Vintage Hobies #136620
03/16/08 01:35 AM
03/16/08 01:35 AM
Minnesota
Jeff Peterson Offline OP
Minnesota
The Hobie 16 & 14 have been around, well, just about forever. Many of us enjoy our old boats and do most anything to keep them going. I believe the older boats should now be considered "Vintage" boats. But, what defines a vintage Hobie? Pre-comptip? Old style jib cam cleats? Pre-redline? Sail colors?
What are your thoughts on this?
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Vintage Hobies [Re: Jeff Peterson] #136621
03/16/08 12:08 PM
03/16/08 12:08 PM
...what defines a vintage Hobie?
Are you asking at what point your boat becomes an "old" boat?
Re: Vintage Hobies [Re: Jeff Peterson] #136622
03/16/08 12:56 PM
03/16/08 12:56 PM
Northern California, USA
RyanMcHale Offline
RyanMcHale  Offline
Hi Jeff,
I consider mine to be "Vintage", (AKA Old like Mary said" 1980 Hobie 14!!!
What defines a vintage Hobie?
Ryan McHale
Hobie 14 (battened jib)
Re: Vintage Hobies [Re: RyanMcHale] #136623
03/16/08 06:45 PM
03/16/08 06:45 PM
Coopersburg, PA
V
Vinny_M Offline
Vinny_M  Offline
V
Coopersburg, PA
Hi Jeff,
got ya beat....ive got a 79'
~vinny~
Re: Vintage Hobies [Re: Jeff Peterson] #136624
03/16/08 07:26 PM
03/16/08 07:26 PM
When looking at the definition of vintage in adj. form
Characterized by excellence, maturity, and enduring appeal; classic.
The Hobie 16 fits this criteria, still strong amongst all one-design sailing classes.
OR
Old or outmoded.
You may say pre-1995 without integral traveler tracks (allowing more rake) are outmoted. Prior to that possibly pre-1984 when the class lowered min. weight to 320#s.
Re: Vintage Hobies [Re: _flatlander_] #136625
03/17/08 12:39 AM
03/17/08 12:39 AM
Minnesota
Minnesota
I'm looking for a variety of opinions, but my personal opinion tends to the "true" older boat. If it has a comp-tip, its hard for me to call a boat a vintage Hobie. I would certainly get upset with calling any post-1984 boat as vintage. The 1984 change is a definite watershed.
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Vintage Hobies [Re: Jeff Peterson] #136626
03/17/08 02:24 AM
03/17/08 02:24 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
About 7 years ago, I met a guy who is now my friend. He was learning how to sail a Hobie 16 and I gave him some advice and eventully sailed on his boat. It was Hobie 16 number 166, as stamped into the aluminum stanchions.
This boat's hulls were severely faded from sun, but they were as hard as glass with not a soft spot to be found.
I do not know what the weight of this boat was.
GARY
Santa Monica Bay
Re: Vintage Hobies [Re: Vinny_M] #136627
03/17/08 09:15 AM
03/17/08 09:15 AM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
Hi Jeff,
Got you beat, 70-71, h16, serial number ccme 23170 very much hoping to get the soft spot fixed this year and put it back on the water.
Re: Vintage Hobies [Re: Banzilla] #136628
03/18/08 11:06 AM
03/18/08 11:06 AM
Jeff- if you're interested there is a 71' H14 in Cannon Falls that will probably end up die a gruesome death if no one picks it up. It's tough looking, and needs alot of work/parts. But it's there, I wouldn't offer over $200 for it. A little bit soft, but still fairly stiff.
Re: Vintage Hobies [Re: Karl_Brogger] #136629
03/19/08 11:33 PM
03/19/08 11:33 PM
Minnesota
Minnesota
(Karl, check your private messages.)
...Now, back to the topic of Vintage Hobies...
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Vintage Hobies [Re: Jeff Peterson] #136630
06/20/08 09:40 AM
06/20/08 09:40 AM
C
Concord Offline
Concord  Offline
C
I think I have you all beat but how do I find out the age of a Hobie?
The Hobie 16 Hull number 1279 is stamped on the plyon posts and acording to the web site that makes it a pre-1973 model but I am curious of the actual year of manufacture.
Also having trouble registering it because the hull does not have a number other than 1279. (Registration required to put the boat on the beach in NJ) Any advice appreciated.
For reference, the boat is pretty close to new condition except for a little gel coat fading and a few loose rivets.
Re: Vintage Hobies [Re: Jeff Peterson] #136631
06/24/08 06:04 PM
06/24/08 06:04 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
Who's gonna run the first Vintage Hobie 16 Regatta/Rally?
Re: Vintage Hobies [Re: rhodysail] #136632
06/25/08 08:23 PM
06/25/08 08:23 PM
They should have a class for 30+ year old boats at the 40th aniversary regatta.
Re: Vintage Hobies [Re: Karl_Brogger] #136633
06/26/08 08:21 AM
06/26/08 08:21 AM
Which goes back to the original question. What is the cut-off year? What defines vintage?
Re: Vintage Hobies [Re: _flatlander_] #136634
06/26/08 08:39 AM
06/26/08 08:39 AM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
Not sure it is just the date of the boat, but would you not have to have age appropriate
Sails, Blocks, Tramp, harness, rudders and most importantly of all crew? What about the Mast? For a car to be truly vintage, do not all of the parts also have to be vintage?
Could you set the time line to be something like prior to the upgrade of Parts X say for example Main blocks
Sam
[b] Sail Like you have a Pair
Re: Vintage Hobies [Re: Banzilla] #136635
06/26/08 09:58 AM
06/26/08 09:58 AM
Sam,
Good point, it would be very rare to find enough boats that haven't been upgraded with jib systems, main blocks, EPO's and the like.
I'd suggest the cutoff be no newer than 1983, as that's when the minimum weight was dropped/standardized, even then some older (pre '80) boats are light. It would be hard to arrive at a consensus.
As far as the crew age goes, HCANA rules have master and grand master established.
Re: Vintage Hobies [Re: _flatlander_] #136636
06/26/08 10:57 AM
06/26/08 10:57 AM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
So, what about comptip vs non? If the vintage rules are followed, a "true" Vintage boat would not be eligible to sail in HCA events. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Re: Vintage Hobies [Re: Banzilla] #136637
07/11/08 08:05 AM
07/11/08 08:05 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
________________________________________
I can speak to the reference to Vintage Race Cars:
Generally speaking, we permit replacement of all components with original spec items, regardless of when they are manufactured. That means, in theory, that the whole boat or car might be made of essentially new parts.
When original spec parts are no longer availible, then we allow parts that are functionally similar. This of course can be a grey area subject to heated debate.
In the case of "Vintage Hobies", I would support the time-line concept. You won't get recognition from Hobie for several reasons, primarily because they have the Comp Tip rule and also they are in the business of selling new boats. However, factory parts are readily available.
For non-Hobie races, the Vintage Hobies (VH16)?? could start with the H16's and just be scored separately. Since they would still be class legal, they might also be scored with the fleet as well.
The key points to define a VH16 could be:
1. Pre-1984 hulls.
2. No Comp-Tip.
3. Max mast rake as defined by rule.
4. Min weight of 365#
5. Sails cut to 1983 pattern, but aftermarket to same design allowed.
6. Open tramp rule.
7. Original jib halyard and downhaul.
8. 6:1 mainsheet.
9. Plastic rudders.
10. Crew age….??? Not sure if that should be a factor…the youngsters wouldn’t have a fair chance!
Another concept would be to take in Prindle 16 and Sol Cat survivors. They ought to be able to race straight-up with the VH16’s.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Vintage Hobies [Re: Mugrace72] #136638
07/17/08 08:24 PM
07/17/08 08:24 PM
Norcal
wrxboy76 Offline
wrxboy76  Offline
Norcal
I think my boat fills the bill as a vintage H16: 1971 hull# 1842.
---Jake---
Re: Vintage Hobies [Re: wrxboy76] #136639
08/17/08 11:13 PM
08/17/08 11:13 PM
walla walla , washington
snoopdog Offline
snoopdog  Offline
I am new here and just picked up a 1976 H16. To me its a brand new boat. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
1 registered members (vasil), 289 guests, and 39 spiders.
