| Re: back-friendly harness
[Re: Timbo]
#143652 05/21/08 12:44 PM 05/21/08 12:44 PM |
Posts: 164 fort Myers, FL | Timbo, from a biomechanical perspective the most efficient placement of the hook is closest to the body's Center of Mass (COM), which is located in front of the sacral bone (or S2). This happens to be the approximate location of the hook for most harnesses. The further you place the hook away from the COM, the more muscle action is needed to stabilize the body while on the wire, or more elaborate support mechanisms will be needed. If you would move the hook placement higher on the trunk, you would need more muscle activity of your lumbar extensors and other back stabilizers to stabilize your spine, and over the course of a day this would probably lead to more low back fatigue/pain.
Arie Hobie 16 111812
[Re: mbounds]
#143654 05/21/08 01:34 PM 05/21/08 01:34 PM |
Posts: 164 fort Myers, FL | Sorry....couldn't contain myself! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: mbounds]
#143655 05/21/08 01:34 PM 05/21/08 01:34 PM |
Posts: 6,049 Sebring, Florida. | Thanks Arie. Many years ago (1984) I had a windsurfing harness that had the hook up higher, near the chest, no butt support of course but I was thinking of something similar with a butt buckett as well as chest wrap around, put the hook half way between the two locations.
Blade F16 #777
[Re: Timbo]
#143656 05/21/08 01:43 PM 05/21/08 01:43 PM |
Posts: 2,584 +31NL | Tim: I don't think a waist windsurfing harness is going to work, with windsurfing you are mostly in an upright position. Maybe a seat trapeze harness will work, I would definetly try to wear mine in an emergency though: http://www.pro-limit.nl/displayitemv6comp.php?item_id=4482 | | | Re: back-friendly harness
[Re: Timbo]
#143657 05/21/08 01:48 PM 05/21/08 01:48 PM |
Posts: 164 fort Myers, FL | Yeah, I remember those... That could work, providing that there is contineous support of the spine along the back to prevent too much muscle action. One of the problems might be that this back support would need to be fairly rigid beween the chest piece and bucket, otherwise the area of the back opposite of where the hook is located would take a lot of loading. That rigidity that might make it more difficult to move around. Most windsurfers seem to have gone to lower placed hooks with the change in technique and technology.
[Re: Tony_F18]
#143658 05/21/08 03:16 PM 05/21/08 03:16 PM |
Posts: 6,049 Sebring, Florida. | I was thinking about one of the waist models but with a butt sewn on so it wouldn't slide up. Click on their "waist" models. Yeah, it might be to stiff to move around on the tramp when you have to snuff the spinn, etc.
Blade F16 #777
[Re: Timbo]
#143661 05/23/08 09:41 AM 05/23/08 09:41 AM |
Posts: 5,590 Naples, FL | Timbo,
Can't you run your shoulder strap adjustment loop over your PFD? I think I have that same harness (magic marine - the "pre" worrell name I believe), and I run the strap over the PFD on that side, so it's right there when I need to snug or loosen it...
But, all that adjusting does distract one from the sailing...
[Re: Dan_Delave]
#143667 05/28/08 03:57 PM 05/28/08 03:57 PM |
Posts: 3,348 | Pete: What is the picture telling us? What are we supposed to be paying attention to? Look where and how the trap line attaches to the harness. I appears to be a small line that goes from the hook to the shoulder straps. The attachment point seems to slide along that line. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> On second glance, that is just the trap bungy! Still, I think I'll try to cobble something together.
21,105
guests, and 1,028
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,137 29 minutes ago | | |
