| Questions from a possible F-16 buyer #132754 02/21/08 10:50 PM 02/21/08 10:50 PM |
Joined: Feb 2008 Posts: 3 Toronto, Ontario canuck001 OP
Posts: 3 Toronto, Ontario | I have been sailing all my life, though mostly recreationally - very little racing. I grew up sailing sunfish and lasers. I raced Albacores and also sailed a Flying Junior as a teenager. In my twenties I windsurfed alot. And when then kids came along, we bought a laser which has given us years of enjoyment. Along the way I had a chance to briefly sail a few catamarans - a Super 17, and older Dart, and a strange little thing called an Aquacat. But in total, my catamaran sailing experience might total 3 hours. I am a bit of a speed freak, and the Laser has never quite satisfied my appetite for speed the way that my windsurfer did.
Apart from speed, the real draw of the F-16 for me is its light weight, its flexibility (1-up or 2-up), and its moderate cost (compared to an A-class). My ususal sailing partner would likely be my wife or one of my kids, so total weight would be 260-340 lbs.
My questions are as follows:
1) Would my background make me a reasonable candidate for an F-16 sailor, or is this too much boat for me.
2) My patience for a boat that requires endless setup time is limited. If you have a place to keep the boat close to the water with the mast up, how long would it take to rig an F-16 (mostly likely looking at the Blade), with or without the Spn. What if you were starting from scratch, rigging the boat from a trailer.
3) Some places I sail have shoals. How durable is are the hulls on the F-16, what would likely happen if you ran aground at a reasonable speed.
4) Which options - Pentex sails, Kevlar hulls, carbon mast, etc. are most worthwhile.
5) Safety and Pitchpoling. In my one experience on a Super 17, a near pitchpole sent me (out on the trapeze) flying forward. I ended up underneath the tramp (still on the wire) after whacking my head on the forward beam. Strikes me as it could have been a bad situation. This was in the late 1980s. Have trapezes evolved since that time to stop this kind of thing from happening?
6) Are there any F-16s in Canada or in Toronto. I realize the class is still new and I dont mind being the first, but company would be nice.
7) Finally, it is a short season up here and Lake Ontario never really warms up. Compared to a laser, or other beach cats, how wet a ride is the F-16.
Thanks for your help. Hope to be an owner within 6 months. | | | Re: Questions from a possible F-16 buyer
[Re: canuck001]
#132756 02/22/08 02:41 AM 02/22/08 02:41 AM | Anonymous
| Anonymous
Unregistered | I have been sailing all my life, though mostly recreationally - very little racing. I grew up sailing sunfish and lasers. I raced Albacores and also sailed a Flying Junior as a teenager. In my twenties I windsurfed alot. And when then kids came along, we bought a laser which has given us years of enjoyment. Along the way I had a chance to briefly sail a few catamarans - a Super 17, and older Dart, and a strange little thing called an Aquacat. But in total, my catamaran sailing experience might total 3 hours. I am a bit of a speed freak, and the Laser has never quite satisfied my appetite for speed the way that my windsurfer did.
"I also spent lots of time sailboarding, I find sailing under spinnaker a similar experience, so I think you will like it, a big challenge like learning sailboarding. I sold my previous F16 "Altered" to a guy with similar experience, he is enjoying it and doesn't mind crashing and burning to learn."
"Hard stand 10mins. From trailer 60 mins with yack time."
"Don't run aground! Damage to centreboards and centreboard cases is likely if you do."
"If sailing one up I would go with all options mentioned. make sure mast is above minimum weight and it is strong enough."
"There are quick release trapeze harnesses available, but in my 40 years of sailing I have only seen one person caught in the situation you describe. After a while you become expert at crashing?"
"Don't know, but if you have any other cats with spinnaker or A's around you have company at the front of the fleet."
"I have found the F16 Blade dryer than other cats I have sailed."
[Re: ]
#132757 02/22/08 06:07 AM 02/22/08 06:07 AM |
Posts: 9,582 North-West Europe | "If sailing one up I would go with all options mentioned. make sure mast is above minimum weight and it is strong enough."
The alu mast die is widening a little due to frequent use and the newer batches of masts are slightly heavier, stronger and stiffer as a result. Basically, you won't have to worry about this aspect at all. The lighest masts held up great and it is impossible to expect the slightly heavier masts to be less durable. Wouter
[Re: ]
#132759 02/22/08 12:57 PM 02/22/08 12:57 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | Just one point about Alloy masts and I don't want to steal this thread but Alu hasn't changed for basically the last forty years but Carbon has come on leaps and bounds in the last twenty so to say the Alu is more robust isn't quite true!! and as for costs if by any chance my Carbon mast did fail it would be a hell of a lot CHEAPER for me living in the UK to purchase a JP Carbon mast than to import an Alloy Superwing from Australia. There we go I've said my bit about Masts as for the rest of a F16 I can guarantee you would not have any second thoughts after sailing one. MP*MULTIHULLS | | | Re: Questions from a possible F-16 buyer
[Re: Gilo]
#132761 02/22/08 02:02 PM 02/22/08 02:02 PM |
Posts: 915 Dublin, Ireland | My dad is 60 and has been sailing for 10 years on the 5.0 (mostly with me as skipper) and he didn't have any difficulties changing to the Blade also. Regards, Gill 60 - and he's still sailing cats <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Dermot Catapult 265
[Re: Dermot]
#132762 02/22/08 02:13 PM 02/22/08 02:13 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | 60 - and he's still sailing cats <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> Hmmm, I know people in their late 60's and early 70's who are still sailing cats. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> | | | Re: Questions from a possible F-16 buyer
[Re: Mary]
#132763 02/22/08 02:20 PM 02/22/08 02:20 PM |
Posts: 915 Dublin, Ireland | 60 - and he's still sailing cats <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> Hmmm, I know people in their late 60's and early 70's who are still sailing cats. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> That was quick Mary <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Seeing that I'm in that group now, I'm trying to get others over 60 to comment <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Dermot Catapult 265
[Re: Rolf_Nilsen]
#132765 02/22/08 04:32 PM 02/22/08 04:32 PM |
Posts: 126 southern Ontario | Here in Toronto there is one former F18 sailor who races a Blade. Nice boat. Races us F18's and Acat.
[Re: Rolf_Nilsen]
#132766 02/22/08 05:35 PM 02/22/08 05:35 PM |
Posts: 915 Dublin, Ireland | Wow Dermot, I would never have guessed! Keep at it! I really don't want to talk about myself, but maybe this is relevant to this thread and will encourage new sailors to cat sailing. In my opinion <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />, I have always raced the most suitable cat for my ability (and age). I started sailing at 33 in a single-handed Catapult. I raced it in a mainly Condor fleet and, when my eldest son, Neil, was 12, he became my full time crew on a Dart 18. When Neil moved on to his own Dart 18, my younger son Gary took over as my crew. When the Dart Hawk was introduced, we moved on to that, before I got too old <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />. Then the lighter Spitfire appeared on the scene, and Neil bought one, and I followed a year later. Gary went off working as a sailing instructor and I found that the juniors in the Club (mainly girls in their early 20s) could not afford their own boats, but were very enthusiastic about sailing on cats. I have had 2 sisters racing with me for the past few years (one at a time) and we won the 2006 Irish Nationals as I entered my 60th year in 2006. This will probably be my last year on the Spitfire. At my age, I don’t want to be dependant on a crew, or have a crew dependant on me, so it looks like a Shadow beckons – It’s all about sailing the most suitable cat for your circumstances. When I say Spitfire here, I really do not differentiate between it and a Formula 16.
Dermot Catapult 265
[Re: canuck001]
#132767 02/22/08 05:39 PM 02/22/08 05:39 PM |
Posts: 9,582 North-West Europe | 6) Are there any F-16s in Canada or in Toronto. I realize the class is still new and I dont mind being the first, but company would be nice.
A few. The guy in Toronto as mentioned, and I know of Bruce Barrs in Edmonton Alberts (a bit far away) and a couple in up-state New York. Check here for locations : http://www.frappr.com/formula16classgroupThis frappr map is not up to date anymore, but everybody that is on there still has a boat, basically the new additions haven't registered yet. My advice would be to find a Blade owner and beg for a test ride. Then you know what to expect in stead of believe us on our world. But the old addagio still holds (it orginated with the Taipans). "Don't test sail a F16 if your are not prepared to want one !" Wouter
[Re: Twister]
#132768 02/22/08 05:39 PM 02/22/08 05:39 PM |
How does he do in comparison. I mean relative to before and after the switch ?
[Re: Dermot]
#132769 02/22/08 07:28 PM 02/22/08 07:28 PM |
Posts: 954 Mumbles Y.C Wales U.K | Come on now Dermot, I know you have deep roots in the Swell ethos but a true F16 is what you're really craving!! Have a GREAT day and don't open too many bottles whilst watching the other sport <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> What are you doing between the 9th-12th Aug. I'm sure we'd all like you to join us at our Welsh World's in body if not on the water. MP*MULTIHULLS | | | Re: Questions from a possible F-16 buyer
[Re: Mark P]
#132770 02/22/08 10:31 PM 02/22/08 10:31 PM |
Posts: 6,049 Sebring, Florida. | Dermot is lying, probably trying to get some "senior Citizen discount" or something. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I've seen him up close, I tell you he isn't a day over 50! And Dermot, could you please send me one of those "sisters" for the Gulfport regatta? Wouldn't it be great to have an authentic Irish Lasse on St. Patty's day over here! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Blade F16 #777
[Re: Timbo]
#132771 02/22/08 11:10 PM 02/22/08 11:10 PM |
Posts: 19 Toronto | Hey Canuck! As soon as the water warms, the Blade F16 #722 will be back out on Lake Ontario out of EYC. Track me down if you want to go for a blast! Apparently there is also a Taipan sailing out one of the outer harbour clubs, but I have yet to see it. It would be nice to get another F16 out to race with.
Blade 722
[Re: Wouter]
#132772 02/22/08 11:14 PM 02/22/08 11:14 PM |
Posts: 19 Toronto | I think I'm doing better thanks!
Blade 722
[Re: f16rick]
#132773 02/23/08 02:58 AM 02/23/08 02:58 AM |
Posts: 9,582 North-West Europe | I think I'm doing better thanks!
So I can mark you down as a happy customer ?! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Wouter
332
guests, and 46
