SC20 tall rig on Stiletto 23? #141183
04/24/08 11:52 PM
04/24/08 11:52 PM
WA, ID, MT
davefarmer Offline OP
WA, ID, MT
Sure, I'm the last guy to need a fourth cat, but....I'm looking at an '85 Stiletto, no sails and a Supercat 20 tall rig mast(38.5', triple spreader) instead of the std 36' Stiletto extrusion. In shopping for new sails, I called Tom Haberman @ Aquarius Sails(mfgr of Supercats and ARC cats), and he expressed reservations about using this rig, designed for a 450 lb boat, on an 850 lb boat. And I do want to run a spin and/or hooter, and again, this mast was not designed for that. I do sail in a lot of light air, could this rig be used judiciously, reefing early(smaller high wind main?), not running spin/screacher over x knots? Keep the spin hlyd tang close to the hounds? Am I capable of the necessary restraint?
Opinions cheerfully entertained!
Dave
Re: SC20 tall rig on Stiletto 23? [Re: davefarmer] #141184
04/25/08 08:02 AM
04/25/08 08:02 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Dave,
You probably should also post on the Stiletto website. Lots of engineers, Stiletto people/designers there that are familiar with the Stiletto characteristics etc. Maybe Peter Wormwood would chime in.
Good luck,
Clayton
Re: SC20 tall rig on Stiletto 23? [Re: Clayton] #141185
04/25/08 09:59 AM
04/25/08 09:59 AM
WA, ID, MT
WA, ID, MT
Thanks Clayton, I have posted there, no response yet.
Dave
Re: SC20 tall rig on Stiletto 23? [Re: davefarmer] #141186
04/25/08 01:58 PM
04/25/08 01:58 PM
I
I20RI Offline
I20RI  Offline
I
I have an 85 stiletto 23. I'd be shocked if it actually weighed 850 pds. I think that is really optimistic. Myboat is kevlar/nomex and though I have never weighed the boat,I have moved the hulls around quite a bit. I have also talked to Peter about it quite a bit, I think the 23 is realistically closer to 1000 pds. My instinct says "bad idea", but i'm not an engineer. The loads on my boat are pretty extreme when shes powered up. certainly a lot more than on a sc 20. Dont forget, the 23 is almost 4' wider than the SC 20. So you'd be hanging 200 plus more pounds on a 4 foot longer lever when you are flying a hull, i'd be very worried.
Re: SC20 tall rig on Stiletto 23? [Re: I20RI] #141187
04/25/08 02:02 PM
04/25/08 02:02 PM
I
I20RI Offline
I20RI  Offline
I
Oh yeah, I have a 23 rig i'm not using. I replaced it with carbon. I cannibalized the spreaders and the mast step. I'd sell it to you, but I am all the way in RI.
Re: SC20 tall rig on Stiletto 23? [Re: I20RI] #141188
04/25/08 02:06 PM
04/25/08 02:06 PM
WA, ID, MT
WA, ID, MT
Did Forte build the mast for you? They mentioned making one recently and using the existing spreaders. Did you switch for weight reasons? Could you PM me with your phone#? Thanks!
Dave
Re: SC20 tall rig on Stiletto 23? [Re: davefarmer] #141189
04/25/08 03:02 PM
04/25/08 03:02 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Dave,
Where is the boat located? Is it named 'double up'?
Re: SC20 tall rig on Stiletto 23? [Re: flumpmaster] #141190
04/25/08 04:29 PM
04/25/08 04:29 PM
WA, ID, MT
WA, ID, MT
Outside of Houston somewhere. Tommy Granger's old boat. I thinks that's the name. What do you know?
Dave
0 registered members (), 521 guests, and 47 spiders.
