Meet Skeeta II #139632
04/10/08 11:48 PM
04/10/08 11:48 PM
Kyabram
M
MickM Offline OP
MickM  Offline OP
M
Kyabram
For those who may be interested here is a new mosquito under construction. I have been looking at this forum for some time and found many good tips used in the construction. Skeeta II has been under construction for about 12 months and is now ready to paint. It should be ok for next season - but then again I thought it would be ready for last Christmas. Anyway attached is a picture of where I'm up to now and more pic's can be posted on completion if there is any interest. Cheers
141830-skeeta10408.pdf (395 downloads)
MickM Mossi 1811
Re: Meet Skeeta II [Re: MickM] #139633
04/11/08 01:21 AM
04/11/08 01:21 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Hey Mick,
Good hearing from you.
Boat looks great!
What colour are you going to paint it?
Keep us posted.
Cheers Ben
---Ben Cutmore---
--MOSQUITO 1704--
Re: Meet Skeeta II [Re: becjm] #139634
04/11/08 01:49 AM
04/11/08 01:49 AM
Kyabram
M
MickM Offline OP
MickM  Offline OP
M
Kyabram
Hi Ben,it will be red with black beams and tramp.The hulls are under 17kgs each before painting and it's quite solid so I'm quite happy with that. cheers
MickM Mossi 1811
Re: Meet Skeeta II [Re: MickM] #139635
04/11/08 01:52 AM
04/11/08 01:52 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Sounds good.
Where is Kyabram. Where are you going to sail it?
---Ben Cutmore---
--MOSQUITO 1704--
Re: Meet Skeeta II [Re: becjm] #139636
04/11/08 02:24 AM
04/11/08 02:24 AM
Kyabram
M
MickM Offline OP
MickM  Offline OP
M
Kyabram
Kyabram is in Northern Vic, half way between Shepparton and Echuca. Waranga is the local club and I plan to do some regatta's
MickM Mossi 1811
Re: Meet Skeeta II [Re: MickM] #139637
04/11/08 03:24 AM
04/11/08 03:24 AM
Peter_Foulsum Offline
Mick,
Great to see another timber Mozzie. Did you use 4 mm ply throughout ? Do you expect it to be minimum platform weight ?
You may need to check with the association regarding your new registration number. 1811 is already sailing at Somers.
<img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Peter
Mosquito 1814
Macka Mozzie
Re: Meet Skeeta II [Re: Peter_Foulsum] #139638
04/11/08 04:14 AM
04/11/08 04:14 AM
greymatter Offline
greymatter  Offline
looks good enough to varnish.
And as Peter said check with the association about your number there might have been a mistake with the number. if your plans are for 1811. call up for another number, before you get your sails made.
what sail maker are you using?
Re: Meet Skeeta II [Re: greymatter] #139639
04/11/08 05:15 AM
04/11/08 05:15 AM
Kyabram
M
MickM Offline OP
MickM  Offline OP
M
Kyabram
It's made from 3mm gaboon and I expect it to make minimum weight. Looks like we have a problem with the sail number, though. I confirmed the sail number via email with the association back in about September/October and Goodalls have already made the sail in the latest myla materials
MickM Mossi 1811
Re: Meet Skeeta II [Re: MickM] #139640
04/11/08 05:27 AM
04/11/08 05:27 AM
Kyabram
M
MickM Offline OP
MickM  Offline OP
M
Kyabram
Just looked at my files and confirmed that on July 4th this year the association agreed 1811 would be my sail number.
MickM Mossi 1811
Re: Meet Skeeta II [Re: MickM] #139641
04/11/08 07:09 AM
04/11/08 07:09 AM
Bendigo, Victoria, Australia
colmc Offline
colmc  Offline
Dis is a bit of a concern is there also another 1810 out there somewhere because I got my number after July. I think it was about October 2007. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> Suppose we'll have to wait and see.
Col
"Now What?"
Mosquito 1810
Re: Meet Skeeta II [Re: MickM] #139642
04/11/08 06:27 PM
04/11/08 06:27 PM
greymatter Offline
greymatter  Offline
at 17 kg a hull with out paint it will be under weight. my hulls were 17kg without decks on them, my boat is carrying 1.75 kg of lead.
Have you doubled the deck, or are you trying to go glass either side of the 3mm?
on my boat i had glass on the inside only and split the deck since then i have doubled the deck, as the plans say to and it is very strong now.
Re: Meet Skeeta II [Re: greymatter] #139643
04/12/08 01:34 AM
04/12/08 01:34 AM
Kyabram
M
MickM Offline OP
MickM  Offline OP
M
Kyabram
Hi Rob, In the centre deck I used three 25mm x 3mm stringers on their edges. Effectively I went with the theory that if you supported a ruler on its edge, over a less than 200mm clear span, it can hold a fair bit of force. These stringers are wider than a ruler, ply, and coated in resign, so I hope they do the job. No doubt if wore my stilettos I would punch a hole right through, but I think I only need to worry about a knee or elbow. Anyway for now I think they’re pretty solid so we’ll just have to wait.
MickM Mossi 1811
0 registered members (), 567 guests, and 26 spiders.
