Adding Positive Mast rotation #169013
02/20/09 10:36 PM
02/20/09 10:36 PM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
Hey guys,
I want to add positive mast rotation to the ARC21.
I have a rotator bar that mounts in front of the beam. Do you have any tips or tricks for this arrangement before I start drillin?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Adding Positive Mast rotation [Re: arbo06] #169027
02/21/09 08:09 AM
02/21/09 08:09 AM
cyberspeed Offline
cyberspeed  Offline
With the self tacker, shouldn't it point back?
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Adding Positive Mast rotation [Re: arbo06] #169030
02/21/09 08:28 AM
02/21/09 08:28 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Make sure that it is really easy to release each time you tack. Get decent cam cleats[Harken] so that you can un-cleat under load when you do forget.
Re: Adding Positive Mast rotation [Re: arbo06] #169031
02/21/09 08:32 AM
02/21/09 08:32 AM
RickWhite Offline
RickWhite  Offline
forgot, do you have a boom?
Rick White
www.onlinemarinestore.com
Re: Adding Positive Mast rotation [Re: RickWhite] #169041
02/21/09 09:39 AM
02/21/09 09:39 AM
arbo06 Offline OP
arbo06  Offline OP
That is a good question. the cuurent set up is this; the boom is in a pocket at the foot of the sail but does not attact to the mast.
I am having a new sail made and will be adding a more common style boom with a gooseneck on the mast.
John Sheifer called the rotator that I have a Platypus style rotator.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Adding Positive Mast rotation [Re: arbo06] #169052
02/21/09 11:01 AM
02/21/09 11:01 AM
RickWhite Offline
RickWhite  Offline
I had a Platapus on my Tornado, but wasn't really crazy about it. If perfectly balanced, they worked well.
The reason I asked about the boom is that on the N6.0NA they were boomless and you had to apply positive mast rotation all the time, upwind and downwind.
I had a perfect system on mine and thought I would tell you about that one, but if you have a boom, it wouldn't work.
Rick
Rick White
Re: Adding Positive Mast rotation [Re: cyberspeed] #169057
02/21/09 11:51 AM
02/21/09 11:51 AM
arbo06 Offline OP
arbo06  Offline OP
good point, I'll have interference......
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Adding Positive Mast rotation [Re: arbo06] #169059
02/21/09 12:25 PM
02/21/09 12:25 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
I thought the 21 was boomless!
you don't +pve mast rotation, just make sure that the mainsheet angles aft enough to put some foward pressure on the gooseneck
Re: Adding Positive Mast rotation [Re: TEAMVMG] #169082
02/21/09 06:54 PM
02/21/09 06:54 PM
arbo06 Offline OP
arbo06  Offline OP
I guess the ARC21 is somewere in between. The lower batten is a 1" alu tube that runs the full length of the foot of the sail. Not a boomlet. Rotation is controlled by a horizontal plate wit 8 holes to adjust for wind strength. You cannot reset it on the water between legs.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Adding Positive Mast rotation [Re: arbo06] #169084
02/21/09 09:13 PM
02/21/09 09:13 PM
cyberspeed Offline
cyberspeed  Offline
I see arbo06, you answer posts but not my calls. Sailing tomorrow?
craig van eaton
Supercat 20
TEAM CYBERSPEED
Endurance Series
www.SailSeries.com
Re: Adding Positive Mast rotation [Re: cyberspeed] #169086
02/21/09 09:18 PM
02/21/09 09:18 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
GUMBO
Isak Dinesen
E. B. White
Re: Adding Positive Mast rotation [Re: Team_Cat_Fever] #169090
02/21/09 10:15 PM
02/21/09 10:15 PM
cyberspeed Offline
cyberspeed  Offline
Alright BOY, I finally have most of my major projects off my plate and have my boat is back on the beach after almost a year hiatias. Last year almost killed me. Too much work and no relief valve.
Not a good pic (from my phone) but gives you the idea from last Sunday.
www.themanshed.net/supercat-20/?g2_itemId=75
The built in cooler works great. I put ice and beer in it Saturday and there was still ice in it on Sunday.
craig van eaton
Supercat 20
TEAM CYBERSPEED
Endurance Series
www.SailSeries.com
0 registered members (), 360 guests, and 330 spiders.
