couple pix from the Meigs #148671
07/07/08 07:16 AM
07/07/08 07:16 AM
Gulf Coast
tami Offline OP
tami  Offline OP
Gulf Coast
good on Sam n'em at FWYC... they worked VERY hard!
Results and more pictures soon at www.fwyc.org
Re: couple pix from the Meigs [Re: tami] #148672
07/07/08 07:55 AM
07/07/08 07:55 AM
What kind of main sail is that on that Nacra 20 - number 20?
Re: couple pix from the Meigs [Re: Jake] #148673
07/07/08 08:49 AM
07/07/08 08:49 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Ditto Jake's question AND in the first picture is it normal to connect the forstay chainplate offset like that?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: couple pix from the Meigs [Re: Chris9] #148674
07/07/08 08:55 AM
07/07/08 08:55 AM
does the rubber chicken work as a wind guage or is he there just for good cluck (i mean luck)
Re: couple pix from the Meigs [Re: Jake] #148675
07/07/08 09:20 AM
07/07/08 09:20 AM
Gulf Coast
tami Offline OP
tami  Offline OP
Gulf Coast
Jake: Not my boat. Ask Mark Smith.
Chris: Not my boat. Ask Marc Reiter.
Andrew: It is my chicken. That is The Wind Chicken, and it's MIZ Wind Chicken to you.
Re: couple pix from the Meigs [Re: Chris9] #148676
07/07/08 09:27 AM
07/07/08 09:27 AM
I didn't notice that - heck no! That's a failure waiting to happen.
Re: couple pix from the Meigs [Re: tami] #148677
07/07/08 09:29 AM
07/07/08 09:29 AM
Hello Miz, Say Hello to my "Little Friend" MR CHICKEN HAWK
Re: couple pix from the Meigs [Re: ] #148678
07/07/08 09:45 AM
07/07/08 09:45 AM
That "extreme square top" sail's got the Key Sailing logo on it. Perhaps someone over there could elaborate?
Re: couple pix from the Meigs [Re: waterbug_wpb] #148679
07/07/08 10:13 AM
07/07/08 10:13 AM
I can't believe Mark Smith would go with a non-class-legal mainsail?
Re: couple pix from the Meigs [Re: Jake] #148680
07/07/08 10:38 AM
07/07/08 10:38 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Check out the ncl jib with the mini squaretop. He usually sails with this setup at the OSYC events.
Philip
USA #1006
Re: couple pix from the Meigs [Re: tami] #148681
07/07/08 12:14 PM
07/07/08 12:14 PM
Gulf Coast
tami Offline OP
tami  Offline OP
Gulf Coast
results are posted
http://www.fwyc.org/RaceInfo.html
scroll down to Meigs, look on the far right, click results of interest
Re: couple pix from the Meigs [Re: Jake] #148682
07/07/08 12:32 PM
07/07/08 12:32 PM
Yes he would. Been talking about it for a while. Legal to do so in a Portsmouth event.
Re: couple pix from the Meigs [Re: John Williams] #148683
07/07/08 04:03 PM
07/07/08 04:03 PM
I thought a lot of portsmouth events have a rule about having boats sail with equipment legal within their classes though. I thought I saw that language for the RTI NOR.
Can' find it now though. You certainly know more about this than I do so maybe I was mistaken.
Edit:
found it: but this is for the RTI in the SIs
Modified and non class competitors must abide by their
applicable or Portsmouth Ratings including modification factors.
So would Smith have to take a modification hit?
Re: couple pix from the Meigs [Re: PTP] #148684
07/07/08 04:29 PM
07/07/08 04:29 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Yes, Mark would have taken the larger than class legal main hit "ML" modifier since the jib appears to be the same size there is no hit for that.
DPN*ML = 59.3*.98=58.114
But if the main is the same sail area (within 5%) and just a different cut he should take the MN hit. DPN*MN = 59.3*.995 = 59.0035 it's more likely this is the modifier used. If you're a numbers player it's a small hit for an updated sailplan.
Isn't DPN fun.
F18 USA 242
http://www.solarwind.solar
Re: couple pix from the Meigs [Re: PTP] #148685
07/07/08 04:29 PM
07/07/08 04:29 PM
Read the modification - if he's within 5% of the class legal sail area, then there's no hit.
Mark said he'd never use those sails in a class event, of course.
I'm a friend of Mark's. He was my first long-term skipper in catamarans and he's made incalcuable contributions to catamaran sailing in the Panhandle. I think, however, that gaming the numbers is poor sportsmanship. In Mark's defense, I'll say that he's only following others' examples.
Re: couple pix from the Meigs [Re: John Williams] #148686
07/07/08 04:32 PM
07/07/08 04:32 PM
Clermont, FL, USA
Clermont, FL, USA
Nope, that aint quite right boss
MN - For non-class legal mainsail, of same sail area or less than class legal mainsail (formerly square top adjustment)
F18 USA 242
Re: couple pix from the Meigs [Re: John Williams] #148687
07/07/08 04:38 PM
07/07/08 04:38 PM
I know Mark also... good guy.
Re: couple pix from the Meigs [Re: David Ingram] #148688
07/07/08 04:40 PM
07/07/08 04:40 PM
Reno NV
Rhino1302 Offline
Rhino1302  Offline
Reno NV
There's no official modification factor for non-class legal Jib of the same area or less, but it's an obvious improvement over class legal the RC should invent one.
Any other deviations from standard class configurations, including the addition of wings, can be assessed a penalty of at least 0.995. Multiple deviations may incur multiple penalties. Penalties may be greater than 0.995. Please identify any such modifications and penalties assigned and include with results reported to the handicap committee and Portsmouth Numbers Committee.
Re: couple pix from the Meigs [Re: Rhino1302] #148689
07/07/08 04:45 PM
07/07/08 04:45 PM
Clermont, FL, USA
Clermont, FL, USA
sigh...
F18 USA 242
Re: couple pix from the Meigs [Re: David Ingram] #148690
07/07/08 06:21 PM
07/07/08 06:21 PM
You're right, of course, Dave. It is a 0.995 hit. The hit for sail area greater than 5% is 0.980.
For ease of reference, a N20 rates 59.3. Mark's rating, if he's not taking any mods on the jib, is 59.0. Unless his sail is really more that 5% bigger, which would rate him 58.1, almost the same as the M20.
Quick Sailwave run; Mark owes a stock 20 about 31 seconds an hour, while the "large" main owes the stock 20 just over two minutes an hour.
1 registered members (vasil), 372 guests, and 39 spiders.
