H 16 jib question #149582
07/15/08 08:12 AM
07/15/08 08:12 AM
Eastern Massachusetts
swanbike57 Offline OP
My jib flaps and sounds like a motor boat or helicopter in moderate air. (15-20 kts.) My sails are old, not crisp. The boat is old too, hull number 2479 I think, but the spars are from a newer boat, black anodized, no comp tip. Should I use a higher hole in the plate in the lower rear corner of the jib or is all to do with how tight the jib sheet is set? I have been keeping the jib traveler cars way out by the corner castings.
Re: H 16 jib question [Re: swanbike57] #149583
07/15/08 10:17 AM
07/15/08 10:17 AM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
I sail solo much of the time and leave the jib travelers in close to the mast. I seldom have them traveled out as far as you do except when going downwind. The jib shouldn't be acting the way you describe. Set it by the teltales the same way you would set the main, both sides streaming back.
Howard
Re: H 16 jib question [Re: swanbike57] #149584
07/15/08 05:22 PM
07/15/08 05:22 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
On all points of sail?!?! The cars need to be all the way in on a beat. Move them out to the castings on a reach or run.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: H 16 jib question [Re: hobie1616] #149585
07/16/08 12:04 PM
07/16/08 12:04 PM
Coopersburg, PA
V
Vinny_M Offline
Vinny_M  Offline
V
Coopersburg, PA
I had flapping on my jib too when I first got my boat. The problem was due to the battens being too short, make sure the battens are sticking out of the jib a little bit, or maybe they are broken?
~vinny~
Re: H 16 jib question [Re: swanbike57] #149586
07/16/08 01:53 PM
07/16/08 01:53 PM
Other than your issue with the jib traveller cars, that's your real problem.
The leech of the jib is the first thing to blow out.
Re: H 16 jib question [Re: swanbike57] #149587
07/18/08 12:40 PM
07/18/08 12:40 PM
California
Skipshot Offline
Skipshot  Offline
California
I had the same problem and fixed it with a new jib. Let it go. . .
0 registered members (), 280 guests, and 40 spiders.
