| I20 Dagger board trunks cushion tape #152514 08/13/08 03:25 PM 08/13/08 03:25 PM |
Posts: 99 Chicago, IL | I’m looking for the “cushion tape” (for the lack of better word) used in dagger board trunks in I20. I looked in online store on this website and Murray’s and I can not find one.
Thanx
I20
| | | Re: I20 Dagger board trunks cushion tape
[Re: Krisu13]
#152515 08/13/08 03:43 PM 08/13/08 03:43 PM |
Posts: 1,152 tampa, fl | I went to a local hardware store and purchased a roll of Velcro tape. Used the fuzzy side in the trunk on my N20. Works great!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: I20 Dagger board trunks cushion tape
[Re: Krisu13]
#152516 08/13/08 03:44 PM 08/13/08 03:44 PM |
Posts: 3,528 Looking for a Job, I got credi... | Is your stuff the same in Laser Daggerboard trunks? If so look for Slegel tape (it might be Schlegel tape)
I've used it in my inter 17 with no problems
F16 - GBR 553 - SOLD I also talk sport here | | | Re: I20 Dagger board trunks cushion tape
[Re: scooby_simon]
#152517 08/13/08 04:18 PM 08/13/08 04:18 PM | Anonymous
| Anonymous
Unregistered | i recently used 2 sided tape that has a soft foam center (almost sounds like an oreo ad) about 1/8" of thickness to cushon my centerboards.
i simpy left the tape on one side. it works perfect, but not sure if my discription will explain what the tape is... or if it will help you in your application. | | | Re: I20 Dagger board trunks cushion tape
[Re: Krisu13]
#152518 08/13/08 04:51 PM 08/13/08 04:51 PM |
Posts: 12,310 South Carolina | I use regular cheap-o carpet from a home improvement box store, cut a strip, and glue it in with Windshear (that stuff glues anything). I tried contact cement and it makes it impossible to install properly and doesn't hold well if you put it in all wet and gooey.
Jake Kohl | | | Re: I20 Dagger board trunks cushion tape
[Re: Krisu13]
#152519 08/13/08 05:12 PM 08/13/08 05:12 PM |
Posts: 1,203 uk | I used a strip of fuzzy draught excluder that goes between the sliding sections of a UPVC patio door!
[Re: TEAMVMG]
#152520 08/13/08 05:43 PM 08/13/08 05:43 PM |
Posts: 1,403 | | | |
2,546
guests, and 300
