| Adding Positive Mast rotation #169013 02/20/09 10:36 PM 02/20/09 10:36 PM |
Joined: Jun 2001 Posts: 1,911 South Florida & the Keys arbo06 OP
Posts: 1,911 South Florida & the Keys | Hey guys,
I want to add positive mast rotation to the ARC21.
I have a rotator bar that mounts in front of the beam. Do you have any tips or tricks for this arrangement before I start drillin?
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Adding Positive Mast rotation
[Re: arbo06]
#169030 02/21/09 08:28 AM 02/21/09 08:28 AM |
Posts: 1,203 uk | Make sure that it is really easy to release each time you tack. Get decent cam cleats[Harken] so that you can un-cleat under load when you do forget.
[Re: RickWhite]
#169041 02/21/09 09:39 AM 02/21/09 09:39 AM |
Posts: 1,911 South Florida & the Keys | That is a good question. the cuurent set up is this; the boom is in a pocket at the foot of the sail but does not attact to the mast.
I am having a new sail made and will be adding a more common style boom with a gooseneck on the mast.
John Sheifer called the rotator that I have a Platypus style rotator.
[Re: arbo06]
#169052 02/21/09 11:01 AM 02/21/09 11:01 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | I had a Platapus on my Tornado, but wasn't really crazy about it. If perfectly balanced, they worked well. The reason I asked about the boom is that on the N6.0NA they were boomless and you had to apply positive mast rotation all the time, upwind and downwind. I had a perfect system on mine and thought I would tell you about that one, but if you have a boom, it wouldn't work. Rick | | | Re: Adding Positive Mast rotation
[Re: arbo06]
#169059 02/21/09 12:25 PM 02/21/09 12:25 PM |
Posts: 1,203 uk | I thought the 21 was boomless! you don't +pve mast rotation, just make sure that the mainsheet angles aft enough to put some foward pressure on the gooseneck
[Re: TEAMVMG]
#169082 02/21/09 06:54 PM 02/21/09 06:54 PM |
Posts: 1,911 South Florida & the Keys | I guess the ARC21 is somewere in between. The lower batten is a 1" alu tube that runs the full length of the foot of the sail. Not a boomlet. Rotation is controlled by a horizontal plate wit 8 holes to adjust for wind strength. You cannot reset it on the water between legs.
405
guests, and 179
