Snuffer Dimensions #166675
01/29/09 10:35 PM
01/29/09 10:35 PM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
I have started talking with Dennis at Barefoot Studios to make a snuffer that we could adapt to the ARC21. One of the questions he asked me(that I can;t answer) was, what is the diameter if the sail after it has been scrunhed by the snuffing line that runs thu the patches. Can one of you Nacro 20 or tornado guys measure the opening of your snuffer and the length of the bag to give me a starting measurment?
Mucho Garcias,
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Snuffer Dimensions [Re: arbo06] #166678
01/29/09 10:59 PM
01/29/09 10:59 PM
TeamChums Offline
TeamChums  Offline
Dennis is in the process of making one for an I 20 right now. He should already have that info. I'll measure mine in the am if you don't have it by then. We're running the same snuffer socks as the F18's, if that helps.
Lee
Re: Snuffer Dimensions [Re: TeamChums] #166688
01/30/09 01:08 AM
01/30/09 01:08 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Hey Lee,
I hate to be *that guy* but you realize that a snuffer made for your N20 outside of performance isn't class legal....
Re: Snuffer Dimensions [Re: ThunderMuffin] #166698
01/30/09 07:08 AM
01/30/09 07:08 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Obviously its an unfair advantage having an after market snuffer....
equally an after market tramp mat gives an unfair advantage... so the class rules say...
make you wonder what goes through their minds besides money...
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Snuffer Dimensions [Re: Dazz] #166708
01/30/09 07:47 AM
01/30/09 07:47 AM
Frankly, it IS an advantage. The N20 snuffer hoop is too small for the spinnaker size which makes setting and dousing extremely physical and slow. A properly designed snuffer can take a second or better of the set and when your boat moves at a hull length per second...that's a significant advantage around the cans. If I could have legally changed ours I would have done so a long time ago.
Re: Snuffer Dimensions [Re: Jake] #166723
01/30/09 08:56 AM
01/30/09 08:56 AM
Portland, Maine
Portland, Maine
I'm not going to be a dick about someone using a non-PC spin pole, or rudder crossbar, or tiller extension or whatever. Jake's spot on though - the snuffer is not properly designed for the 20 and the fact that everyone has to deal with it is the only reason why its bearable.
Re: Snuffer Dimensions [Re: TeamChums] #166730
01/30/09 09:17 AM
01/30/09 09:17 AM
andrewscott
andrewscott
I purchased my ring/bag from Jill/Robbie and i know that the system i use is the tornado bag... and is longer than the f18 bag to accomidate a larger spin.
Re: Snuffer Dimensions [Re: ] #166760
01/30/09 12:32 PM
01/30/09 12:32 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
For the bag length measure from where on the pole you want the snuffer to sit. On the snu on my tiger I moved iy up 6 inches in front of the bridle. Makes snuffing easier if you start to round up. Then measure back to the end of the pole . Thats the bag length. Or you can hold your arm in a small circle and pull the spin through with the snuffer line attached. Like your arm was the mouth and find out how long you need.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Snuffer Dimensions [Re: F-18 5150] #166766
01/30/09 01:22 PM
01/30/09 01:22 PM
Or measure from your two upper/lower-most snuffing points to the corner(s) of the spinnaker...that's bag length.
Re: Snuffer Dimensions [Re: Jake] #166777
01/30/09 02:44 PM
01/30/09 02:44 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Jake don't give him the easy way.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Snuffer Dimensions [Re: ThunderMuffin] #166784
01/30/09 03:09 PM
01/30/09 03:09 PM
TeamChums Offline
TeamChums  Offline
Hey Lee,
I am fully aware of that. I'm just making a reference to what is being used. I ONLY use class legal hardware on my boat. Especially for Tybee and GT300 since it would really suck to get DSQ'd after laying out all that dough for the race. The SNU is for a SanDiego N20. I actually will get to try it out since it's going on the boat that I'm using in the Border Run Race this year in April.
Lee
Re: Snuffer Dimensions [Re: TeamChums] #166785
01/30/09 03:15 PM
01/30/09 03:15 PM
Portland, Maine
Portland, Maine
Word. I had a feeling that it had a logical reason :P
Re: Snuffer Dimensions [Re: Jake] #166833
01/30/09 09:43 PM
01/30/09 09:43 PM
Dazz Offline
Dazz  Offline
Now I get it.. they are making more money from the extra wear and tear on kites... that is really harsh, has anyone tried to change the rules through the class association?
"Darph Bobo"
Re: Snuffer Dimensions [Re: Dazz] #166837
01/30/09 09:51 PM
01/30/09 09:51 PM
TeamChums Offline
TeamChums  Offline
Actually I was the one who got the rule changed for the rotator arm to be relocated to the base. I set mine up that way before the Tybee in 07. Not knowing it was an infraction, I was threatened with protest at a later regatta. Then went through the channells of the Nacra class (one guy actually)to get the change. I doubt if they will let us shop hoops from outside sources. It would be less revenue for PC.
Lee
Re: Snuffer Dimensions [Re: TeamChums] #166840
01/30/09 09:55 PM
01/30/09 09:55 PM
Portland, Maine
Portland, Maine
PC ain't gonna change the hoop design. Like was earlier stated, its the same hoop for the F18/Infusion.
Re: Snuffer Dimensions [Re: ThunderMuffin] #166848
01/30/09 11:13 PM
01/30/09 11:13 PM
arbo06 Offline OP
arbo06  Offline OP
One Design is One Design. You commit when you buy.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Snuffer Dimensions [Re: F-18 5150] #166849
01/30/09 11:22 PM
01/30/09 11:22 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Jake's method for measuring bag length worked for me. I have Dennis' snuffer sized for the F18 on my HT, and much as I like it, it's still a bit tight for my Glaser spin. I'd definitely want a larger hoop for your boat.
Dave
Re: Snuffer Dimensions [Re: davefarmer] #166853
01/30/09 11:38 PM
01/30/09 11:38 PM
arbo06 Offline OP
arbo06  Offline OP
That is the info I am looking for. Thank you Dave.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Snuffer Dimensions [Re: davefarmer] #166854
01/30/09 11:57 PM
01/30/09 11:57 PM
arbo06 Offline OP
arbo06  Offline OP
OK, who makes a larger hoop?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Snuffer Dimensions [Re: ThunderMuffin] #167546
02/07/09 05:10 PM
02/07/09 05:10 PM
TeamChums Offline
TeamChums  Offline
Unlimited events such as long distance
races and demonstration events may make exceptions to these Class Rules
provided that sailors are notified in the Notice of Race.
Jake, I am really looking for your input on this one as well. I was contacted by the SNU designer and asked if I would run one of these in the Tybee and the GT300 this year. How much resistance would I get from youguys if I raced with it? Both Dennis and myself are going to see if Jack will make them an option to be bought through PC. It's a long shot. If we have some support from youguys (like calling and voicing your opinion to Jack on the matter of giving us an alternative) it may give us a better option for the N20.
Lee
0 registered members (), 405 guests, and 179 spiders.
