repairing a hole #132302
02/19/08 01:06 AM
02/19/08 01:06 AM
Camden NSW
wildtoy Offline OP
wildtoy  Offline OP
Camden NSW
Hi all,
On the w/e I put a small crack in one of my hulls just behind the main bulkhead.
I was just wondering how ppl would repair this.
I was going to put filler/hardener over it then place a bit of fibreglass tape over it.
Any ideas would help.
cheers
William
Re: repairing a hole [Re: wildtoy] #132303
02/19/08 01:15 AM
02/19/08 01:15 AM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
William,
I would glass both inside and outside or it will just crack again.....and depending on size I would initially open up the crack slightly and glue it before glassing it.
The outside may need to be sanded back so that when it is glassed it is fair with the hull
And do use Epoxy resin and glue (Bote Cote, Epiglass or similar) as the polyester will fail in time.
DKD
"Banh Sidhe"
Re: repairing a hole [Re: dkd] #132304
02/19/08 01:19 AM
02/19/08 01:19 AM
Camden NSW
wildtoy Offline OP
wildtoy  Offline OP
Camden NSW
**** of the bay regatta next week at kcc, So cutting a port hole aint an option yet.
Will
Re: repairing a hole [Re: wildtoy] #132305
02/19/08 07:16 AM
02/19/08 07:16 AM
Peter_Foulsum Offline
Will,
How did you crack it ? Not a stress fracture I trust. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
Your hulls are timber aren't they ?
If a stress crack drill out the end of the crack so that it won't continue. Open up the crack and fill with high strength epoxy and fibreglass tape over the top. Fair it off with filler when you have more time.
Peter
Mosquito 1814
Macka Mozzie
Re: repairing a hole [Re: Peter_Foulsum] #132306
02/19/08 01:29 PM
02/19/08 01:29 PM
Camden NSW
wildtoy Offline OP
wildtoy  Offline OP
Camden NSW
Hi Peter,
Its not a stress crack. The crack went right through.
I did it trying to get onto the hull to right it.
Will
Re: repairing a hole [Re: wildtoy] #132307
02/21/08 12:41 AM
02/21/08 12:41 AM
RedAlert Offline
RedAlert  Offline
Hi Will,
Jim Boyer's method to repairing holes in timber mozzies goes like this:
1. take an angle grinder to it and bevel the edge of the hole to about a centimeter or more all around.
2. wet the bevelled edge with resin.
3. lay fibreglass tape over the hole and on the bevelled edge, as much of the bevelled edge as possible.
4. brush resin over the tape.
5. fill the hole with a fibre glass filler - he recommends the west system of "microfibre blen gap filler (403)". This is mixed into the fibre glass resin till it is of a consistency desired, and then used to fill the hole.
6. leave a bit too much and sand it down later.
I have used this method and am really pleased with the results.
Jim says it is stronger than the original ply.
Hope it goes well.
Keith
Yesterday at 09:43 PM
