| Re: Nets or cloth trampolines?
[Re: ncik]
#154084 09/05/08 02:48 AM 09/05/08 02:48 AM |
Posts: 3,528 Looking for a Job, I got credi... | Another one may be that a beach cat you may be wiring and so you need a surface that can handle "sidways" movement as well as up and down. I can see all sorts of damage from trying to slide across netting.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Nets or cloth trampolines?
[Re: harryproa]
#154086 09/05/08 09:04 AM 09/05/08 09:04 AM |
Posts: 778 Houston | Many one design cats have a rule that precludes you from using any non-woven material for the tramp. For example, the story I heard was, it's banned on the Tornado because no one wanted to use it but it it can be an advantage under some conditions. If you want a sort of net, there is a knitted dacron fabric ( http://www.sailrite.com/Categories/Trampoline-Mesh_2).It's soft, net like and works well. HOWEVER, it's very UV sensitive. Even protected from the sun it may only last 2 years. There is also a perforated vinyl (like a solid Hobie tramp with lots and lots of holes in it) but I have not seen that material in years Everytime I buy or build a trampoline, I look around, think about it, and decide to use some form of polypro mesh. It's light, durable, and strong. Now if someone makes that knitted fabric out of polypro, I might, reconsider | | | Re: Nets or cloth trampolines?
[Re: harryproa]
#154087 09/05/08 09:55 PM 09/05/08 09:55 PM |
Posts: 1,307 Asuncion, Paraguay | G'day,
Has anyone any experience of using net instead of trampolines on a beach cat? Or know why big boats use net and little ones cloth? Seems it would be less windage when flying a hull, although maybe more drag when sailing flat?
any input appreciated.
regards,
Rob If it wasn't for OD rules, all beach cats would use nets. Take a look here for knotless dyneema nets that need no reinforcement in the edges and are the lighter, stronger and simpler thing you will find.
Luiz
[Re: Luiz]
#154088 09/07/08 07:01 PM 09/07/08 07:01 PM |
Posts: 12,310 South Carolina | G'day,
regards,
Rob If it wasn't for OD rules, all beach cats would use nets. Take a look here for knotless dyneema nets that need no reinforcement in the edges and are the lighter, stronger and simpler thing you will find. There's nothing holding back the a-cats and they're still using poly-pro.
Jake Kohl | | | Re: Nets or cloth trampolines?
[Re: Luiz]
#154089 09/08/08 02:26 AM 09/08/08 02:26 AM |
Posts: 3,528 Looking for a Job, I got credi... | G'day,
regards,
Rob If it wasn't for OD rules, all beach cats would use nets. Take a look here for knotless dyneema nets that need no reinforcement in the edges and are the lighter, stronger and simpler thing you will find. Are you sure? I for one would not think that you would be able to slide along the tramp like I can on my currnet one when tacking.
[Re: Luiz]
#154090 09/08/08 09:15 AM 09/08/08 09:15 AM | Anonymous
| Anonymous
Unregistered | If it wasn't for OD rules, all beach cats would use nets. There are MANY cat sailors who dont race, nor care about OD rules that dont use nets (ME) | | | Re: Nets or cloth trampolines?
[Re: ]
#154091 09/08/08 04:20 PM 09/08/08 04:20 PM |
Posts: 1,307 Asuncion, Paraguay | If it wasn't for OD rules, all beach cats would use nets. There are MANY cat sailors who dont race, nor care about OD rules that dont use nets (ME) I stand corrected. People have different preferences. I think nets are preferable because they are lighter, drain faster and reduce windage, thus making the boat safer, But that's just me.
Luiz
[Re: PTP]
#154093 09/10/08 12:54 AM 09/10/08 12:54 AM |
Posts: 1,307 Asuncion, Paraguay | aside from sunrise (multihullnets.com) anyone know where to find this netting or something similar? Holes need to be 3/8inch or so This seems to be (blue) coated knotless polyester, almost the same as the dyneema version. I believe you can find it in the same place, Net Systems, Seattle.
Luiz
[Re: Luiz]
#154094 09/10/08 06:21 AM 09/10/08 06:21 AM |
Posts: 12,310 South Carolina | aside from sunrise (multihullnets.com) anyone know where to find this netting or something similar? Holes need to be 3/8inch or so This seems to be (blue) coated knotless polyester, almost the same as the dyneema version. I believe you can find it in the same place, Net Systems, Seattle. We use some of that on our machinery we build...that weave and pattern in polyester is equivalent to 20 grit sandpaper. It's VERY rough. It's also very "springy" and would be difficult to get it reasonably tight for a trampoline application.
#154096 09/10/08 07:03 PM 09/10/08 07:03 PM |
Posts: 2,921 Michigan | It's also very "springy" and would be difficult to get it reasonably tight for a trampoline application. It is for the 31 and I don't keep them very tight- you have to loosen them to fold the boat up anyway then re-tighten them. kind of painful if you do it with any sort or regularity. looking for winter projects... | | | Re: Nets or cloth trampolines?
[Re: PTP]
#154097 09/10/08 07:17 PM 09/10/08 07:17 PM |
Posts: 308 Reno NV | | | | Re: Nets or cloth trampolines?
[Re: ncik]
#154099 09/10/08 10:20 PM 09/10/08 10:20 PM |
Posts: 1,307 Asuncion, Paraguay | I don't think nets would reduce windage while sailing, ie. at high speeds with wind flow along the length of the net. They would be less windage at low wind speeds with the wind going through the net, ie. when capsizing. Exactly. Windage isn't helpful when the boat heels.
Luiz
[Re: PTP]
#154100 09/10/08 10:28 PM 09/10/08 10:28 PM |
Posts: 1,307 Asuncion, Paraguay | Ian Farrier recommends wider net openings. He is concerned with the boat taking off in a storm, even if grounded.
Luiz
1 registered members (FredL),
446
guests, and 68
