| Adjustable Outhaul #166125 01/26/09 08:46 AM 01/26/09 08:46 AM |
Posts: 118 Pensacola, FL | Recently, I crewed on an infusion and it did not have an adjustable outhaul. It just had a short piece of line at the end of the boom that you would loop through the clew. You could adjust it while on the beach or between races but probably not while racing. I was thinking of changing to this system because it was so easy to use. Is anyone adjusting the outhaul when changing from upwind to downwind on a spin boat?
Chris Trident F16
| | | Re: Adjustable Outhaul
[Re: Cab]
#166126 01/26/09 08:54 AM 01/26/09 08:54 AM |
Posts: 12,310 South Carolina | Recently, I crewed on an infusion and it did not have an adjustable outhaul. It just had a short piece of line at the end of the boom that you would loop through the clew. You could adjust it while on the beach or between races but probably not while racing. I was thinking of changing to this system because it was so easy to use. Is anyone adjusting the outhaul when changing from upwind to downwind on a spin boat? I always adjust it from upwind to down unless it's really nuclear out (since it could power up the boat more and when surviving is worth more than 1/100th a knot in speed)...I can't really speak for how effective it is - I just have always done it.
Jake Kohl | | | Re: Adjustable Outhaul
[Re: Cab]
#166127 01/26/09 08:54 AM 01/26/09 08:54 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | we do it on every downwind leg. once we go around the A mark, that outhaul goes loose, along with the board up a bit, the mast over rotated, downhaul off, jib out, spin up of course. | | | Re: Adjustable Outhaul
[Re: Cab]
#166128 01/26/09 08:55 AM 01/26/09 08:55 AM |
Posts: 3,906 Clermont, FL, USA | I quit adjusting the outhaul shortly after I switched to spin boats.
[Re: ThunderMuffin]
#166129 01/26/09 09:01 AM 01/26/09 09:01 AM |
Posts: 2,584 +31NL | I dont really see why you would want to adjust it when going downwind with the spin up except for extreme lowwind conditions maybe. The mainsail doesnt know if its going upwind or downwind, with the apparent wind angle at almost 90°. Seems like another thing to forget resetting before going upwind. | | | Re: Adjustable Outhaul
[Re: wildtsail]
#166139 01/26/09 09:48 AM 01/26/09 09:48 AM |
Posts: 2,844 42.904444 N; 88.008586 W | When I used to sail boats like my Prindle 18-2, stock, no spin, it was a must. Outhaul, downhaul, boards, rotator, barberhauler....., every a or c mark. (remember when they had a 'b' mark?)
But with a more recent, spin rigged boat, it's been said.
F-18 Infusion #626- SOLD it!
[Re: Cab]
#166259 01/27/09 01:42 AM 01/27/09 01:42 AM |
Posts: 2,921 Michigan | I can see the reason to have it be set, but sometimes I think it is helpful to really flatten it if you get caught in high winds.
[Re: Cab]
#166269 01/27/09 06:59 AM 01/27/09 06:59 AM |
Posts: 1,203 uk | Outhaul is released automaticaly when the down haul is released because the foot of the sail is angled down at the front.
To set the fixed outhaul right, release it fully,apply max downhaul then set the out haul to firm.
Some guys set the outhaul too tight then go out and gun the downhaul and pull the bottom of the sail out of the track!
[Re: TEAMVMG]
#166277 01/27/09 09:07 AM 01/27/09 09:07 AM |
Posts: 3,528 Looking for a Job, I got credi... | Outhaul is released automaticaly when the down haul is released because the foot of the sail is angled down at the front.
Some guys set the outhaul too tight then go out and gun the downhaul and pull the bottom of the sail out of the track! Agreed.
F16 - GBR 553 - SOLD I also talk sport here | | |
687
guests, and 134
