Adjustable Spreaders Measurement Check #140156
04/16/08 03:51 AM
04/16/08 03:51 AM
ncik Offline OP
ncik  Offline OP
Would just like to check spreader measurements that are found on the forum.
- 580mm between wire centres.
- 25mm rake from sail track to taut line.
Are these correct?
Re: Adjustable Spreaders Measurement Check [Re: ncik] #140157
04/16/08 07:40 PM
04/16/08 07:40 PM
East Gippsland, Australia
Tim_Mozzie Offline
Tim_Mozzie  Offline
Here's a drawing of the spreaders I have (they are only adjustable by the three slots on the ends of the arms):
Tim Shepperd
Mosquito 1775
Karma Cat
Re: Adjustable Spreaders Measurement Check [Re: Tim_Mozzie] #140158
04/16/08 11:38 PM
04/16/08 11:38 PM
ncik Offline OP
ncik  Offline OP
Thanks Tim, that is a lot less rake and length than I found earlier.
Re: Adjustable Spreaders Measurement Check [Re: ncik] #140159
04/17/08 03:05 AM
04/17/08 03:05 AM
Tim_Mozzie Offline
Tim_Mozzie  Offline
I would imagine more length could be a problem if sloop rigged - it would catch on the jib. No problem cat rigged though.
I have my wires in the rear-most slot because I am light (74kg) and sail cat rigged - so I'm keen to de-power.
It's important to check where the wires are attached at the base of the mast when comparing rigs. Mine are attached to a single point on the front of the mast. If diamonds are attached to the sides then more spreader rake will be required to achieve the same effect.
Tim Shepperd
Mosquito 1775
Karma Cat
Re: Adjustable Spreaders Measurement Check [Re: Tim_Mozzie] #140160
04/17/08 05:55 PM
04/17/08 05:55 PM
ncik Offline OP
ncik  Offline OP
Good points, my wires are attached on the sides and the current spreader length does push into the jib if rotated too much with narrow sheeting position.
0 registered members (), 255 guests, and 26 spiders.
