| Cat Trax inner tube on a Roleez wheel? #141177 04/24/08 08:38 PM 04/24/08 08:38 PM |
Joined: Feb 2008 Posts: 8 Chesapeake, VA clintopher OP
Posts: 8 Chesapeake, VA | Will the Cat Trax inner tube fit a roleez wheel? I'm not sure of the size. My father-in-law has had them for a while...says patent pending on the tire. Anyway, the only information it has on the side of the tire is 120Kg (264lb) payload. That jives with the info from the 49cm Wheeleez.
So does anybody know if the tubes will work? If not I'm gonna have to get real creative with a broken valve stem.
Clint
| | | Re: Cat Trax inner tube on a Roleez wheel?
[Re: clintopher]
#141178 04/25/08 06:33 AM 04/25/08 06:33 AM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | Don't see why not, as long as they are both close in size.
You could blow them up outside of the tire and see how they look next to the tire they are going in.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: Tri_X_Troll]
#141179 04/25/08 07:46 AM 04/25/08 07:46 AM |
Posts: 1,253 Columbia South Carolina, USA | if not, I got a tube replaced in mine from the local tire store for $20. sure beats $110 for a new tire from cattrax
[Re: Tri_X_Troll]
#141180 04/25/08 08:03 AM 04/25/08 08:03 AM |
Posts: 1,884 Detroit, MI | Don't see why not, as long as they are both close in size.
You could blow them up outside of the tire and see how they look next to the tire they are going in. Cat Trax tires are much larger than Rol-eze tires. 65" circumference if memory serves. | | | Re: Cat Trax inner tube on a Roleez wheel?
[Re: Barry]
#141182 04/25/08 04:16 PM 04/25/08 04:16 PM |
Posts: 1,253 Columbia South Carolina, USA | mine was a cattrax tire that I replaced with an innertube, but I bet they(any tire store) could size and/or fix the rolleez too
269
guests, and 39
