| Re: n20 mast
[Re: ThunderMuffin]
#161305 11/24/08 05:35 PM 11/24/08 05:35 PM |
Posts: 1,121 Eastern NC, USA | Can you use your old rotator system on the new mast? Seems like you could with a little "tweaking".
Tom | | | Re: n20 mast
[Re: hokie]
#161306 11/24/08 05:48 PM 11/24/08 05:48 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | I do not understand all the complaining about the alu mast, for months now, a lot of people were discussing the high price of the carbon mast. now there is a new alu mast to overcome the problem and now this... i'm lost here
personally I'm upset because it doesn't appear that they made ANY effort to find a different carbon mast supplier that could supply the SAME mast for a more reasonable cost that wouldn't obsolete every sail in my inventory! | | | Re: n20 mast
[Re: Kennethsf]
#161308 11/24/08 06:04 PM 11/24/08 06:04 PM |
Posts: 3,224 Roanoke Island ,N.C. | I do not understand all the complaining about the alu mast, for months now, a lot of people were discussing the high price of the carbon mast. now there is a new alu mast to overcome the problem and now this... i'm lost here If you've got a Ferrari with an engine problem do you replace said engine with a prius engine. Masts don't get broken often but for most of us the thought of $11,000 for a new one limits how hard your willing to push it. I have no problem with the Aluminum mast if all you have to change is the main, as long as it's competitive. I only have 4 I-20 mains that would be useless, which kinda sucks ,but I can replace all my mains and the mast for less than the carbon mast.I guess I can make duffle bags out of 'em. We'll see what shakes out, if it lowers the price of the boat, stays as fast, and gets more people sailing them it's a good thing. Todd p.s. Tad, your fortune telling skills suck. You shoulda just asked Will! And Tad Jack said he made an effort to find a builder, I just don't know how much effort.
| | | Re: n20 mast
[Re: macca]
#161317 11/24/08 08:36 PM 11/24/08 08:36 PM |
Posts: 2,490 On the Water | Thanks for the information Andrew, Is there a new mainsail cut or are you using the old stock setup? . . . and, in testing, have you raced the alloy rig against the classic carbon? If so, how much? Again thanks for the updates.
Philip USA #1006 | | | Re: n20 mast
[Re: macca]
#161320 11/24/08 08:54 PM 11/24/08 08:54 PM |
Posts: 3,116 Annapolis, MD | How much does it weigh.... how much more then the carbon stick..... Is it on par with the Tornado tear drop alu stick of old or closer to the back breaking nacra 6.0 NA stick ?
(you need to know when to run when they ask for help in raising the stick)
crac.sailregattas.com
| | | Re: n20 mast
[Re: FLL]
#161321 11/24/08 08:57 PM 11/24/08 08:57 PM |
Posts: 3,224 Roanoke Island ,N.C. | Have I-20s always had carbon mast? Si!
| | | Re: n20 mast
[Re: P.M.]
#161332 11/24/08 09:29 PM 11/24/08 09:29 PM |
Posts: 1,021 Australia | Thanks for the information Andrew, Is there a new mainsail cut or are you using the old stock setup? . . . and, in testing, have you raced the alloy rig against the classic carbon? If so, how much? Again thanks for the updates. Th mainsail cut was changed to suit the new style mast, but it would be possible to recut the luff curve on an old sail to get it to work pretty well with the new mast. testing as done with old v's new and the difference was negligible pretty much straight away. | | | Re: n20 mast
[Re: Mark Schneider]
#161344 11/25/08 12:15 AM 11/25/08 12:15 AM |
Posts: 12,310 South Carolina | How much does it weigh.... how much more then the carbon stick..... Is it on par with the Tornado tear drop alu stick of old or closer to the back breaking nacra 6.0 NA stick ?
(you need to know when to run when they ask for help in raising the stick) I'm assuming that the extrusion is the same as on the Nacra Infusion...and if that is the case, I would not be surprised if the mast is nearly the same weight as the current carbon mast. Nacra made a huge reduction in the aluminum mast weight with the Infusion. The carbon mast on the I20 is very heavy compared to modern carbon laminations....it's old school carbon.
Jake Kohl | | | Re: n20 mast
[Re: Chris9]
#161364 11/25/08 07:22 AM 11/25/08 07:22 AM |
Posts: 1,226 Atlanta | has a carbon 20 mast been successfully repaired? yes. | | | Re: n20 mast
[Re: macca]
#161365 11/25/08 07:26 AM 11/25/08 07:26 AM |
Posts: 3,224 Roanoke Island ,N.C. | I think Mike Krantz told me it was less than 10 lbs. difference.I do like the section shape better,lot more chord length.It'll be interesting to see the price. Todd
473
guests, and 528
