Mast Caddy for trailer? #139201
04/06/08 05:04 AM
04/06/08 05:04 AM
M
Mappy Offline OP
Mappy  Offline OP
M
What is the best type of rear beam mast caddy to use? Any pictures of a homemade design that works well?
Thanks
Re: Mast Caddy for trailer? [Re: Mappy] #139202
04/06/08 07:23 AM
04/06/08 07:23 AM
Re: Mast Caddy for trailer? [Re: Mappy] #139203
04/06/08 12:16 PM
04/06/08 12:16 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
made from 2x8, screwed and glued. You can see how the traveler track is notched out. I secure it in place with bungees.
Re: Mast Caddy for trailer? [Re: arbo06] #139204
04/06/08 12:19 PM
04/06/08 12:19 PM
arbo06 Offline
arbo06  Offline
And the other view, including the beautiful Makita Girls and my better half.
Re: Mast Caddy for trailer? [Re: arbo06] #139205
04/06/08 01:56 PM
04/06/08 01:56 PM
I just use one f my old tyres from the Impreza; Yes they are heavy, but they allow me to get some tension as they give a little.
Added bonus is that (as I carry another one) they can act as stern supports when the boat is placed on hard ground (as well as the foam ones I have).
Re: Mast Caddy for trailer? [Re: arbo06] #139206
04/06/08 02:19 PM
04/06/08 02:19 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
I was going to say, I don't see anything that looks like a mast caddy. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
[b] Sail Like you have a Pair
Re: Mast Caddy for trailer? [Re: Mappy] #139207
04/06/08 04:15 PM
04/06/08 04:15 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Polystyrene block cut to shape. If you want to look after it cover it in light mutton cloth with a pva style glue and paint it.
Re: Mast Caddy for trailer? [Re: Mappy] #139208
04/07/08 08:53 AM
04/07/08 08:53 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
http://farm4.static.flickr.com/3258/2395236493_20dde2b13e.jpg?v=0
This mast caddy was created from UHMW plastic sheet. I believe it was a cutting board in its past life.
You can pretty much see how it was built if you look at the picture carefully and spend a moment pondering on it.
The nut on the left side is the closure. It pivots up in between the notch there. The caddy is connected to the rear beam with old bungee run thru holes drilled in the plastic. Use stainless screws (note rust).
This was conceived and built by David Tilley, Franklin, Louisiana.
Re: Mast Caddy for trailer? [Re: tami] #139209
04/07/08 10:32 PM
04/07/08 10:32 PM
I AM GOING TO BUY A MAKITA!!!!
Re: Mast Caddy for trailer? [Re: Mappy] #139210
04/15/08 09:55 PM
04/15/08 09:55 PM
College Station, Texas
chloemac00 Offline
chloemac00  Offline
I've got an extra mast cradle that attached to the rear beam. It's from one of my old 5.2's. I don't need it. It is located in Texas. If you're still looking for one, make me an offer. It attaches to the rear crossbeam and then to the mast.
George
My pride and joys and my daughter, Chloe and our Nacra 5.2!!!
Re: Mast Caddy for trailer? [Re: chloemac00] #139211
04/16/08 12:49 PM
04/16/08 12:49 PM
George
I might be interested, could you post a pic?
Re: Mast Caddy for trailer? [Re: ] #139212
04/16/08 06:59 PM
04/16/08 06:59 PM
chloemac00 Offline
chloemac00  Offline
I don't have means to a digital camera and I can't figure out how to download from my cell phone to the computer.
The description is as best as I can do....
It is black, neophrene plastic, with two pivot points. One point attaches to the rear cross beam and a long bolt tightens up for security. The top cradle pivots left and right, fore and aft. It has a wide opening to fir most any cat. mast. a long bolt goes through the top to secure the mast.
I've tried to look these up on the internet to download a picture from there, but I can't seem to find them.
You can go to www.sailingtexas.com
go to sailboat photo gallery and letter "N".
Pull up the Nacras and look for the 5.2 from Georgia. It has a picture the with mast being cradled from the rear beam. That is the cradle that I have.
In Christ
George
979-219-0829
Re: Mast Caddy for trailer? [Re: Mappy] #139213
04/19/08 11:40 PM
04/19/08 11:40 PM
I
icatchya Offline
icatchya  Offline
I
This is what is common in Australia\
simple but effective
0 registered members (), 2,643 guests, and 351 spiders.
