp.
Let me know if you can think of another/better way. I'm all ears.
Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: Invention ideas??
[Re: BobG]
#13118 09/30/05 06:23 PM 09/30/05 06:23 PM |
Posts: 2,921 Michigan | That'll be the best 400bucks you ever spent. yeah, I know... but if I were to buy new ones now the total cost would be something like 700$!!!!  my stupidity for not getting new ones to start with, but still. | | | Re: Invention ideas??
[Re: PTP]
#13119 09/30/05 09:47 PM 09/30/05 09:47 PM |
Posts: 324 South Florida | How about a telescoping mast? That would certainly make set up soooo much easier! Has anyone ever tried this??
Fred F
(ex Hobie 18)
[Re: BobG]
#13122 10/01/05 07:31 AM 10/01/05 07:31 AM |
Posts: 2,074 Northfield,NH USA | Hydraulic or Telekinetic? Now THAT'S funny!  Why not Virtual?
[Re: bullswan]
#13123 10/01/05 08:37 AM 10/01/05 08:37 AM |
Posts: 324 South Florida | How about mechanical. It could have a system of blocks and pulleys inside and a line you pull on the outside to telescope it to its full length and then to release it. I wonder if anyone has tried something like this. It would certainly be an expensive mast, (and heavier also).
Am I wrong or do they have a cat with telescoping crossbars to increase beam?
Fred F
(ex Hobie 18)
[Re: SOMA]
#13124 10/01/05 08:47 AM 10/01/05 08:47 AM |
Posts: 324 South Florida | Although telekinetic WOULD be the best!  Heck!! I wish I could make the entire set up Telekinetic! That would certainly draw people to catamaran sailing! IN FACT THAT'S IT!!!! THE FIRST GUY THAT INVENTS THE FIRST TELEKINETICALLY SET UP CATAMARAN WILL MAKE MILLIONS!!!! I can't do it. My ears start smoking when I try!
Fred F
(ex Hobie 18)
[Re: BobG]
#13126 10/02/05 08:08 AM 10/02/05 08:08 AM |
Posts: 805 Gainesville, FL 32607 USA | Take a look at the WaterWorld movie again if you need sailing ideas. Lots of nifty telekinetic stuff there- except the non-sailing part of the flick that was Hollywood crap. I heard Randy Smyth did some of the sailing bits.
[Re: hrtsailor]
#13127 10/02/05 08:28 AM 10/02/05 08:28 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | With all the talk about having a float "Bob" on the top of the mast, why not an inflatable float on the top with tubing down to a CO2 cartridge or inflation device that you trigger if the boat goes over. You could deflate it after you right the boat.
Howard There was a system like this. Inflatable ball at the top,tubing and co2 cartridge at the bottom. I don't think it was auto though.
[Re: catman]
#13128 10/02/05 10:04 AM 10/02/05 10:04 AM |
Posts: 2,074 Northfield,NH USA | Someone even posted an advertisement selling the device. I think today it could be automatic because they have the life vests that open on contact with water. Here is a thought...... IF the top of the mast had a foil as Mike Catley proposed and IF the ends of the foil had this inflation device would it not be able to lift the entire mast out of the water and get it to that critical spot where the boat is tipped enough to make righting that much easier?????? What I mean to say is that the wind would be able to affect the lifting of the sails and the hulls would be tipped to at least perpendicular to the water surface so in theory wouldn't that make the craft VERY easy to right? Would that not be another selling point??
Greg
4,145
guests, and 742
