Rick White's Magnificent Pole #141696
05/01/08 11:05 AM
05/01/08 11:05 AM
roccats Offline OP
roccats  Offline OP
I recently aquired the Rick White Super Power Righting kit in the mail and was a bit confused as to how it is going to work.
The universal 3 axis joint for the pole seems to be free in all 3 axis. I assume the writing force is being taken by the line running to the "beam loops" rather than the pole. Is this correct?
If so what stops the line from running free ( or just slacking) and the pole from pivoting downards? Is it just the small stopped knot in the line? Are you then not able to dynamically adjust the angle of the pole since it is determiend by where the knot in the line is?
Is the righting line a single loop, starting tied off to one end of the pole, traveling through a beam loop, then across the cross beam, through the 2nd beam loop and then comming back to tie off on the pole again?
Any picture or even beter a schematic of the system would be a huge help. The pictures on catsailor are a bit hard to see exactly how everything is rigged.
Any help would be greatly appreciated!
Bimare Jav2 18HT
Re: Rick White's Magnificent Pole [Re: roccats] #141697
05/01/08 11:13 AM
05/01/08 11:13 AM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
I used to have one of these on an I-17R.
Yes.
The knot keeps tension on the line, and the pole angle is - as you said - predetermined by the knot location. I think my instructions said to tie a big knot, like a figure 16 or something.
This is exactly how mine worked.
One word of advice: when using this system be careful with your fore-aft movement, or you can pinch the pole against your dolphin striker.
Geoff
Re: Rick White's Magnificent Pole [Re: GeoffS] #141698
05/01/08 11:18 AM
05/01/08 11:18 AM
roccats Offline OP
roccats  Offline OP
This was exactly the help I needed. Thanks!
Bimare Jav2 18HT
Re: Rick White's Magnificent Pole [Re: roccats] #141699
05/02/08 07:52 AM
05/02/08 07:52 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
From my experience the rope is a triangle shape and should always be nice and tight and the stopper knots should be where they hold the pole at a comfortable angle above your head when righting. When you release the pole and it retracts it should miss the top hull even with the stopper knot in or you have set it too high and risk damaging the hull. The stopper knot will never slip with weight on it
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Rick White's Magnificent Pole [Re: GeoffS] #141700
05/02/08 10:49 AM
05/02/08 10:49 AM
Cutler Bay, Florida
Bajan_Bum Offline
Bajan_Bum  Offline
Cutler Bay, Florida
Geoff
Geoff, do you recommend the pole? Is there a real advantage over using the conventional rope?
Re: Rick White's Magnificent Pole [Re: Bajan_Bum] #141701
05/02/08 08:10 PM
05/02/08 08:10 PM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
It worked beautifully before I screwed up and pinched it against my dolphin striker. It is not stayed fore-aft, so you have to keep control of this axis yourself. The pole that came with my kit was (I think) a carbon windsurfer mast, and it collapsed at the point of contact. Totally my fault - I am an idiot. The pole is a great system, but my recommendation would probably be to start with a waterbag and see if that worked for you before considering the pole.
Geoff
Re: Rick White's Magnificent Pole [Re: GeoffS] #141702
05/03/08 07:40 PM
05/03/08 07:40 PM
Western New York
wyatt Offline
wyatt  Offline
Western New York
I have a Hobie 18 Magnum and I weigh 170 lbs. I was able to right the boat myself. The small limiter line is scary, but it does work. As far as the fore/aft problem, there is a limiter that you should have attached to the rear crossbar and it is held taut with a bungee line.
Wyatt
0 registered members (), 439 guests, and 51 spiders.
