| How to decals or lettering from sails? #13934 12/09/02 11:55 PM 12/09/02 11:55 PM |
Posts: 591 Bradenton, FL | I just got some used sails that are in pretty decent shape. However, they've got some lettering that seems to be glued on somehow that I'd like to remove. They seem to be Dacron material, or maybe vinyl?
Is there anything that'll dissolve the glue without fading or otherwise harming the Dacron sail?
Hobie 14T
| | | Re: How to decals or lettering from sails?
[Re: Sycho15]
#13936 12/10/02 11:01 AM 12/10/02 11:01 AM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | Hi, I haven't tried it myself, but I have a video from the Sailrite company that shows how they remove adhesive residue from sails. They use a product called "Goo Gone". They soak the area, cover it with a cloth or paper towel and soak that also. After it sits for a while (you'll have to experiment to see how long), the gunk will wipe off and roll up. A second application is needed sometimes. Good luck, Jack Hoying Fort Loramie, Ohio Prindle 18 #1645 http://www.bright.net/~jmhoying/sailing/prindle.htm
Jack Hoying
Fort Loramie, Ohio
[Re: Sycho15]
#13938 12/10/02 12:49 PM 12/10/02 12:49 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Try using a hair dryer. Somtimes when you heat it the adhiesve will stick to the decal and come off with it. 3M makes a product that removes the goo also. Find it at a auto paint supplier.
3,695
guests, and 114
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online4,027 1 hour ago | | |
