Shackles? Can someone advise me. #147776
07/02/08 08:06 PM
07/02/08 08:06 PM
Cincinnati, Ohio
Tri_X_Troll Offline OP
Cincinnati, Ohio
Currently I'm using the little stamped shackles that use a split ring to hold the pin in. Removing my 6:1 is a pain in the butt, I lose the split rings.
I'm much too cheap for the quick release pins, so I want to just order a couple D shackles that use a threaded pin. My question is, that when searching the Catsailor online store, I am seeing two different kinds. One with a "self locking non captive pin" and one with a "self locking captive pin."
Which one do I want? It looks like I need a 3/16 to hang my blocks. Honestly I probably don't need anything that heavy. My old seaways had these flimsy little stamped ones with a threaded pin.
http://store.catsailor.com/pc/viewPrd.asp?idproduct=8311
What about for attaching my jib tack to the chainplate? I figure I ought to have a couple spares.
Re: Shackles? Can someone advise me. [Re: Tri_X_Troll] #147777
07/02/08 08:06 PM
07/02/08 08:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
And when ordering from the store, I'm not seeing an option to select the size on these items.
Re: Shackles? Can someone advise me. [Re: Tri_X_Troll] #147778
07/02/08 09:00 PM
07/02/08 09:00 PM
without captive pins, you'll have the same problem as with the damnit-rings. Drop it in the sand and wave bye bye! Get shackles with captive pins whenever possible - the pins can only be loosened and slid back but will not come all the way out - the threads won't clear the through hole in the slack side. Sometimes, however, you might have clearance issues with the captive pin shackle and whatever you are pinning since some of the pin stays in the opening in the shackle.
Re: Shackles? Can someone advise me. [Re: Jake] #147779
07/02/08 09:39 PM
07/02/08 09:39 PM
Cincinnati, Ohio
Cincinnati, Ohio
hmmmm. I like the idea of the captive shackle, but......I don't think it will clear the round part on the block.
For the jib tack, will a 1/4" captive shackle clear the chain plate? Anyone have any experience with this. I see no need for the quick release.
On the class x, my grandparents used to tie a spare batten tie through the hole for the seizing wire and wrap it around the shackle.
Re: Shackles? Can someone advise me. [Re: Tri_X_Troll] #147780
07/03/08 07:08 AM
07/03/08 07:08 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
Sure.... go here:
http://www.wichard.com/documents/stainlessSteel.pdf
Scroll down to the 'shackles' page. There's a nice closeup pic of a locking pin. The nice thing about Wichard shackles is that when one opens the shackle, the pin recedes back into the 'slack' (to use Jake's term) side, so there is a full open I.D.
'Spensive? Yeah, but worth it... and if/when you sell the boat, just keep the Wichards if you want to.
Re: Shackles? Can someone advise me. [Re: Tri_X_Troll] #147781
07/03/08 10:14 AM
07/03/08 10:14 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
On my 6.0 I attach the main tackle using snap shackles top and bottom. Main system removes from the boat quickly. Put a wrap of tape around the pin part if you're worried about something catching and releasing them.
Re: Shackles? Can someone advise me. [Re: Keith] #147782
07/03/08 10:40 AM
07/03/08 10:40 AM
I attach S hooks (see image) to hang my blocks from the boom. I find a smap shackle best on the travler. It is fast and easy to attach and remove.
Re: Shackles? Can someone advise me. [Re: ] #147783
07/03/08 11:02 AM
07/03/08 11:02 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I've had an S-Hook open up (ended up looking more like a J) in a big gust with a fat head main on the 6.0. I'm guessing depending on the size of the main you might be fine with one, I don't trust them for that anymore.
Re: Shackles? Can someone advise me. [Re: Keith] #147784
07/03/08 11:12 AM
07/03/08 11:12 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
A shop magnet (on a stick) in the catbox is standard equipment just for this scenario <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Shackles? Can someone advise me. [Re: ThunderMuffin] #147785
07/03/08 11:16 AM
07/03/08 11:16 AM
maybe for a ringding...but 316 stainless isn't magnetic.
Re: Shackles? Can someone advise me. [Re: Keith] #147786
07/03/08 11:18 AM
07/03/08 11:18 AM
WOW.... i have used s-hooks for about 8 years, in several 30+ storms and NEVER seen one bend (I sail a Tornado squartop sail)
Re: Shackles? Can someone advise me. [Re: ] #147787
07/03/08 11:46 AM
07/03/08 11:46 AM
Portland, Maine
Portland, Maine
Yes its good for ringdings. I didn't mean shackle pins.
As for the s-hooks.. I have to concur on the bending. I've got them on my downhaul for my mainsail and they have to be replaced every season due to the fact that they get stretched.
Re: Shackles? Can someone advise me. [Re: ThunderMuffin] #147788
07/03/08 11:57 AM
07/03/08 11:57 AM
Perhaps i am using the bigger s-hooks (i know they come in 2 sizes)...
Re: Shackles? Can someone advise me. [Re: ] #147789
07/03/08 12:48 PM
07/03/08 12:48 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Start of the 2004 C-100, coming out of Galesville into the West River. Lots of carnage, we had the jib furled. As soon as we got to the river from the harbor a gust hit, and we heard a sound like a gunshot and suddenly the mainsheet system was no longer attached to the sail. We noodled across the river until we got into a small protected cove and we ditched the straightened out S-hook for a shackle. Continued on and ultimately won the race.
In the pic below, the red and white sail is us on our way to the cove - notice the sail is about 90 degrees to the boat.
I'm sure it doesn't happen often, but I don't want to chance it on a distance race anymore.
Re: Shackles? Can someone advise me. [Re: Keith] #147790
07/03/08 01:17 PM
07/03/08 01:17 PM
that's the third instance I've heard of it straightening out. Too much gorilla on the mainsheet! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Shackles? Can someone advise me. [Re: Jake] #147791
07/03/08 01:37 PM
07/03/08 01:37 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Mmmmm... Mongo like mainsheet!
Re: Shackles? Can someone advise me. [Re: Keith] #147792
07/03/08 02:11 PM
07/03/08 02:11 PM
Mongo changin out S-hooks
Re: Shackles? Can someone advise me. [Re: ] #147793
07/03/08 02:35 PM
07/03/08 02:35 PM
While you guys are doing the Tim Allen "man grunt" thing about your straightened S hooks, you failed to notice an important fact:
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
On a Hobie 16, you can't use anything but a small shackle on the top block and a pin on the lower block and still get as much mast rake as you really want.
Re: Shackles? Can someone advise me. [Re: mbounds] #147794
07/03/08 04:16 PM
07/03/08 04:16 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Ryan - H16
So, you mean we should be suggesting a single line external dead-ended at the traveler leading to a cascaded system internal to the boom with a mid-boom exit/sheeting point? Could probably get more rake, and nobody would steal it unless they took the whole boom... Doh! Might not be class legal....
<img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Shackles? Can someone advise me. [Re: Keith] #147795
07/03/08 09:15 PM
07/03/08 09:15 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Can you afford a piece of string with a loop to keep the dammit curl pin tied to the boat?
Think, I say again, Think Boy!
Dacarls:
1 registered members (FredL), 309 guests, and 23 spiders.
