I20 Dagger board trunks cushion tape #152514
08/13/08 03:25 PM
08/13/08 03:25 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
I’m looking for the “cushion tape” (for the lack of better word) used in dagger board trunks in I20. I looked in online store on this website and Murray’s and I can not find one.
Thanx
I20
Re: I20 Dagger board trunks cushion tape [Re: Krisu13] #152515
08/13/08 03:43 PM
08/13/08 03:43 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I went to a local hardware store and purchased a roll of Velcro tape. Used the fuzzy side in the trunk on my N20. Works great!
Re: I20 Dagger board trunks cushion tape [Re: Krisu13] #152516
08/13/08 03:44 PM
08/13/08 03:44 PM
Is your stuff the same in Laser Daggerboard trunks? If so look for Slegel tape (it might be Schlegel tape)
I've used it in my inter 17 with no problems
Re: I20 Dagger board trunks cushion tape [Re: scooby_simon] #152517
08/13/08 04:18 PM
08/13/08 04:18 PM
i recently used 2 sided tape that has a soft foam center (almost sounds like an oreo ad) about 1/8" of thickness to cushon my centerboards.
i simpy left the tape on one side. it works perfect, but not sure if my discription will explain what the tape is... or if it will help you in your application.
Re: I20 Dagger board trunks cushion tape [Re: Krisu13] #152518
08/13/08 04:51 PM
08/13/08 04:51 PM
I use regular cheap-o carpet from a home improvement box store, cut a strip, and glue it in with Windshear (that stuff glues anything). I tried contact cement and it makes it impossible to install properly and doesn't hold well if you put it in all wet and gooey.
Re: I20 Dagger board trunks cushion tape [Re: Krisu13] #152519
08/13/08 05:12 PM
08/13/08 05:12 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
I used a strip of fuzzy draught excluder that goes between the sliding sections of a UPVC patio door!
Re: I20 Dagger board trunks cushion tape [Re: TEAMVMG] #152520
08/13/08 05:43 PM
08/13/08 05:43 PM
V
Ventucky Red Offline
V
Re: I20 Dagger board trunks cushion tape [Re: Ventucky Red] #152521
08/13/08 07:16 PM
08/13/08 07:16 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
Thanx everyone for the fast reply.
I will go with boars carpet form http://www.apsltd.com/
Kris
I20
Re: I20 Dagger board trunks cushion tape [Re: Krisu13] #152522
08/13/08 10:22 PM
08/13/08 10:22 PM
We used carpet at the top and this stuff at the bottom
Re: I20 Dagger board trunks cushion tape [Re: _flatlander_] #152523
08/14/08 09:47 AM
08/14/08 09:47 AM
Andrew Offline
Andrew  Offline
Dr. Scholl's!
0 registered members (), 22,119 guests, and 476 spiders.
Yesterday at 04:54 AM
