| Re: Mainsheet / traveller routing question
[Re: PTP]
#163931 01/03/09 09:36 PM 01/03/09 09:36 PM |
Posts: 3,224 Roanoke Island ,N.C. | Hey Harry, I had mid boom sheeting and when I sheeted it would inevitably pull the boom farther than needed. It was almost like just tying a line to the boom and pulling it around. My set-up wasn't super refined , it was harken bullets and such, but I think if I try anything else it will be center/tramp sheeting or maybe both rear and tramp. Todd
[Re: Team_Cat_Fever]
#163956 01/04/09 11:18 AM 01/04/09 11:18 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | "DAAPLOY ZE JAANNNAAAKKKEERRR" I promised JC that'd I'd be standing up at the A mark rounding yelling this at the top of my lungs. :P | | | Re: Mainsheet / traveller routing question
[Re: Learning to Fly...]
#164052 01/05/09 12:27 PM 01/05/09 12:27 PM |
Posts: 3,293 Long Beach, California | Sorry your thread got hijacked there, bud. As for your questions, I think just about everyone ties the end of the traveler to the end of the mainsheet if they have separate lines. The knot is usually tied at a point to allow almost maximum traveler play to keep the traveler car from exploding by impacting the stops on either side of the boat. I use a single line with a figure-eight tied at that point - there really isn't much difference.
I wonder, from your questions, if perhaps your mainsheet might be too short. With the main and traveler connected, you should be able to sit and trim from the front beam in light airs, to being fully trapped while up near the front beam in marginal conditions. There shouldn't be any tension from the retainer bungee in these positions - that is your maximum distance. Trapping out in the normal skipper position should leave you with some slack either on the tramp or in your lap.
In most conditions while close-hauled, you will have the traveler centered and play the mainsheet. If it is connected to the traveler or you have a single line for both, then it is easy to fish up the traveler to drop the car an inch (or more) if the wind really picks up.
For reaching in most conditions, you can ease the traveler a couple of inches (probably a little more since your Nacra has a boomless mainsail), trap out and continue to play the mainsail. A sharp crew can help out a lot by either having the traveler in hand when it's woolly, or help control pitch by playing the jib to keep max speed.
Down wind, your traveler position really depends on the type of boat and the conditions. Boats that have booms and spinnakers might ease the traveler significantly when rounding the windward mark, but often it is centered again shortly after the spinnaker is hoisted and trimmed. Boomless rigs like the Wave (if equipped with the optional traveler) certainly ease it to the fullest extent. There's a lot of variation in between. What are you sailing? Re-read the first paragraph on page 87 of Rick's book and keep in mind that it was written some time ago. I think the second sentence, "however, the best way..." is more important than the first sentence "...just inside the leeward hull" in most circumstances.
To trim the main down wind, I know guys who only hold the traveler. This is more of a gross adjustment, however. I have been seeing more and more skippers that never cleat the main down wind, and work it quite aggressively throughout the leg.
Hope that helps and that more folks weigh in to get you going as fast as you want to go.
[Re: John Williams]
#164054 01/05/09 01:22 PM 01/05/09 01:22 PM | andrewscott
| andrewscott
Unregistered | I tie my trav/main together
I cleat my main upwind... i keep it in hand, with a little tention.. so all i need is a flick to undo it | | | Re: Mainsheet / traveller routing question
[Re: HMurphey]
#164067 01/05/09 03:20 PM 01/05/09 03:20 PM | andrewscott
| andrewscott
Unregistered | i keep most of the mainsheet inboard without any bungie/rings, and about 4 feet in my lap/across my legs. this keeps the line out of the water most of the time.
I can always get to the travler line if needed (they are tied together)
[Re: ]
#164095 01/05/09 08:28 PM 01/05/09 08:28 PM |
Joined: Jan 2009 Posts: 43 NQLD, Australia Learning to Fly... OP
Posts: 43 NQLD, Australia | In response to John Williams, I sail a NACRA 4.5 (different to the American NACRA 450), 4.5 has 188 vs 165sqft and it is slightly lighter. I am in my first year of sailing, generally club racing it with a sloop rig, single handed. For the occasions I sail with crew I add a spinnaker off a 14sq.
Ever since I have had the boat the ratchet for the main has been seized. I have gotten into the habit of doing the coarse adjustment with the main then going out on the trap with the traveller for fine adjustment. I am about to buy a new Harken automatic ratchet triple, replace all the lines and then will relearn the correct technique.
Jon
#164102 01/05/09 09:47 PM 01/05/09 09:47 PM |
Posts: 3,293 Long Beach, California | Send your seized blocks back to Harken - they love to get that stuff to figure out why it failed. That improves the product for all of us down the road.
The 4.5 with a 'chute must be a lot of fun, Jon. Good on ya. I used to sail a 5.0 with a 'chute once-upon-a-time...
#164115 01/05/09 10:53 PM 01/05/09 10:53 PM | andrewscott
| andrewscott
Unregistered | Ever since I have had the boat the ratchet for the main has been seized.
WOW... sounds like you will be really happy with new gear | | |
4,331
guests, and 637
