Hobie 18 Righting System #145097
06/07/08 01:01 PM
06/07/08 01:01 PM
Ohio, Lake Erie, USA
flyhigh Offline OP
flyhigh  Offline OP
I sail a Hobie 18 myself on occasion and last year a big gust of wind rolled the boat over. I tried to right the boat by myself with the hawiian righting system and pointing the boat into the wind but I could only get the mast tip off of the water by about 6 inches. I weigh about 230 lbs. After a while another guy sailed over and helped me right the boat. Is there any other system that could be used to right the boat when saling alone?
Re: Hobie 18 Righting System [Re: flyhigh] #145098
06/07/08 03:18 PM
06/07/08 03:18 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Use the aid of a righting bag, they may sell them at the online store on this site.
Re: Hobie 18 Righting System [Re: Hullflyer1] #145099
06/07/08 11:22 PM
06/07/08 11:22 PM
I was able to right one with a 4to1 tackle and righting bag at 5' 11" 170lbs. If you just fill the bag up part way you should easily be able to through it over your shoulder and right it.
Your putting the righting line in you harness to take the strain off your hands right?
Re: Hobie 18 Righting System [Re: flyhigh] #145100
06/08/08 09:03 AM
06/08/08 09:03 AM
All over the SE
Ken_H Offline
Ken_H  Offline
All over the SE
The righting bag, looping the line around your trapeeze hook, and patience... Lean back and you will get it. Also make sure the mast is air tight. Worse case scenario (if you dont race) get a Hobie Bob take the easy way out...
Re: Hobie 18 Righting System [Re: flyhigh] #145101
06/10/08 11:04 AM
06/10/08 11:04 AM
Western New York
wyatt Offline
wyatt  Offline
Western New York
We go through this question a lot. After years of experimenting, we've finally added a Hobie Bob to stop the turtling; you can take it off for racing. We purchased a power pole; you can get one from Rick White. I weigh 170lbs and I can get the thing up by myself. Follow the instructions carefully. I would not compromise my front crossbar and drill through my tramp, we machined a different Pole mounting system to the dolphin striker and the mast extrusion post. Good Luck.
Re: Hobie 18 Righting System [Re: wyatt] #145102
06/10/08 11:25 AM
06/10/08 11:25 AM
I had a TheMightyHobie18 and agree the righting bag is the way to go... however i would NOT attach it to my trapeeze hook... i have a righting line and i have a truckers hitch (loop) in it where i hang my bag line.. After i fill the bag i pull it up out of the water and lean back on the line/bag... this will lift almost any beach cat. BTW it is MUCH cheaper to purchase the entire system than try to make it yourself.
0 registered members (), 4,837 guests, and 792 spiders.
