| Mast corrosion help #162131 12/06/08 11:12 PM 12/06/08 11:12 PM |
Posts: 291 | I am moving my spreaders (newer style) from my old Tiger mast to my new one and have noticed a decent amount of corrosion between the spreader and stainless bracket as well as where the stainless clevis pins that hold the spreader to the bracketa are. I am surprised by the amount of corrosion given the spreaders are less than a year old. Has anyone experienced this and if so what remedies to prevent it are there since stainless and aluminum are on opposite ends of the galvanic scale?
| | | Re: Mast corrosion help
[Re: JACKFLASH]
#162154 12/07/08 11:23 AM 12/07/08 11:23 AM |
Posts: 3,224 Roanoke Island ,N.C. | Tef-gel where you can put it, will go along way to help. Try to rinse with fresh water as often as possible.
[Re: Team_Cat_Fever]
#162174 12/07/08 09:19 PM 12/07/08 09:19 PM |
Posts: 291 | Tef-Gel sure is pricey. Anybody have experience with Lanocote? Looks a little more cost effective if it actually works.
[Re: JACKFLASH]
#162177 12/07/08 09:28 PM 12/07/08 09:28 PM |
Posts: 3,224 Roanoke Island ,N.C. | Only a $1.00 an ounce more if you get it from Layline/Mike Krantz. Rick may carry it also. It comes in a nice syringe w/ a brush. I just had a front beam bolt break off upon removal. I had used some other anti galv. spray. After peeling the forward deck off ,re-seating the backing plate, paying $17 for a new bolt, and putting my now chipped all up ,foredeck back on, I'd have paid alot more to have had it in there. You can bet it is now. Todd
[Re: ncik]
#162200 12/08/08 04:55 AM 12/08/08 04:55 AM | Scarecrow
| Scarecrow
Unregistered | I've used sail repair tape for both this (with duralac) and potential wear areas (ie spinnaker bail)
[Re: ]
#162207 12/08/08 09:08 AM 12/08/08 09:08 AM |
Posts: 291 | Great idea with the tape. Maybe a wrap of tape around the spreader end before inserting into the bracket along with the Tef-Gel on the screw and clevis pin will do the trick. I admit that I am partially to blame as the boat gets a good rinse off after use the mast may not be so lucky. I know now.
625
guests, and 166
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
