Nacra 5.0 #165501
01/21/09 04:15 AM
01/21/09 04:15 AM
E
Elfish
Elfish
E
Hello there
I'm new here and from Switzerland. Unbeatable combo for a very poor english. Please excuse me...
Well, I just got a Nacra 5.0 (mid eighties) for free from my uncle. The boat is in a good condition.
Now I got a few questions because I want to tune my boat up a little bit.
- Is it possible to add a spi with snuffer?
- Ist it possible to add a Nacra 500 Squaretop Mainsail? Is it possible to add the new jib form the Nacra 500?
- Is there a rigging guide? Or a sail tuning guide?
Thanks in advance for your help.
Cheers from Switzerland
Elfish
Re: Nacra 5.0 [Re: ] #165529
01/21/09 09:56 AM
01/21/09 09:56 AM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
1. Yes you can add a spin
2. The Nacra 500 main will work but may not be optimal (this has been discussed on the forum), to make the jib work you would need to reposition the fairleads to the main beam (the 500 jib is smaller and non-overlapping).
3. There is a basic rigging guide on the performance catamaran website, and lots of rigging and tuning advice can be found by searching the forums or asking.
Good luck with your new boat.
Re: Nacra 5.0 [Re: hokie] #165534
01/21/09 10:18 AM
01/21/09 10:18 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Is the 500's mast using swept spreaders? I'm assuming the old 5.0's had straight spreaders.
Re: Nacra 5.0 [Re: ThunderMuffin] #165588
01/21/09 02:18 PM
01/21/09 02:18 PM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
they are swept on the 5.0 and 500
Re: Nacra 5.0 [Re: hokie] #165808
01/22/09 10:42 PM
01/22/09 10:42 PM
jcasto1 Offline
jcasto1  Offline
Very old NACRA 5.0 had straight spreaders - I know, I used to have one. So did the old 5.2s. NACRA changed to swept sometime before 87.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Nacra 5.0 [Re: ] #165823
01/23/09 06:56 AM
01/23/09 06:56 AM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
Hallo Elfish,
ich hatte ebenfalls einen NACRA 5.0 mit Spi, aber ohne Snuffer. Anstatt dessen hatte ich eine Tasche auf dem Trampolin - keine besonders tolle Lösung.
Wenn ich mich recht erinnere hat der NACRA 5.0. die Fockholepunkte auf den Rümpfen - der NACRA 500 aber auf den Beams. Die neue Fock passt nur, wenn Du die Fockholepunkte verlegst: ein ziemlicher Aufwand!
Bezüglich neuem Groß könntest Du den deutschen NACRA-Vertrieb anrufen: +49 40 5249538. Sven kennt beide Boote UND ist Segelmacher, dort solltest Du eine kompetente Antwort bekommen.
Wie auch immer: Du hast da ein tolles Anfängerboot und ich wünsche Dir viel Spaß damit,
Kai
F18: C2 / A-Cat: Minelli
Re: Nacra 5.0 [Re: Baltic] #165824
01/23/09 07:13 AM
01/23/09 07:13 AM
Dunedin Causeway, FL
David Parker Offline
... Fockholepunkte ...
????? confused
Re: Nacra 5.0 [Re: jcasto1] #165844
01/23/09 09:27 AM
01/23/09 09:27 AM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
But these spreaders are still used with slack diamonds...no prebend. I think the sweep was just to help with the jib hanging up.
Re: Nacra 5.0 [Re: David Parker] #165851
01/23/09 09:55 AM
01/23/09 09:55 AM
andrewscott
andrewscott
????? confused
Don't be so COY Dave!
Re: Nacra 5.0 [Re: ] #165873
01/23/09 11:15 AM
01/23/09 11:15 AM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
=> mounting of jib-sheet blocks. Everything else is clear? smile
Re: Nacra 5.0 [Re: bobcat] #165877
01/23/09 11:23 AM
01/23/09 11:23 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
The 500 sport uses prebend
Re: Nacra 5.0 [Re: ] #165939
01/23/09 05:21 PM
01/23/09 05:21 PM
????? confused
I sail a Nacra 5.0 and I never knew about the Fockholepunkte. I speak fair German but that one is new to me.
Andrew, instead of yelling "Starboard!" at you, next time I'll try "Fockholepunkte". grin
Re: Nacra 5.0 [Re: Baltic] #165940
01/23/09 05:25 PM
01/23/09 05:25 PM
How about translating Segelmacher and Rümpfen?
Re: Nacra 5.0 [Re: David Parker] #165946
01/23/09 07:12 PM
01/23/09 07:12 PM
japan
erice Offline
erice  Offline
japan
[/quote]
Andrew, instead of yelling "Starboard!" at you, next time I'll try "Fockholepunkte". grin [/quote]
i think it will be more effective as
FOCKHOLE.............punkte!
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Nacra 5.0 [Re: erice] #165949
01/23/09 07:33 PM
01/23/09 07:33 PM
I think we just got punkte.
Re: Nacra 5.0 [Re: John Williams] #165969
01/24/09 08:26 AM
01/24/09 08:26 AM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
... okay, okay - I got the message ... whistle
German is always good for a joke since we tend to combine several nouns into one word. But since he said he is swiss and his english not that good ...
Segelmacher =>sail maker (that one should have been obvious ...)
Rümpfe => in this context: hulls
Re: Nacra 5.0 [Re: Baltic] #165997
01/24/09 05:57 PM
01/24/09 05:57 PM
I thought it was fun.
Re: Nacra 5.0 [Re: Baltic] #166323
01/27/09 12:09 PM
01/27/09 12:09 PM
E
Elfish
Elfish
E
Thanks guys. I've found now mostly all the answers I was looking for... smile
Re: Nacra 5.0 [Re: David Parker] #166325
01/27/09 12:38 PM
01/27/09 12:38 PM
andrewscott
andrewscott
How about next time you want cut me off and yell "starboard" at me, you wait until we are racing...
How about next time you want cut me off and yell "starboard" at me, don't do it infront of a channel marker, so i dont have to put it in reverse to avoid hitting the channel marker
How about next time you want cut me off and yell "starboard" at me, you dont do it in front of a channel marker so you don't hit the channel marker....
OR you could just not cut me off..... but that would be boring! ;p
0 registered members (), 2,569 guests, and 461 spiders.
Yesterday at 10:10 AM
