| Do you know for sure your boat won't sink? #13408 11/22/02 01:31 PM 11/22/02 01:31 PM |
Joined: Sep 2002 Posts: 273 Key Largo, FL MaryAWells OP
Posts: 273 Key Largo, FL | Whether you have a multihull or a small monohull, do you know whether your boat will float if it is completely full of water? How can you find this out before you are in a life-threatening situation? We beachcat sailors all seem to complacently accept that our boats will capsize but at least they will not sink. But is that definitely true? Nobody seems to know. I have recently heard that some of the newer, lighter, more high-tech cats, partly because of their hull construction, can definitely sink. So how can you be sure, aside from taking your boat out into relatively shallow water and deliberately trying to sink it? But nobody wants to do that, because if it really does sink, how do you get it floating again so you can get it back on shore? So if you have any doubt about whether your boat would float, do you stuff it full of styrofoam -- how do you know how much is enough?
Mary A. Wells
| | | Re: Do you know for sure your boat won't sink?/ Cu
[Re: Sailing Pro Shop]
#13411 11/22/02 02:54 PM 11/22/02 02:54 PM |
Posts: 2,844 42.904444 N; 88.008586 W | My first boat, a P18, yellow asym. hulls, #333.
While ~5mi offshore of West Beach, Galveston this boat began to take on water. I had a recent bottom job done, that had ruptured and leaked. To make a long stroy short, it floated after righting with the tops of the decks at the waterline, most everything underwater, but it floated my brother and I as a friend on a P16 towed the boat and us back to shore. It seemed that it had the floatation inherent in it not to sink, that was salt water however, may have made a difference.
I think someone should try it, take out the plugs, and inspection port lids, fully rigged, and see what it does, salt and fresh water. We could post it here in sort of a table format. I"m sure someone with a 6.0 could tell me their results 8'), it's be in the interest of safety research, let me know how your 6.0 does, I'll make a note.
Todd Bouton N6.0na+ #111
F-18 Infusion #626- SOLD it!
[Re: MaryAWells]
#13413 11/22/02 04:01 PM 11/22/02 04:01 PM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | Mary,
If the risk of sinking is something that should be considered, what about using the flotation bags that are common in canoes and kayaks. Insert through the inspection ports and inflate.
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: MaryAWells]
#13418 11/26/02 05:42 PM 11/26/02 05:42 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I can remember hearing of a well known sailor who would pour acetone through the hull on his Hobies to get rid of the extra weight of the styro blocks. The a-tone would melt the foam and it would pour out the drain holes.
Anything to save a pound or two.
| | | Solcat 18...
[Re: thom]
#13421 11/27/02 02:08 PM 11/27/02 02:08 PM |
Posts: 50 Farmington, Utah | Thom: Our Solcat 18 was a 1978 or 9 (I think). It really was a fun boat....with lots of forward floatation, due to those very long bows in front of the front beam. It's low freeboard made for some exciting, wet and wild whaaa-hooo sailing....and there were lots of rigging adjustments to play with. What did you do with yours after its unfortunate demise...??? Regards and Happy Thanksgiving to all..... Tom H. | | | Float your boat
[Re: thouse]
#13422 12/02/02 11:38 AM 12/02/02 11:38 AM |
Posts: 2,844 42.904444 N; 88.008586 W | OK Jake,
Let's try it! C'mon down to Galveston Bay. We'll swamp'r and see!
Todd Bouton N6.0na #111
| | | Great post...
[Re: carlbohannon]
#13426 12/03/02 01:17 PM 12/03/02 01:17 PM |
Posts: 50 Farmington, Utah | Mary... that was a great post....and I just smiled and smiled as I read it.... As I read it I thought you: 1. Have had lots of bad luck with boats.... 2. Spent enough time on lots of boats to have had lots of "on the edge" experience... 3. Hang around some pretty wild and crazy boat driverds.... or 4. All of the above. However, the question remainds...If you want to scuttle one that's given its all....how do you get it to sink... | | | Re: Great post...
[Re: thouse]
#13427 12/03/02 05:04 PM 12/03/02 05:04 PM |
Posts: 273 Key Largo, FL | Maybe fill it with sand and/or dirt and/or rocks? This is all experimental because most people do not deliberately try to sink their beach cats. There's probably a law against it -- like littering, or damaging the sea grass. In these parts, getting rid of a boat usually involves a chainsaw.
Yes, we had a boat that sank, but it was a big monohull sailboat that we were traveling and living on at the time. It was raised by inflating bags inside the boat and gradually lifting it with two tow-truck hoists.
I know, now you want to know why it sank. We were tied up to a new dock in the Hudson River. It had replaced an old dock, and somebody had neglected to remove some steel pilings from the old dock. They were below the surface of the water and were invisible because the water was opaque. While we were gone for the day, the old pilings dug a hole in our hull.
The reason I asked the question about beach cats is because somebody mentioned to me recently that some of the new, high-tech hull construction materials do not use foam core and may not have any inherent buoyancy -- and also do not have auxiliary flotation materials in the hulls. I don't know whether this is true or not, but it started me thinking about it because, as I said, nobody wants to try to sink their boat on purpose just to see whether it floats. So we just take it on faith that it will float. And the assurance or guarantee of a dealer or manufacturer is not going to be much comfort to me if my boat is sinking out from under me in the Gulf Stream.
Anyway, my original question, Do you know for sure you boat won't sink, was actually sort of rhetorical, because how CAN you know for sure? Do manufacturers cut a boat in half crosswise and put it in the water to see if the front and aft halves will float independently of each other? Seems like that would be a really good test.
If you are not sure whether your boat will float and you are worried about it, you should put some kind of flotation into your hulls -- maybe the inflatable bags that someone else suggested. Or you could fill it with that styrofoam packing "popcorn" or lots of lobster pot floats or whatever will fit through your inspection hatches. (If you are going to use little, loose things like that, probably better to put big plastic bags into the hulls, put the flotation stuff into the bags and then seal the bags.)
Mary A. Wells
1 registered members (FredL),
2,799
guests, and 283
