| Spinlock pictured on homepage.... #16465 02/18/03 11:12 AM 02/18/03 11:12 AM |
Joined: Jul 2001 Posts: 2,844 42.904444 N; 88.008586 W Todd_Sails OP
Posts: 2,844 42.904444 N; 88.008586 W | I think it's a ronstan, anyway, when I retorfitted my N6.0 with a snuffer rig, I used one like this for the spin halyard. The second time I used it, it wouldn't hold the sheet in heavy air!
Now, I do use some kind of high tech, no stretch line, expensive line ( can't 'member the name)
I took it back to West Marine, and got one, that looked the same size, by the same manufacturer, but, on the top of the cleat, it has the word 'ALLOY' stamped on it in plain sight.
I'm not slamming anything here, just relating personal experience.
The current one, by the same manufacturer, works GREAT!
F-18 Infusion #626- SOLD it!
| | | Re: Spinlock pictured on homepage....
[Re: Todd_Sails]
#16467 02/18/03 12:35 PM 02/18/03 12:35 PM |
Joined: Jul 2001 Posts: 290 Pensacola, Florida / Katy, Tex... Cookie Monster
Posts: 290 Pensacola, Florida / Katy, Tex... | Todd,
The Spinlocks are great, but be careful with heavy loads and small line. You may want to think about sewing on a sleeve of bigger diameter line (about a foot long), just where the cam bites the line. This gives a much better bite and will help keep it from slipping under heavier loads. You don't need a spinnaker to get away from you too many times, before you figure this one out.
Don
Don Cook
ARC22 #2226
ADRENALIN
[Re: Cookie Monster]
#16468 02/18/03 12:45 PM 02/18/03 12:45 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Thanks David, and Don, As I said, they replaced the spin lock free, and now it works just fine with the alloy cleat. I thought maybe they were making both, and wanted to point out the better product. Todd
| | | I used it for a Jib halyard and it did not work...
[Re: Todd_Sails]
#16470 02/18/03 05:30 PM 02/18/03 05:30 PM |
Posts: 1,253 Columbia South Carolina, USA | It was not the line slipping, it was uncleating itself, I assume under load , but not sure since it was on the mast and got alot of slamming around with gybes and tacks and such. I will have to look at it and see if it is alloy. What is the replacement made of? It was bought at West Marine. David Mosley www.seacats.org
[Re: Todd_Sails]
#16471 02/19/03 02:01 PM 02/19/03 02:01 PM |
Posts: 47 | The spinlock's work well but sometimes believe it or not when you first go out on the water and pull the shute up you need to put some water on the cleat and line. Then she will hold. My memory is that the cleat wears out after a season or so on a cat. 1/4 inch spinnaker halyard would probably be best and actually easiest to handle. This cleat gets a lot of abuse.
Mark
C28R no. 140
Houston, TX
455
guests, and 43
