Non Skid Paint / Interlux #167583
02/08/09 08:44 AM
02/08/09 08:44 AM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
Have any of you ever used this product?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Non Skid Paint / Interlux [Re: arbo06] #167585
02/08/09 08:55 AM
02/08/09 08:55 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I added the dry nonskid mix to Interlux Perfection for my decks on the Acat. Worked great.
Re: Non Skid Paint / Interlux [Re: arbo06] #167591
02/08/09 10:12 AM
02/08/09 10:12 AM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
Hey Eric,
I used Interdeck on my I20 and am less than happy with the results. Unfortunately it is just not durable enough. The paint has worn through in some areas. If I were to do it again, I spend the extra few bucks for Perfection and add the non skid additive.
Good luck! Post some pics when you're done!
Todd Nacra 20 www.wrcra.org
Re: Non Skid Paint / Interlux [Re: Todd Berget] #167592
02/08/09 10:14 AM
02/08/09 10:14 AM
arbo06 Offline OP
arbo06  Offline OP
Thanks guys, great feedback. Here is a pic without the nonskid.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Non Skid Paint / Interlux [Re: arbo06] #167656
02/09/09 03:42 AM
02/09/09 03:42 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I did some tests with Interlux Interdeck, with increasing amounts of non-skid additive and also some aerosol spray on called Industrial Choice Anti-slip from Rustoleum.
I applied all to a section of plexiglass about 8"x4" each test square. When dried, I put on Gul sailing booties on the plexi and applied water under them. The booty had a 1lbs weight in it and I tied off a fishing scale to one end. Dragging the wet boot across the test patches gave me a measurement of traction on the scale. The Interlux was not the best...even with quite course amounts of additive. The aerosol was nearly 2x the traction. I had used both the clear and the black, with black giving about 0.5x more traction as the clear. So, I tried in on the hull gunwales...thinking it would likely come off in a couple of weeks....well it held up for over 2 years and only now it could it do with a refresh. Traction has been superb. One of the best things about it...it does not make the surface to rough that is eats through your drysuit or rip skin off your knuckles. I'm thinking to cover the whole deck with it.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
0 registered members (), 1,116 guests, and 192 spiders.
