| Re: Diesel soot - how to remove?
[Re: Rhino1302]
#140172 04/16/08 12:02 PM 04/16/08 12:02 PM |
Posts: 1,200 Vancouver, BC | Acetone will do it...just don't try on a painted surface unless you've tested it first.
Rubbing alcohol or Ethanol will also do a good job and are less harmful to paint.
[Re: Cheshirecatman]
#140176 04/16/08 04:59 PM 04/16/08 04:59 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | "If you can't find a proprietary product, mix your own."
Unless you're a Chemist, NEVER mix your own! I think I learned that in 8th grade science. NEVER mix unknown chemicals. Leave that to the professionals unless you have a death wish.
Lee
Lee
[Re: Rhino1302]
#140183 04/17/08 09:08 AM 04/17/08 09:08 AM |
Posts: 833 St. Louis, MO, | I'm not sure if there is anything special about diesel soot. My first thought is Snobol Toilet bowl cleaner. Just wipe it on and wait about a minute and wipe it off with a bucket of water. Wear gloves!!! After clean throw some speed glaze on there or whatever you use as a "wax" or "non wax wax". If you don't the pours are open and will stain easily with the next splash in dirty water.
Mike Hill N20 1005
Mike Hill N20 #1005
[Re: Rhino1302]
#140185 04/17/08 05:59 PM 04/17/08 05:59 PM |
Joined: Jun 2001 Posts: 975 South Louisiana, USA Clayton
Posts: 975 South Louisiana, USA | I regularly tow over a 7000' pass. 7000'??? Around here you need a bridge to get a 100'-150'! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Elevation at my homestead is +32' (and I'm on high ground!) Get a turbo! Clayton End of hijack | | |
869
guests, and 648
