Diesel soot - how to remove? #140171
04/16/08 11:33 AM
04/16/08 11:33 AM
Reno NV
Rhino1302 Offline OP
Reno NV
Anyone know of an easy way (i.e. not rubbing compound and elbow grease) to remove diesel soot from boat hulls?
Re: Diesel soot - how to remove? [Re: Rhino1302] #140172
04/16/08 12:02 PM
04/16/08 12:02 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Acetone will do it...just don't try on a painted surface unless you've tested it first.
Rubbing alcohol or Ethanol will also do a good job and are less harmful to paint.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Diesel soot - how to remove? [Re: Tornado] #140173
04/16/08 12:16 PM
04/16/08 12:16 PM
Reno NV
Reno NV
Didn't have any luck with acetone, but probably I let it go too long. I'll try acetone again as soon as the soot starts to get noticeable.
Re: Diesel soot - how to remove? [Re: Rhino1302] #140174
04/16/08 01:07 PM
04/16/08 01:07 PM
Largo, Florida
papayamon2 Offline
papayamon2  Offline
Largo, Florida
FSR might do the trick. That's the brand name of a fiberglass cleaning product (FSR stands for Fiberglass Stain Remover). It's a gel that you rub on, let sit, and then wipe off. Works great for many stains and should be available locally.
Re: Diesel soot - how to remove? [Re: Rhino1302] #140175
04/16/08 04:54 PM
04/16/08 04:54 PM
UK
Cheshirecatman Offline
UK
Many of the stain remover products are oxalic acid based. If you can't find a proprietary product, mix your own.
Cheshirecatman
Re: Diesel soot - how to remove? [Re: Cheshirecatman] #140176
04/16/08 04:59 PM
04/16/08 04:59 PM
TeamChums Offline
TeamChums  Offline
"If you can't find a proprietary product, mix your own."
Unless you're a Chemist, NEVER mix your own! I think I learned that in 8th grade science. NEVER mix unknown chemicals. Leave that to the professionals unless you have a death wish.
Lee
Lee
Re: Diesel soot - how to remove? [Re: papayamon2] #140177
04/16/08 05:06 PM
04/16/08 05:06 PM
West Virginia
Soapysails Offline
Soapysails  Offline
West Virginia
Auhhh, now we know why that 5.8 move so well in light air...lol..You may wish to try Simple-Green or GUNK in a spray can..both are good with carbonized soils. GUNK (solventized emulsion) being a good deal stronger. After the hulls are cleaned well, take a look at the new Poly-barrier coatings. These protect the porus jel-coat (on older or sanded hulls)and help retard future staining...
Re: Diesel soot - how to remove? [Re: Rhino1302] #140178
04/16/08 06:33 PM
04/16/08 06:33 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Try Oops!
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Diesel soot - how to remove? [Re: TeamChums] #140179
04/17/08 02:16 AM
04/17/08 02:16 AM
UK
UK
Simple solution in water!!! Is that beyond most catsailors ability???
Cheshirecatman
Re: Diesel soot - how to remove? [Re: Rhino1302] #140180
04/17/08 02:22 AM
04/17/08 02:22 AM
ncik Offline
ncik  Offline
Detergent and hot water applied with a sponge should do a pretty good job?
Re: Diesel soot - how to remove? [Re: ncik] #140181
04/17/08 02:33 AM
04/17/08 02:33 AM
Have you tried asking your local ship chandler?
I know that there is special stuff available to clean oil stains, used it on my parents boat once but I forgot what it was called.
(Actually Shell Oil gave it to us after they caused an oil spill in the harbour).
Re: Diesel soot - how to remove? [Re: Tony_F18] #140182
04/17/08 02:58 AM
04/17/08 02:58 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Re: Diesel soot - how to remove? [Re: Rhino1302] #140183
04/17/08 09:08 AM
04/17/08 09:08 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I'm not sure if there is anything special about diesel soot. My first thought is Snobol Toilet bowl cleaner. Just wipe it on and wait about a minute and wipe it off with a bucket of water. Wear gloves!!! After clean throw some speed glaze on there or whatever you use as a "wax" or "non wax wax". If you don't the pours are open and will stain easily with the next splash in dirty water.
Mike Hill
N20 1005
Mike Hill
N20 #1005
Re: Diesel soot - how to remove? [Re: Mike Hill] #140184
04/17/08 09:58 AM
04/17/08 09:58 AM
Reno NV
Reno NV
Thanks for all the advice. I think it just must have got too deeply imbeded into the gelcoat for surface cleaners to work because I was lazy and let it accumulate for too long.
And I get a lot of soot because I've got a non-turbo diesel and I regularly tow over a 7000' pass.
Re: Diesel soot - how to remove? [Re: Rhino1302] #140185
04/17/08 05:59 PM
04/17/08 05:59 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
7000'??? Around here you need a bridge to get a 100'-150'! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Elevation at my homestead is +32' (and I'm on high ground!)
Get a turbo!
Clayton
End of hijack
Re: Diesel soot - how to remove? [Re: ncik] #140186
04/18/08 06:53 PM
04/18/08 06:53 PM
blindmonkey Offline
blindmonkey  Offline
Denatured Alchohol works every time
Re: Diesel soot - how to remove? [Re: blindmonkey] #140187
04/19/08 04:53 PM
04/19/08 04:53 PM
Hollister CA, Plano TX
avalondarlyn Offline
In the coast guard we used denatured alcohol. with the cheap coast guard paint then we started to paint the stern with a high quality "Sterling" paint. then it justs wipes off. no wax. If its old and pourus and you get it clean, seal it with something like "rain -x" or avaition window cleaner for plastic windows "miguares" once its sealed it should just wipe off with a sponge.
0 registered members (), 18,087 guests, and 1,120 spiders.
14 hours ago
