| Re: H20 rudderelastic
[Re: NED4]
#13371 11/21/02 02:37 PM 11/21/02 02:37 PM |
Posts: 805 Gainesville, FL 32607 USA | Hobie 20 elastic bungee replacement for the metal clip on tiller arm: The first time 1. drill out the rivets 2. pull the cap off 3. poke the taped bungee end through from the outside 4. Keep pushing until it comes out, untape, tie in a figure 8 knot then pull the knot back inside.
Second time: now the cap would not come off. 1. drill another hole under the first hole through the tiller extension 2. use a piece of line through both holes 3. tie the bungee in place for the clip.
[Re: NED4]
#13374 11/21/02 09:29 PM 11/21/02 09:29 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I installed this system on a Hobie 18 and I just drilled down completley through the tube and tied a figure 8 at the bottom. Never had any problems and its easy to replace. Make sure to deburr the holes so there's no chafe.
754
guests, and 648
