Nacra mainbeam and dolphin striker #138502
03/31/08 03:36 PM
03/31/08 03:36 PM
I have recently reassembled the main beam on my Nacra 5.8. The original mast bolt was bent and needed replacing. I need to know how to tension the striker and what torsion should the main beam have. Anyone know?
Re: Nacra mainbeam and dolphin striker [Re: ] #138503
03/31/08 08:14 PM
03/31/08 08:14 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
According to the factory, 3/8 inches of prebend on the front beam.
Philip
USA #1006
Re: Nacra mainbeam and dolphin striker [Re: P.M.] #138504
03/31/08 08:19 PM
03/31/08 08:19 PM
Thanks for the reply mummp.
Where did you get that information? Since I am reassembling the cat, I would find that source valuable.
How would you measure a prebend of 3/8"?
Re: Nacra mainbeam and dolphin striker [Re: ] #138505
03/31/08 11:12 PM
03/31/08 11:12 PM
jcasto1 Offline
jcasto1  Offline
Make a straight line from end to end of crossbeam, without mast in place. The ends of crossbeam should be lower than middle by amount of prebend.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Nacra mainbeam and dolphin striker [Re: ] #138506
04/01/08 08:50 AM
04/01/08 08:50 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Tobin,
Keep it simple, with no load on the beam your beam should be level and/or "straight", then simply screw the lower nut up 3/8 in. and then tighten your upper nut. Just curious, after you straightened the rod, did you put a compression tube back inside the beam? If you did I hope you marine greased the snot out of it. . .
Philip
USA #1006
Re: Nacra mainbeam and dolphin striker [Re: P.M.] #138507
04/01/08 03:23 PM
04/01/08 03:23 PM
I didn't, but i reassembeled it just a week ago and haven't tightened it yet. Where should I grease the snot out of it? And why?
Re: Nacra mainbeam and dolphin striker [Re: ] #138508
04/01/08 04:58 PM
04/01/08 04:58 PM
JACKFLASH Offline
JACKFLASH  Offline
Where the stainless sleeve comes into contact with the aluminum crossbar due to electrolosys (sp) that will occour there.
Collin Casey
Re: Nacra mainbeam and dolphin striker [Re: ] #138509
04/01/08 05:17 PM
04/01/08 05:17 PM
catman Offline
catman  Offline
And this is the best stuff to use. tefgel
Re: Nacra mainbeam and dolphin striker [Re: JACKFLASH] #138510
04/01/08 06:24 PM
04/01/08 06:24 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
. . . . and also the inside of the compression tube.
Philip
USA #1006
0 registered members (), 633 guests, and 169 spiders.
Posts267,056
