Where can you get carbon rudders for Infusion #156073
09/28/08 09:58 AM
09/28/08 09:58 AM
Budapest, Hungary, Europe
CatSailingHu Offline OP
A friend of mine looking for carbon rudders for his nacra infusion, and asked me to find a pair. Any idea where?
Sanyi
Nacra Infusion
www.catsailing.hu
Re: Where can you get carbon rudders for Infusion [Re: CatSailingHu] #156074
09/28/08 09:31 PM
09/28/08 09:31 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Carbon rudders? They are carbon, not sure if they are 100% carbon, probably not. If you want a carbon looking rudder just ask Performance to make some with clear gelcoat.
Re: Where can you get carbon rudders for Infusion [Re: pitchpoledave] #156075
09/29/08 06:32 AM
09/29/08 06:32 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
or sand the gel coat off and add carbon.
Re: Where can you get carbon rudders for Infusion [Re: CatSailingHu] #156076
09/29/08 09:00 PM
09/29/08 09:00 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
At the carbon store you big lug! Gosh......
Re: Where can you get carbon rudders for Infusion [Re: arbo06] #156077
09/30/08 05:41 AM
09/30/08 05:41 AM
thanks to all for the answers.
special thanks to arbo06...
Sanyi
Nacra Infusion
www.catsailing.hu
Re: Where can you get carbon rudders for Infusion [Re: CatSailingHu] #156078
09/30/08 03:44 PM
09/30/08 03:44 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Hi Sanyi,
Have you tried to contact Andras about the foils ? He was of great help for me and I remember that he mentioned something about carbon foils at one point (like making them in Hungary).
Florin
Re: Where can you get carbon rudders for Infusion [Re: isvflorin] #156079
09/30/08 04:49 PM
09/30/08 04:49 PM
Maybe a dumb question but why would you want carbon rudders on an Infusion?
IMHO the standard ones are fine as they are and are already reinforced with carbon.
If his money is burning a hole in his pocket tell him so send it to me <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Where can you get carbon rudders for Infusion [Re: CatSailingHu] #156080
09/30/08 06:33 PM
09/30/08 06:33 PM
arbo06 Offline
arbo06  Offline
smooooooch! Good luck though.
Re: Where can you get carbon rudders for Infusion [Re: Tony_F18] #156081
10/01/08 02:33 AM
10/01/08 02:33 AM
Hi Tony, of course not a dumb question. The stocks ones work fine for me, so
- I'm not want to replace my rudders --> but a friend.
- He think about it because the stock ones he got are really noisy over 8-10kts
- I recommended he to sand the trailing edge of the foils, a bit asymmetrical, he tried, but it became even noisy. Today he will try it reshape again, like THIS.
- He think a stiffer rudder will not resonate, so it is also an option.
- Otherwise I had no information about the stock ones are reinforced.
regards
Sanyi
Sanyi
Nacra Infusion
www.catsailing.hu
Re: Where can you get carbon rudders for Infusion [Re: CatSailingHu] #156082
10/01/08 03:03 AM
10/01/08 03:03 AM
Australia
macca Offline
macca  Offline
Australia
Actually, a stiffer rudder will resonate more!
you just need to make the trailing edge a bit thinner, I do it with all my blades and it takes about 30 seconds per blade, so no excuses.
________________________
http://aus300.blogspot.com
Re: Where can you get carbon rudders for Infusion [Re: macca] #156083
10/01/08 07:48 AM
10/01/08 07:48 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Thanks for linking that article. It gives me a good place to start finding out where my problems with screaming boards are and how to fix em.
Re: Where can you get carbon rudders for Infusion [Re: CatSailingHu] #156084
10/01/08 02:30 PM
10/01/08 02:30 PM
I've had some success with noisy foils by eliminating some of the hollow in the rear of the foil shape giving them more of a traditional shape. I don't know if the hollows were intentional or not. To see if you have them, hold a straight eged horizontally against the foil (in the direction water will flow). If you see a point where the foil pulls away from the straight edge leaving a "hollow", fill it and fair it.
Re: Where can you get carbon rudders for Infusion [Re: macca] #156085
10/01/08 04:07 PM
10/01/08 04:07 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Thinner?
Re: Where can you get carbon rudders for Infusion [Re: Jake] #156086
10/02/08 09:02 AM
10/02/08 09:02 AM
Australia
macca Offline
macca  Offline
Australia
The hollow in the rear section of the foil is there for a reason!
If you change it you are reducing the "grip" of the water on the blade.
Just file the training edge a bit thinner and then look after it.
