Rudder Alignment #146199
06/18/08 05:16 PM
06/18/08 05:16 PM
PeelSkid Offline OP
PeelSkid  Offline OP
How do you do a rudder alignment?
If rudders make a lot of whinning noise is this because of alignment or just going fast?
Re: Rudder Alignment [Re: PeelSkid] #146200
06/18/08 05:49 PM
06/18/08 05:49 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
If rudders make a lot of whinning noise...
Sometimes this will help:
Re: Rudder Alignment [Re: PeelSkid] #146201
06/18/08 10:45 PM
06/18/08 10:45 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Rudder hum at speed means you;re going slow <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
since your blades are shedding vortices off their trailing edges. You need close to 1/16" to completely remove hum and minimize drag.
Lots of production cats do not come with blades properly faired...it's easier/cheaper to make a blade with a fatter trailing edge than a high quality thin one.
I recommend fairing down the last 1/3 of the blade with progeressively finer grain wet/dry sanding. Ideally, you don't want an obvious angle right at the last 1/2" from the edge...but if that helps and you're not too concerned with getting ultimate performance, then go ahead and use the scissor method.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Rudder Alignment [Re: PeelSkid] #146202
06/19/08 11:06 AM
06/19/08 11:06 AM
V
Ventucky Red Offline
V
Think of it this way; noise = vibration, vibration = friction and friction = drag - and that's a drag!!!
Re: Rudder Alignment [Re: Ventucky Red] #146203
06/20/08 08:36 AM
06/20/08 08:36 AM
Ft Myers Beach, FL
walkefmb Offline
walkefmb  Offline
Ft Myers Beach, FL
I found my vibes in the bearing or washers between the rudder and the head. The damn sand wore enough of the material away to create a bit of play and thus a very annoying hummmmmmmmmm.
cedar tornado classic,
sunfish,
1972 morgan 27
optidad
0 registered members (), 2,424 guests, and 182 spiders.
